Gigantisk explosion i ryskt vattenkraftverk???
Mizzarrogh
Re: Gigantisk explosion i ryskt vattenkraftverk???
Inlägg av Mizzarrogh »
Att det orsakat rusning i turbinen (om nu detta är tekniskt möjligt) eller tryckchock?
GFEF
Inlägg av GFEF »
Uppdatering om olyckan.
Nu anges vattenslag i en turbin som start orsak.
Transformator fel följdskador från översvämning.
http://en.wikipedia.org/wiki/2009_Sayano–Shushenskaya_hydroelectric_power_station_accident
Länkfix /blueint
Mizzarrogh
Ok, jo det verkar ju som att en turbin möjligen är ramponerad av bilderna att döma (men var ju svårt att se exakt på de första utan att spekulera, lät inte heller särskilt sannorlikt att det skulle ha orsakats av för högt varvtal i en sådanhär anläggning.), vattenslag låter ju i allafall som den rimligaste förklaringen hittills tycker jag. :humm:
blueint
Inlägg av blueint »
Verkar inte så konstigt längre..
"According to the former director of Irkutskenergo, Viktor Bobrovski, the accident could have been caused by an incorrect start-up process of the turbine which resulted in an hydraulic pressure surge, or the excess load of the turbine caused by the peak consumption of electricity. According to Bobrovski, it is common practice in the region to compensate for peak load by overloading hydroelectric power plants, and the energy system of the region is near collapse, as the main goal of its owners is to take out as much profit as possible cutting down on maintenance, investment, safety, and educational costs. Since the load for other turbines ceased after the collapse of the turbine № 2, they probably started to spin without load at increasing speed until they smashed. He said that former director of Sayano–Shushenskaya hydroelectric power station Valentin Bryzgalov had alerted that it is dangerous to operate the plant at its maximum loads when the turbines are starting to vibrate in the axial direction. He said that the accident probably would not have had such catastrophic results if the safety systems had worked and the safety rules had been followed. According to Rostekhnadzor, the automatic shutdown system of the water intake pipes' gates failed after failure of the turbine № 2."
Bara å vänta på nästa Tjernobyl då ..
GFEF
Inlägg av GFEF »
Mizzarrogh
blueint
Inlägg av blueint »
Här syns turbintypen lite (englishrussia.com):
prototypen
Inlägg av prototypen »
Mizzarrogh skrev:Cleaning up the mess...
http://englishrussia.com/?p=5141#comment-783872
STOOOOOPP
För mig leder denna länk till ett "antivirusprogram" men då det var .exe så gick det inte igång på Maccen turligt nog.
Protte
maDa
Inlägg av maDa »
Usch, det där måste varit en ordentlig smäll. Måste ta tid att städa upp detdära, inga små prylar ju.
Mizzarrogh
Protte, för mig funkar den som den skall, men fick problem med liknande skit på en annan av deras sidor, men nu verkar det ok? :humm: (Kör Avast, senast uppdaterad idag för några minuter sedan).
prototypen
Nu är det något helt annat, det fanns VÄLDIGT många kul bilder där och det länkades vidare till andra kul sidor.
Protte
netrunner
Inlägg av netrunner »
Shit asså.
Det är ju inte "kasst med liten boll" om man säga så. Det behövs nog lite kraft för att flytta dom grejerna.
tobbe
Inlägg av tobbe »
Här var de lite klipp från övervakningskameror.
blueint
Inlägg av blueint »
filehero.com - som .mp4 (hög kvalite)
Uppenbart att elektriska bommar utan manuell funktion är rätt osmart..
AndLi
Inlägg av AndLi »
Det finns säkert en manuell förbikoppling, sannolikt visste ingen i närheten av bommen hur den funka..
Mer intressant är ju att de är så rädda om bilen så de inte bara rammar bommen, mtp att de med lätthet kan trycka den uppåt borde den lika lätt ge efter om man trycker in motorhuvuden under... men det ger ju en viss risk för lackskador...
