If, among the models with the
best rated vacuum cleaner, you want to witness strong suction power that can clean up anything, you have come to the right place with this review of the Dyson Cyclone V10 Absolute Lightweight Cordless Stick Vacuum cleaner.OVERVIEW
The Dyson Cyclone V10 Absolute Lightweight Cordless stick vacuum cleaner is the embodiment of a combination of highly efficient suction power, user-friendliness, and great flexibility in a single stick vacuum. If that is not the definition of high quality, we are not sure what is. However, we do have some bad news: High quality often means expensiveness... and this vacuum is on the higher end of affordability.
Yet, do not be too discouraged. If you see this in a positive and optimistic way, you will find that the quality and performance it offers you are worth more than the price that it comes with. And with its strong durability, this vacuum will serve you well for a long time. It is still a good deal in the end. With proper care and maintenance, it might be the only vacuum cleaner you will ever need.
There should be no doubt about the efficiency of the vacuum’s suction power, as it comes with Dyson’s famous Cyclone technology. This is a special kind of technology that allows the machine to produce one of the strongest cyclonic suctions among the best vacuums while consuming energy at an efficient rate. Combined with the effectively designed brush roll, this makes the machine able to clean and pick up almost any kind of mess, smoothly and quickly.
★★★ For More Information: What is the best rated vacuum cleaner
The fact that the machine can save energy is very important, as the vacuum cleaner runs entirely on a limited battery life. It has been reported that the machine can run for about an hour on normal settings. With stronger settings, that time is drastically reduced to about 15 minutes. You should keep this in mind when operating the vacuum so that you can plan things out better and clean up everything.
Another great thing about this vacuum cleaner is that the dustbin capacity has been improved as compared to older models. Plus, because there is plenty of storage space, this means that you will not have to stop in the middle of cleaning to empty the dustbin. Speaking of emptying the dustbin, you will be happy to know that the emptying mechanic has also been improved to better help allergy sufferers avoid potential deadly allergens.
A downside of this vacuum cleaner is that it is a bit heavy. It weighs roughly the same as a conventional vacuum cleaner. However, because conventional vacuum cleaners are supported with wheels, you can easily push them around the house. In this case, you will be carrying a full-sized vacuum on your arm whenever you are operating it. Therefore, this might be ideal for some people, particularly the elderly.
CONCLUSION
Other than the weight problem, which is less of a problem than it actually sounds, this Dyson vacuum cleaner is one of the best vacuum cleaners on the market. The quality and performance of this vacuum are guaranteed by the reputation of Dyson. That means you know that you are looking at one of
Top 10 vacuum cleaners out there.
