Men jag försöker hjälpa så gott jag kan
verkar som
processor pic16f628a
list p=pic16f628a
list p=pic16f628a
006 LOAD C:/xwisp/lesson4a.HEX
OK
007 GO
An exception ocurred which was not explicitly handled by the XWisp application. The traceback below might give some information about the exception.
Traceback (most recent call last):
File "xwisp.py", line 6226, in Interpret
File "xwisp.py", line 6204, in Execute
File "<string>", line 1, in <module>
File "xwisp.py", line 5443, in CMD_GO
File "xwisp.py", line 5956, in Connect_If_Needed
File "xwisp.py", line 5938, in Connect_Port
File "xwisp.py", line 918, in __init__
File "xwisp.py", line 943, in Open_Port
AttributeError: 'int' object has no attribute 'replace'
ERROR
