MPLAB 8 hänger sig (GCC-PIC32) [LÖST]
Försöker använda ett eget linker-script, då jag vill ha en boot-loader.
Men, Har ändrat i linkerscriptet i enlighet med uChips instruktioner i AN1388.
Dock när jag kompilerar händer absolut ingenting när modulerna skall länkas.
Verkar som att allting bara stoppar, inga felmeddelanden eller dialogrutor, eller nånting.
 * Processor-specific object file.  Contains SFR definitions.
INPUT("processor.o")
 * For interrupt vector handling
PROVIDE(_vector_spacing = 0x00000001);
_ebase_address = 0x9D07F000;
 * Memory Address Equates
 * _RESET_ADDR      -- Reset Vector
 * _BEV_EXCPT_ADDR  -- Boot exception Vector
 * _DBG_EXCPT_ADDR  -- In-circuit Debugging Exception Vector
 * _DBG_CODE_ADDR   -- In-circuit Debug Executive address
 * _DBG_CODE_SIZE   -- In-circuit Debug Executive size
 * _GEN_EXCPT_ADDR  -- General Exception Vector
_RESET_ADDR              = 0xBFC00000;
_BEV_EXCPT_ADDR          = 0xBFC00380;
_DBG_EXCPT_ADDR          = 0xBFC00480;
_DBG_CODE_ADDR           = 0xBFC02000;
_DBG_CODE_SIZE           = 0xFF0     ;
_GEN_EXCPT_ADDR          = _ebase_address + 0x180;
 * Memory Regions
 * Memory regions without attributes cannot be used for orphaned sections.
 * Only sections specifically assigned to these regions can be allocated
 * into these regions.
MEMORY
  kseg0_program_mem    (rx)  : ORIGIN = 0x9D07E690, LENGTH = 0x79690
  kseg0_boot_mem             : ORIGIN = 0x9D07E690, LENGTH = 0x970
  exception_mem              : ORIGIN = 0x9D07F000, LENGTH = 0x1000
  kseg1_boot_mem             : ORIGIN = 0xBFC00000, LENGTH = 0x490
  debug_exec_mem             : ORIGIN = 0xBFC02000, LENGTH = 0xFF0
  config3                    : ORIGIN = 0xBFC02FF0, LENGTH = 0x4
  config2                    : ORIGIN = 0xBFC02FF4, LENGTH = 0x4
  config1                    : ORIGIN = 0xBFC02FF8, LENGTH = 0x4
  config0                    : ORIGIN = 0xBFC02FFC, LENGTH = 0x4
  kseg1_data_mem       (w!x) : ORIGIN = 0xA0000000, LENGTH = 0x20000
  sfrs                       : ORIGIN = 0xBF800000, LENGTH = 0x100000
  configsfrs                 : ORIGIN = 0xBFC02FF0, LENGTH = 0x10
 * Configuration-word sections
SECTIONS
  .config_BFC02FF0 : {
    KEEP(*(.config_BFC02FF0))
  } > config3
  .config_BFC02FF4 : {
    KEEP(*(.config_BFC02FF4))
  } > config2
  .config_BFC02FF8 : {
    KEEP(*(.config_BFC02FF8))
  } > config1
  .config_BFC02FFC : {
    KEEP(*(.config_BFC02FFC))
  } > config0
bearing
Re: MPLAB 8 hänger sig (GCC-PIC32)
Inlägg av bearing »
Så du menar att den kompilerar alla filter, men sen blir det något konstigt vid länkningen?
Har du testat att skriva länk-kommandot manuellt i en terminal?
Samma, inget händer, och jag kommer inte tillbaka till kommandotolken
bearing
Inlägg av bearing »
INPUT-raden saknar semikolon, om det har betydelse.
Det är en kopia av det länk-scriptet som normalt används, det som ändrats är minnes-regionerna
Problemet löst, Det var Microchips urdåliga och inkompletta beskrivning som skapade problemet.
Det visade sig att man måste slå ihop bägge länkscript till ett, dels det generiska och dels det processorspecifika scriptet, till ett gemensamt script, vilket placeras i projekt-rooten.
Jag fattade inte detta utan tog bara den processorspecifika delen.
