Svenska tecken på LCD I2C display ( 2x16 ) - Arduino
Albireo
Inlägg av Albireo »
Hej!
Försöker skriva en sträng (å - Bra gjort!) till en LCD I2C display med en Arduino.
(Men misslyckades!)
Skapade först ett program som skriver ut de svenska tecknen .: åäöÅÄÖ till LCD -displayen.
(Kanske går att lösa på ett smidigare sätt?)
https://forum.arduino.cc/index.php?topic=224615.0
YourDuino.com Example Software Sketch
16 character 2 line I2C Display
Backpack Interface labelled "YwRobot Arduino LCM1602 IIC V1"
terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h>  // Comes with Arduino IDE
#include <LiquidCrystal_I2C.h>
/* -----( Declare Constants )----- */
/* -----( Declare objects )-----   */
// set the LCD address to 0x27 for a 16 chars 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
byte AwithRing[8] = {
  B00100,
  B01010,
  B01110,
  B00001,
  B01111,
  B10001,
  B01111,
byte AwithDots[8] = {
  B01010,
  B00000,
  B01110,
  B00001,
  B01111,
  B10001,
  B01111,
byte OwithDots[8] = {
  B01010,
  B00000,
  B01110,
  B10001,
  B10001,
  B10001,
  B01110,
byte BigAwithRing[8] = {
  0b00100,
  0b01010,
  0b01110,
  0b10001,
  0b11111,
  0b10001,
  0b10001,
  0b00000
byte BigAwithDots[8] = {
  0b01010,
  0b00000,
  0b01110,
  0b10001,
  0b11111,
  0b10001,
  0b10001,
  0b00000
byte BigOwithDots[8] = {
  0b01010,
  0b01110,
  0b10001,
  0b10001,
  0b10001,
  0b10001,
  0b01110,
  0b00000
byte Minus[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b11111,
  0b00000,
  0b00000,
  0b00000
/*----( SETUP: RUNS ONCE )----*/
void setup() {
  Serial.begin(115200);  // Used to type in characters
  lcd.init();
  lcd.backlight();
//-------- Write characters on the display ------------------
  lcd.createChar(1, AwithRing);     //å
  lcd.createChar(2, AwithDots);     //ä
  lcd.createChar(3, OwithDots);     //ö
  lcd.createChar(4, BigAwithRing);  //Å
  lcd.createChar(5, BigAwithDots);  //Ä
  lcd.createChar(6, BigOwithDots);  //Ö
// Display. (Set Serial Monitor option to "No Line Ending")
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("å ä ö Å Ä Ö");
  lcd.setCursor(0,1);
  String message = "\01 \02 \03 \04 \05 \06 ";
  lcd.print(message);
} /*--(end setup )---*/
void loop() {   /*----( LOOP: RUNS CONSTANTLY )----*/
Det fungerar (på ett sätt)
På första raden skrivs ASCII-tecknen ut för å ä ö Å Ä Ö (med Arduinos kod-tabell - liknar japanska :) )
På andra raden skrivs å ä ö Å Ä Ö ut. (som förväntat.)
Skapade ett nytt program där strängen skrivs ut till LCD-skärmen från en variabel.
Problemet uppstår när å i strängen skall bytas mot den skapade bokstaven å.
Här kommer detta försök till program .:
 /* I2C LCD with Arduino example code. More info: https://www.makerguides.com
       https://www.makerguides.com/character-i2c-lcd-arduino-tutorial/  */
    // Include the libraries:
    // LiquidCrystal_I2C.h: https://github.com/johnrickman/LiquidCrystal_I2C
    #include <Wire.h> // Library for I2C communication
    #include <LiquidCrystal_I2C.h> // Library for LCD
    // Wiring: SDA pin is connected to A4 and SCL pin to A5.
    // Connect to LCD via I2C, default address 0x27 (A0-A2 not jumpered)
    // LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 20, 4); // Change to (0x27,16,2) for 16x2 LCD.
    LiquidCrystal_I2C lcd = LiquidCrystal_I2C(0x27, 16, 2);
    byte AwithRing[8] = {  //å
      B00100,
      B01010,
      B01110,
      B00001,
      B01111,
      B10001,
      B01111,
    byte AwithDots[8] = {  //ä
      B01010,
      B00000,
      B01110,
      B00001,
      B01111,
      B10001,
      B01111,
    byte OwithDots[8] = {  //ö
      B01010,
      B00000,
      B01110,
      B10001,
      B10001,
      B10001,
      B01110,
    byte BigAwithRing[8] = {  //Å
      0b00100,
      0b01010,
      0b01110,
      0b10001,
      0b11111,
      0b10001,
      0b10001,
      0b00000
    byte BigAwithDots[8] = {  //Ä
      0b01010,
      0b00000,
      0b01110,
      0b10001,
      0b11111,
      0b10001,
      0b10001,
      0b00000
    byte BigOwithDots[8] = {  //Ö
      0b01010,
      0b01110,
      0b10001,
      0b10001,
      0b10001,
      0b10001,
      0b01110,
      0b00000
    // https://www.arduino.cc/en/Reference/VariableDeclaration
    // https://www.arduino.cc/reference/en/language/variables/data-types/string/
    char TextLCD[16] = "å - Bra gjort!";  // Variable type .: String
    int i = 0;
    void setup() {
      lcd.init();       // Initiate the LCD:
      lcd.backlight();  // Backlight ON:
    void loop() {
      i = 0;
      while (i < strlen(TextLCD))
      { lcd.setCursor(i, 0); // Pekare på .: Kolumn1 - Rad1
        char pointer = TextLCD[i++];
        if ( pointer = "å" ) {
            String replace(pointer, "/1");
        lcd.print(pointer);
        // Serial.println(pointer);
        delay(500);
      lcd.clear();
      // lcd.setCursor(0, 1); // Pekare på .: Kolumn1 - Rad2
      // StringChar.TextLCD(1);
      // lcd.print(myChar);
      // lcd.print("Hello World!"); // Print the string "Hello World!" - Fungerarar!
      // lcd.setCursor(2, 1); //Set the cursor on the third column and the second row (counting starts at 0!).
      // lcd.print("LCD tutorial");
Är detta svårt att lösa?
GeekJoan
Admin
Re: Svenska tecken på LCD I2C display ( 2x16 ) - Arduino
Inlägg av GeekJoan »
Här är en liknande kod som jag kör på denna: https://photos.app.goo.gl/EXXmvAdg8usoJpze7
Du borde kunna klura ut det.
// SDA -> Pin A4
// SCL -> Pin A5
// Pot -> Pin A0
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
#include <Arduino.h>
#include <TM1637Display.h>
LiquidCrystal_PCF8574 lcd(0x27);  // set the LCD address to 0x27 for a 16 chars and 2 line display
// Arduino pin numbers
#define CLK 2
#define DIO 3
TM1637Display display(CLK, DIO);
const int Pot = A0;
int PotVal = 20;
int Sleep = 100;
int OldPotVal = 0;
void setup()
  pinMode(Pot, INPUT);
  lcd.begin(16, 2); // initialize the lcd
  lcd.setBacklight(255);
  Serial.begin(9600);
  B00100,
  B01010,
  B01110,
  B00001,
  B01111,
  B10001,
  B01111,
  B01010,
  B00000,
  B01110,
  B00001,
  B01111,
  B10001,
  B01111,
  B01010,
  B00000,
  B01110,
  B10001,
  B10001,
  B10001,
  B01110,
  0b00100,
  0b01010,
  0b01110,
  0b10001,
  0b11111,
  0b10001,
  0b10001,
  0b00000
  0b01010,
  0b00000,
  0b01110,
  0b10001,
  0b11111,
  0b10001,
  0b10001,
  0b00000
  0b01010,
  0b01110,
  0b10001,
  0b10001,
  0b10001,
  0b10001,
  0b01110,
  0b00000
  byte Minus[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b11111,
  0b00000,
  0b00000,
  0b00000
  lcd.createChar(7, Minus);
   display.setBrightness(7, true);
void loop()
  OldPotVal = PotVal;
  PotVal = analogRead(A0);
  PotVal = map(PotVal, 0, 1023, 0, 12);
  if (PotVal == OldPotVal){
    delay(Sleep);
  else {
  if (PotVal == 0){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Vi \02r h\02r!");
  lcd.setCursor(0,1);
  lcd.print("\06ppna och kom in!");
  display.showNumberDec(1, false);
  Serial.println(PotVal);
  if (PotVal == 1){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Vi \02r p\01 lunch!");
  lcd.setCursor(0,1);
  lcd.print("\04ter kl 13:00");
  display.showNumberDec(2, false);
  if (PotVal == 2){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Tillf\02lligt ute");
  lcd.setCursor(0,1);
  lcd.print("kommer snart");
  display.showNumberDec(3, false);
  if (PotVal == 3){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Vi har g\01tt f\03r");
  lcd.setCursor(0,1);
  lcd.print("dagen");
  display.showNumberDec(4, false);
  if (PotVal == 4){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Ute p\01 service");
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 10:00");
  display.showNumberDec(10, false);
  if (PotVal == 5){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 11:00");
  display.showNumberDec(11, false);
  if (PotVal == 6){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 13:00");
  display.showNumberDec(13, false);
  if (PotVal == 7){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 14:00");
  display.showNumberDec(14, false);
  if (PotVal == 8){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 15:00");
  display.showNumberDec(15, false);
  if (PotVal == 9){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 16:00");
  display.showNumberDec(16, false);
  delay(Sleep);
  if (PotVal == 10){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.setCursor(0,1);
  lcd.print("\04ter ca: 17:00");
  display.showNumberDec(17, false);
  if (PotVal == 11){
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("\05r i n\02r0heten");
  lcd.setCursor(0,1);
  lcd.print("Ring 0704\07l96170");
  display.showNumberDec(1961, false);
Xyzzy
Inlägg av Xyzzy »
Ändra:
if ( pointer = 'å' ) {
Till:
if ( pointer == 'å' ) {
  pointer = 1;
Edit: div korrigering
Som Xyzzy skriver är den rad fel! Med "if ( pointer = "å" )" GER du Pointer värdet "å" vilket per definition är TRUE (i C är allt annat än 0 TRUE).
Sedan anser jag att det även ska stå:
if (pointer == 'å')
då "å" motsvarar en STRÄNG som i detta fall består av "'å', noll".
Skillnaden är alltså " kontra ' där " innesluter en sträng och ' innesluter ett tecken.
Albireo
Inlägg av Albireo »
Tack för Ert egaremang!
(Ska försöka beskriva vad som inträffade)
Har testat att ändra till
        if (pointer == 'å') {
          pointer = 1;
Detta genererar ett fel
(lyckades inte få "taket" att peka under första snutten i 'å'
_________________________________________________
Har även funderat över en lösning likt denna (men försår inte hur instruktionen replace fungerar)
    TextLCD.replace('å', 1);
    TextLCD.replace('ä', 2);
    TextLCD.replace('ö', 3);
    TextLCD.replace('Å', 4);
    TextLCD.replace('Ä', 5);
    TextLCD.replace('Ö', 6);
BJ
Inlägg av BJ »
Jag vet inte vad felmeddelandet är, men det är
inte så att du har förväxlat ' bredvid Ä på tangentbordet
med en oskiftad fnutt mellan + och sudd-knappen?
Dom ser likadana ut i Linux mint med Geany eller Leafpad...
Albireo
Inlägg av Albireo »
Använde först "snutten" till höger om "Å" på tangntbordet!
Sedan kopierades lösningen från koden ovan.
Blev ingen skillnad :? !
Nu ser en del av koden ut på följande sätt .:
    void loop() {
      i = 0;
           pointer = 1;
        lcd.print(pointer);
        delay(500);
      delay(1000);
      lcd.clear();
BJ
Inlägg av BJ »
Okej.
Vad skriver den som felmeddelande?
arvidb
Inlägg av arvidb »
'å' är två bytes enligt UTF8: c3 a5. Tecknet ryms alltså inte i en char:
#include <stdio.h>
#include <stdlib.h>
int main(void)
	char c = 'å';
	printf("%c", c);
	return EXIT_SUCCESS;
$ gcc -Wall utf8-test.c -o utf8-test
utf8-test.c: In function 'main':
utf8-test.c:6:11: warning: multi-character character constant [-Wmultichar]
  char c = 'å';
utf8-test.c:6:11: warning: overflow in conversion from 'int' to 'char' changes value from '50085' to '-91' [-Woverflow]
Oavsett så kanske ett första steg är att byta namn på variabeln "pointer" till något som inte är lika missvisande? :)
Albireo
Inlägg av Albireo »
Detta fel skapas när programmet kompileras
. . . . . . . . . . . . . . . . . . . . ^~~~ (ett försök att få "taket" att peka under första snutten i 'å'
Körs programmet ignoreras "if-satsen"
arvidb
Inlägg av arvidb »
Men vad säger kompilatorn om vilket fel det är, det vill säga vad är själva felmeddelandet? Det där är ju bara platsen som det blir fel på.
BJ
Inlägg av BJ »
arvidb:s svar hade jag inte tänkt på. :doh:
Albireo
Inlägg av Albireo »
....\LCD-Test_write.ino:110:25: warning: multi-character character constant [-Wmultichar]
Sketch uses 2990 bytes (9%) of program storage space. Maximum is 32256 bytes.
Global variables use 310 bytes (15%) of dynamic memory, leaving 1738 bytes for local variables. Maximum is 2048 bytes.
______________________________________________________________________
Hela programmet!
      B00100,
      B01010,
      B01110,
      B00001,
      B01111,
      B10001,
      B01111,
      B01010,
      B00000,
      B01110,
      B00001,
      B01111,
      B10001,
      B01111,
      B01010,
      B00000,
      B01110,
      B10001,
      B10001,
      B10001,
      B01110,
      0b00100,
      0b01010,
      0b01110,
      0b10001,
      0b11111,
      0b10001,
      0b10001,
      0b00000
      0b01010,
      0b00000,
      0b01110,
      0b10001,
      0b11111,
      0b10001,
      0b10001,
      0b00000
      0b01010,
      0b01110,
      0b10001,
      0b10001,
      0b10001,
      0b10001,
      0b01110,
      0b00000
    int i = 0;
    void setup() {
    void loop() {
      i = 0;
           pointer = 1;
        lcd.print(pointer);
        delay(500);
      delay(1000);
      lcd.clear();
Är det raden .: char TextLCD[16] = "å - Bra gjort!"; som ska hanteras på annat sätt?
ex. String TextLCD = "å - Bra gjort!"; (ingen aning vad som skiljer)
Det är inte alls ovanligt att det inte får finnas program-tecken över ASCII 128 i källkoden.
Lösningen är då att ange värdet i hex.
if ( pointer == 0x<vaddetnuär> ) {
guckrum
Inlägg av guckrum »
Observera att kompilatorn ger en bra ledtråd i sitt felmeddelande. Läs felmeddelandena! (I din första post talade du bara om ATT det blev fel.) Felet är alltså att din editor representerar 'ä' med två bytes, kanske via UTF8-kodad unicode, medan din jämförelsesats i koden är på endast en char.
