Hej
Var hitta dessa kondensatorer eller ersätta kondensatorer med samma kapacitet och alla viktiga detaljer
moderkort acer aahd3-vc (acer aspire tc-105)
6.3V 820uF 105 ° C 8mmx11.5mm (original TK ATWY) Jag tittade igenom informationen som jag fann att det kan finnas viktiga detaljerade parametrar.
https://www.audunmelbye.no/2012/05/17/m ... rd-repair/
tillverkarens parametrar
http://www.paullinebarger.net/DS/TK%20% ... series.pdf
och den andra som inte kan identifiera 6.3v 1800uF
https://www.elektroda.pl/rtvforum/topic ... ml#gallery
TH...
Ersätta kondensator Acer aahd3-vc (acer Aspire tc-105)
Re: Ersätta kondensator Acer aahd3-vc (acer Aspire tc-105)
köpte original och motsvarande på ebay
TK 6.3V 820uF 105º Serie ATWY ULTRA LOW ESR 8x11,5/12
NIPPON 6.3V 820uF 105º Serie KZG ULTRA LOW ESR 8x12
SANYO 6.3V 1800 uF 105º Serie WX WG SUPER ULTRA LOW -8x15.4mm
Den andra kondensator köpte på ebay
Panasonic (JAPAN) series FL /1800uF /6.3v /105C /8x20 /1870mA r.m.s. /0.016 Om /3000 hours
...Panasonic FL is a genuine ultra-low ESR series for motherboard use, generally sold only to the large mobo OEMs like Asus, Gigabyte and the like. It isn't available at retail, and there's no datasheet online anywhere.
The ones on EBay could be genuine surplus caps from one of the mobo OEMs or contract manufacturers like Flextronics. However, there's no way to tell if it's genuine from the EBay pic alone, without measuring some of its properties like ESR, etc...
Källor:https://www.badcaps.net/forum/showthread.php?t=9859
