Teamviewer14 + Debian ?
Marta
Inlägg av Marta »
Teamviewer autouppdaterades i datorn jag skall ansluta till och min version blev inkompatibel. Tvingades uppdatera till ver 14, men den startar inte. Påbörjar uppstart, men stannar.
Vad är det som saknas? Hur installeras detta?
Linux version 4.9.0-8-amd64 (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) )
#1 SMP Debian 4.9.130-2 (2018-10-27)
2019/07/03 09:24:56.492  2081 139678768872960 G   Logger started.
2019/07/03 09:24:56.493  2081 139678768872960 G   Found 0 stack dump files ...
2019/07/03 09:24:56.493  2081 139678768872960 G   Found 0 core dump files ...
2019/07/03 09:24:56.496  2081 139678768872960 G   systemd: logind service available
2019/07/03 09:24:56.499  2081 139678768872960 G   systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='3', canGraphical=1, canTTY=1, canMultiSession=1]
2019/07/03 09:24:56.500  2081 139678768872960 G   LogindSessionInfo: New session LogindSessionInfo [id=1 user=root state=user active=0 reliable=1 infoId=2212294583] [path=/org/freedesktop/login1/session/_31 TTY=tty1 seat=seat0 display= vtnr=1 owner=[SysUser: root [uid=0, gid=0 home=/root gecos=root shell=/bin/bash]] idle=0(1562144832856056) active=0 type=tty class=user state=online timestamp=1562144607819281 service=login defaultCG= leader=421 audit=1 remote=0 rHost= rUser= killProc=0]
2019/07/03 09:24:56.502  2081 139678768872960 G   LogindSessionInfo: New session LogindSessionInfo [id=3 user=marta state=user active=1 reliable=1 infoId=1842515611] [path=/org/freedesktop/login1/session/_33 TTY=tty2 seat=seat0 display= vtnr=2 owner=[SysUser: marta [uid=1000, gid=1000 home=/home/marta gecos=,,, shell=/bin/bash]] idle=0(1562144656872056) active=1 type=tty class=user state=active timestamp=1562144653613112 service=login defaultCG= leader=498 audit=3 remote=0 rHost= rUser= killProc=0]
2019/07/03 09:24:56.504  2081 139678768872960 G   SysSessionInfoManager: observing sessions from logind is marked as reliable
2019/07/03 09:24:56.504  2081 139678768872960 G   SysSessionInfoManager: Session Information provided by VT [priority: 2]
2019/07/03 09:24:56.504  2081 139678768872960 G!  FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
2019/07/03 09:24:56.507  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!
2019/07/03 09:24:56.508  2081 139678768872960 G   Running on Qt 5.11.3
2019/07/03 09:24:56.684  2081 139678768872960 G   Initialised XRandR extension 1.5 (base=89 error=147)
2019/07/03 09:24:56.894  2081 139678768872960 G   MonitorInfo: [XRandR 1.2] CRTC LVDS-1 1280x800@60Hz [0, 0, 1280, 800] - 1
2019/07/03 09:24:56.894  2081 139678768872960 G   MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
2019/07/03 09:24:56.894  2081 139678768872960 G   Virtual Desktop [0, 0, 1280, 800]
2019/07/03 09:24:57.102  2081 139678768872960 G   MonitorInfo: [XRandR 1.2] CRTC LVDS-1 1280x800@60Hz [0, 0, 1280, 800] - 1
2019/07/03 09:24:57.102  2081 139678768872960 G   MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
2019/07/03 09:24:57.102  2081 139678768872960 G   Virtual Desktop [0, 0, 1280, 800]
2019/07/03 09:24:57.111  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!
2019/07/03 09:24:57.123  2081 139678768872960 G!! ResourceLoader: loaded file '/opt/teamviewer/tv_bin/resources/TVResource_en.so' version (4730) is not matching with application version (14.3.4730)
2019/07/03 09:24:57.123  2081 139678768872960 G   Loaded language 'en', using locale 'en-GB'
2019/07/03 09:24:57.124  2081 139678768872960 G   InterProcessBase::SecureNetwork created
2019/07/03 09:24:57.126  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.129  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.132  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.135  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.138  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.138  2081 139678768872960 G   AutoLogin::Login: enabled: 1
2019/07/03 09:24:57.139  2081 139678768872960 G   AccountLoginStateMachine::Reset
2019/07/03 09:24:57.142  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.142  2081 139678768872960 G!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded, Errorcode=11
2019/07/03 09:24:57.145  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.146  2081 139678768872960 G!!!Own session could not be resolved, unable to startup, Errorcode=11
2019/07/03 09:24:57.148  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.149  2081 139678768872960 G   Chat::Stop: Stopping chat
2019/07/03 09:24:57.152  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.152  2081 139678768872960 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 9 failed with error 2, Errorcode=11
2019/07/03 09:24:57.152  2081 139678768872960 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 5 failed with error 2, Errorcode=11
2019/07/03 09:24:57.152  2081 139678768872960 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 6 failed with error 2, Errorcode=11
2019/07/03 09:24:57.152  2081 139678768872960 G!! ConfigurationHub::HandleRegistrationResponse(): registering for feature 10 failed with error 2, Errorcode=11
2019/07/03 09:24:57.155  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.158  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.161  2081 139678768872960 G!! SysSessionInfoManager::GetOwnProcessSession: No session found!, Errorcode=11
2019/07/03 09:24:57.162  2081 139678768872960 G   interprocessbase::SecureNetwork destroyed
2019/07/03 09:24:57.169  2081 139678768872960 G   Shutting down System DBus
mrfrenzy
Re: Teamviewer14 + Debian ?
Inlägg av mrfrenzy »
Det som ligger i /opt/teamviewer behöver uppdateras.
Kanske enklast att avinstallera och radera den mappen så bör det bli rätt vid nyinstallation av programmet.
Om det enbart är "(4730)" och "(14.3.4730)" så kanske det ändå är rätt,
bara lite felkodat. Står "(4730)" i TVResource_en.so? Kan man inte bara
prova att ändra det i så fall till "(14.3.4730)"?
4730 verkar vara ett "build-number" och det vore underligt om det är samma
men ändå inte samma version...
mrfrenzy
Inte kan det vara meningen att miljontals användare ska behöva ändra detta manuellt?
Något måste gått fel i installationen om det inte fungerar direkt.
Håller med helt där! Men *om* det nu ändå gick fel just här, och det går
att "fixa" på det sättet, varför inte prova? I dina miljontals användare,
räknar du in alla Windows användare också? Spelar ingen roll....
Marta
Inlägg av Marta »
Kan vara lite blandat. Har haft ver 12 som fungerade. Tyvärr vägrade den connect när 14 råkat slinka in i den dator som det skulle kopplas upp mot. Installerade ver14. Gnällde på gammal Qt i loggen. Installerade ver13 och där står sk*ten nu.
mrfrenzy
Hur har du gjort installationen då?
Om man använder APT som dom rekommenderar är det ovanligt med konflikter.
https://wiki.debian.org/Teamviewer
dpkg -l | grep teamviewer
ta bort allt som listas där med sudo apt remove teamviewer???
Nu ska det vara tomt i mappen /opt/teamviewer. Annars har du nåt gammalt skräp från en manuell installation.
Sedan är det bara ladda ner senaste versionen och installera
wget https://download.teamviewer.com/download/linux/teamviewer_amd64.deb
sudo apt install teamviewer_amd64.deb
Om det behövs någon version av QT eller andra bibliotek så fixar apt det automatiskt
Marta
Inlägg av Marta »
Tolvan installerades med dpkg och sedan apt-get --fix-broken install så fyllde den i de dependecies som var trasiga och avslutade installationen.
Inget funkar längre. Varken på ordinarie burk med jessie eller en laptop med buster. ps visar att teamviewerd är laddad och vid start från terminal ser det rätt ut, men teamviewer kommer inte upp.
Har provat ett avinstallera och /opt är rent. Har gjort rm -r på ~/.local/share/teamviewer utan resultat. Samma med /etc/teamviewer /var/lock/ fanns inget.
mrfrenzy
TeamViewer for Linux requires a Linux 2.6.27 kernel and GLIBC 2.17. Qt 5.6 is recommended for the best experience. Therefore, the following operating systems are supported:
Debian 9 (incl. Raspbian)
Det borde alltså fungera bra med Stretch och kanske Buster men inte med Jessie.
I deras gamla artikel står det att version 13 fungerar med Jessie men det gäller förmodligen inte version 14.
Tydligen installerar den också ett repository i /etc/apt/sources.list.d/teamviewer.list för uppdateringar, du kanske har nåt gammalt där som behöver rensas bort?
https://community.teamviewer.com/t5/Kno ... ta-p/30666
Marta
Inlägg av Marta »
Funkar teamviewer i virtualbox? I så fall sätter jag upp en vm med ubuntu, där ingår den väl i deras repository?
xxargs
Inlägg av xxargs »
Är du hårt styrd till att använda just teamwiever eller kan Anydesk också fungera - det senare verka fungera bättre i många fall och verkar inte lika versionskänslig som teamwiever
mrfrenzy
Självklart funkar det lika bra i virtualbox som på en fysisk maskin, men installationen i Ubuntu skiljer sig inte från debian. Jag föredrar också anydesk, det har mycket rimligare licens.
TeamViewer is proprietary computer software and it is not included in the Ubuntu repositories.
Marta
Inlägg av Marta »
Crap... Problemet är att den andra maskinen har just teamviewer och ägaren är 99% nollställd då det gäller datorer. Tycker inte om att behöva ge upp, men får väl inse att jag också börjar bli nollställd.
Hur som helst, det bli en ren installation med vb och långsamheten skall väl vara uthärdlig för den lilla bagatell det här gäller.
