La min dimmer av tvärt?
LenaLoyd
Inlägg av LenaLoyd »
Common Types of Blade Steel: All You Need to Know
While searching for a high quality pocket knife to buy, it is crucial that you pay attention to the kind of knife steel that your knife uses. While the geometry and the design of the blade is important, the type of steel it is made from also contributes a lot to performance.
Blade steel is essentially a mixture of carbon and iron that also has some other metals mixed in by the manufacturer to boost certain characteristics (corrosion resistance, toughness, hardness …) Picking a type of steel that fits your usage and need will go a long way in ensuring that you’re satisfied with your best folding knife.
This article will tell you all you need to know about blade steel.
The Five Important Properties of Blade Steel
Toughness
Toughness refers to the blade’s ability to resist against chips and cracks as a result of impact or sudden force (i.e when you use the blade to slash or chop tough objects like tree branches). A chipped blade is incredibly difficult to fix, so naturally high toughness is preferred in Bild the best quality pocket knives.
Hardness
The harder the blade, the more resistant it will be against deforms (bents and dents) when the blade is stressed and abused.
Generally, the harder the blade, the less tough it’d be. As a result, balancing toughness and hardness is crucial to picking a good blade.
Wear Resistance
As you use your knife, the blade will eventually become worn out and dull. A blade with great wear resistance capability can delay this process by having a chemical composition with more carbides (tungsten, chromium vanadium, molybdenum ...), which are wear resistant. However, carbides are brittle and prone to cracking, so while it takes longer to wear out, you can crack and chip the blade much more easily.
Corrosion Resistance
A good pocket knife with corrosion resistance ability can protect itself against rust caused by humid and moist environments. Such a knife will be excellent for fishers and hunters who typically have to work in damp places near the water.
Edge Retention
Edge retention is the ability of the knife to hold an edge. Even after heavy, continuous use for a long period of time, these blades should still be able to maintain sharp edges without needing you to hone and sharpen them up.
Unfortunately, the better your blade’s edge retention ability is, the weaker its corrosion resistance capability becomes. You will have to pick one or another.
Stainless Steel
Stainless steel is a combination of ordinary steel and around 13% Chromium, which gives it better corrosion resistance than other kinds of blade steels (hence, the name “Stainless”.) It has inferior toughness and edge retention ability than others, however.
Sandvik, AUS, 400, 154CM are some of the more popular kinds of stainless steel there are.
Carbon Steel
Carbon steel is usually found in high quality pocket knives Bild in the survival and tactical department. They are extremely tough and hard, able to hold an edge for an incredibly long time and easy to sharpen to boot. Nonetheless, since it has very low Chromium content, carbon steel blades are far more susceptible to corrosion.
Popular carbon steel knives are cast from 10-series carbon steel like 1095.
Tool Steel
Tool steel is commonly used to make tools (saws, machine parts …). The most popular type of tool steel used to make cutting tools like good quality pocket knives is high-speed steel. They have extremely high hardness as well as corrosion resistance, but it’s at the cost of high toughness. Tool steel knives aren’t very ductile, so it’s quite easy to chip them if you’re not careful.
D2 tool steel is quite popular, as well as O1.
۞۞۞ See Also: the best pocket knife - Top rated pocket knife
Conclusion
Blade steel is important, but it doesn’t decide everything. Like we mentioned before, the design of the knife, the geometry are also important. Also remember to take into account your budget and other personal preferences in order to find a top rated pocket knife that would fit your fancy.
kodar-holger
Re: La min dimmer av tvärt?
Inlägg av kodar-holger »
Det kan sitta en rörsäkring i dimmern. Det är inte helt ovanligt att denna går sönder när en av lamporna går sönder. Under ett kort ögonblick just när lampan ger upp blir det kortslutning och det hinner säkringen i dimmern reagera på och bryta.
Kolla om ratten på dimmern går att dra loss och om där sitter en säkring under.
Hittade en guide med lite bilder. Det behöver inte se ut exakt så i just din dimmer men liknanade.
https://byggmentor.se/renovera/byta-sak ... ch-bilder/
Det är osannolikt att själva dimmern gått sönder.
Hobbyisten
Gått bort
Inlägg av Hobbyisten »
För mig började taklampan flämta (en dimmer var kopplad till den), fick byta säkringen några gånger. Efter byte till vanlig tryckknapp upphörde problemen.
MadModder
Inlägg av MadModder »
Då en vanlig standarddimmer brukar vara konstruerad för max ca 300W och absolut inte tål 10A sitter där i en säkring på nånstans runt 1,5A.
Har bytt några sådana efter att lampor poffat. :)
Hobbyisten skrev:För mig började taklampan flämta (en dimmer var kopplad till den), fick byta säkringen några gånger. Efter byte till vanlig tryckknapp upphörde problemen.
Glassäkringen i dimmern eller "proppen"?
Hobbyisten
Gått bort
Glassäkringen i dimmern :)
