Hjälp med omlindning
AndrewPayton
Inlägg av AndrewPayton »
Review of Dyson Cyclone V10 Absolute Lightweight Cordless Stick Vacuum
If, among the models with the Bild best rated vacuum cleaner, you want to witness strong suction power that can clean up anything, you have come to the right place with this review of the Dyson Cyclone V10 Absolute Lightweight Cordless Stick Vacuum cleaner.
OVERVIEW
The Dyson Cyclone V10 Absolute Lightweight Cordless stick vacuum cleaner is the embodiment of a combination of highly efficient suction power, user-friendliness, and great flexibility in a single stick vacuum. If that is not the definition of high quality, we are not sure what is. However, we do have some bad news: High quality often means expensiveness... and this vacuum is on the higher end of affordability.
Yet, do not be too discouraged. If you see this in a positive and optimistic way, you will find that the quality and performance it offers you are worth more than the price that it comes with. And with its strong durability, this vacuum will serve you well for a long time. It is still a good deal in the end. With proper care and maintenance, it might be the only vacuum cleaner you will ever need.
There should be no doubt about the efficiency of the vacuum’s suction power, as it comes with Dyson’s famous Cyclone technology. This is a special kind of technology that allows the machine to produce one of the strongest cyclonic suctions among the best vacuums while consuming energy at an efficient rate. Combined with the effectively designed brush roll, this makes the machine able to clean and pick up almost any kind of mess, smoothly and quickly.
★★★ For More Information: What is the best rated vacuum cleaner Bild
The fact that the machine can save energy is very important, as the vacuum cleaner runs entirely on a limited battery life. It has been reported that the machine can run for about an hour on normal settings. With stronger settings, that time is drastically reduced to about 15 minutes. You should keep this in mind when operating the vacuum so that you can plan things out better and clean up everything.
Another great thing about this vacuum cleaner is that the dustbin capacity has been improved as compared to older models. Plus, because there is plenty of storage space, this means that you will not have to stop in the middle of cleaning to empty the dustbin. Speaking of emptying the dustbin, you will be happy to know that the emptying mechanic has also been improved to better help allergy sufferers avoid potential deadly allergens.
A downside of this vacuum cleaner is that it is a bit heavy. It weighs roughly the same as a conventional vacuum cleaner. However, because conventional vacuum cleaners are supported with wheels, you can easily push them around the house. In this case, you will be carrying a full-sized vacuum on your arm whenever you are operating it. Therefore, this might be ideal for some people, particularly the elderly.
CONCLUSION
Other than the weight problem, which is less of a problem than it actually sounds, this Dyson vacuum cleaner is one of the best vacuum cleaners on the market. The quality and performance of this vacuum are guaranteed by the reputation of Dyson. That means you know that you are looking at one of Bild Top 10 vacuum cleaners out there.
alexanderson
Re: Hjälp med omlindning
Inlägg av alexanderson »
Det blir nog billigare för dig att köpa en mindre motor.
arvidb
Inlägg av arvidb »
alexanderson: På vilket sätt skulle det hjälpa trådstartaren att köpa en mindre motor?
Mindmapper
Inlägg av Mindmapper »
Kan den här hjälpa dig att få lägre varv/volt?
TomasL
Inlägg av TomasL »
Antar att du menar kW när du skriver KV, eller? vad menas med det.
Det finns ju något mindre motorer att välja på.
hawkan
Inlägg av hawkan »
kV = varvtal / volt.
Skulle tro att TS vill öka dragkraften genom att ha en större propeller och högsta effekten vid lägre varvtal.
Videon visar ju hur man gör så är man sugen så är det bara att sätta igång.
arvidb
Inlägg av arvidb »
TomasL: KV = motorkonstanten, skrivs väl egentligen KV snarare än KV - och absolut inte kV (kilovolt)!
Mer info.
TomasL
Inlägg av TomasL »
Jo, jag förstod det till slut, i princip back-emf i varv/volt
SeniorLemuren
Inlägg av SeniorLemuren »
Mindmapper skrev: ↑24 augusti 2020, 18:09:34 Kan den här hjälpa dig att få lägre varv/volt?
Det där med att vira alla parallella trådarna innan iläggning var något nytt. Det gör ju att det blir avsevärt trängre i spåret. Man måste även trä in härvan från änden i stället för att "spåra" ner den. Man använder inte spårisolering och inte lock över lindningen och det medför ju avsevärt kortare livslängd på lindningen eftersom den utsätts för stor centrifugalkraft och strävar att röra sig utåt i spåret. Det kan ju orsaka obalans om alla härvorna inte rör sig lika. En mycket felaktig omlindning skulle jag påstå.
hawkan
Inlägg av hawkan »
Jag såg också detta med att trådarna var tvinnade och det gör det mycket svårare att få plats med mycket koppar. Han hade säkert kunna få plats med ett varv till, alternativt ha fler trådar.
Statorn med lindningar står stilla i den här motorn.
SeniorLemuren
Ja. Ok, då har ju inte centrifugalkraften någon inverkan. Men det får ju som du säger plats mer tråd, antingen mer area eller fler varv, vilket man önskar. Dessutom skulle jag lägga in en spårisolering av t.ex 0.10 mm mylar.
