Re: Arduino 1.8.4 kod
Chaf
Inlägg av Chaf »
Hej :D
Någon som vet hur man tar bort en skissbok ?
M.v.h
Chaf
Chaf
Re: Arduino 1.8.4 felkod för display
Inlägg av Chaf »
Hej :D
Får felmeddelande hjälp.
Kanske någon vill kolla.
M.v.h
Chaf
Arduino:1.8.4 (Windows XP), Kort:"Arduino/Genuino Uno"
sketch_sep03a:20: error: 'NEGATIVE' was not declared in this scope
C:\Documents and Settings\Administratör\Mina dokument\Arduino\sketch_sep03a\sketch_sep03a.ino: In function 'void setup()':
sketch_sep03a:76: error: redefinition of 'void setup()'
C:\Documents and Settings\Administratör\Mina dokument\Arduino\sketch_sep03a\sketch_sep03a.ino:24:6: note: 'void setup()' previously defined here
C:\Documents and Settings\Administratör\Mina dokument\Arduino\sketch_sep03a\sketch_sep03a.ino: In function 'void loop()':
sketch_sep03a:81: error: redefinition of 'void loop()'
C:\Documents and Settings\Administratör\Mina dokument\Arduino\sketch_sep03a\sketch_sep03a.ino:54:6: note: 'void loop()' previously defined here
Multiple libraries were found for "LiquidCrystal_I2C.h"
Använd: C:\Documents and Settings\Administratör\Mina dokument\Arduino\libraries\LiquidCrystal_I2C
Oanvänd: C:\Documents and Settings\Administratör\Mina dokument\Arduino\libraries\jm_LiquidCrystal_I2C
Oanvänd: C:\Documents and Settings\Administratör\Mina dokument\Arduino\libraries\NewliquidCrystal
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
/* YourDuino.com Example Software Sketch
 20 character 4 line I2C Display
 Backpack Interface labelled "LCM1602 IIC  A0 A1 A2"
 terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h>  // Comes with Arduino IDE
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
#include <LiquidCrystal_I2C.h>
/*-----( Declare Constants )-----*/
//none
/*-----( Declare objects )-----*/
// set the LCD address to 0x27 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x20, 4, 5, 6, 0, 1, 2, 3, 7, NEGATIVE);  // Set the LCD I2C address
/*-----( Declare Variables )-----*/
//none
void setup()   /*----( SETUP: RUNS ONCE )----*/
  Serial.begin(9600);  // Used to type in characters
  lcd.begin(20,4);         // initialize the lcd for 20 chars 4 lines
// NOTE: Cursor Position: CHAR, LINE) start at 0
  lcd.setCursor(3,0); //Start at character 4 on line 0
  lcd.print("Hello, world!");
  delay(1000);
  lcd.setCursor(2,1);
  lcd.print("From YourDuino");
  delay(1000);
  lcd.setCursor(0,2);
  lcd.print("20 by 4 Line Display");
  lcd.setCursor(0,3);
  delay(2000);
  lcd.print("http://YourDuino.com");
  delay(8000);
// Wait and then tell user they can start the Serial Monitor and type in characters to
// Display. (Set Serial Monitor option to "No Line Ending")
  lcd.setCursor(0,0); //Start at character 0 on line 0
  lcd.print("Start Serial Monitor");
  lcd.setCursor(0,1);
  lcd.print("Type chars 2 display");
}/*--(end setup )---*/
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
    // when characters arrive over the serial port...
    if (Serial.available()) {
      // wait a bit for the entire message to arrive
      delay(100);
      // clear the screen
      lcd.clear();
      // read all the available characters
      while (Serial.available() > 0) {
        // display each character to the LCD
        lcd.write(Serial.read());
}/* --(end main loop )-- */
/* ( THE END ) */
void setup() {
  // put your setup code here, to run once:
void loop() {
  // put your main code here, to run repeatedly:
RadioDJ
Inlägg av RadioDJ »
Ser direkt 2 fel.
Du har dubbla void setup() och dubbla void loop().
Börja med att ta bort dessa 2 som finns längst ner i din kod.
De är ändå tomma och gör inget.
Det går inte att ha mer än en av varje.
slft
Skype: sm6xwe
Inlägg av slft »
här ser du hur man gjort på ett annat ställe
lite mer lättläst
och jag är ingen programerare!
#include <LiquidCrystal_I2C.h> // F Malpartida's NewLiquidCrystal library
#define I2C_ADDR 0x20 // Define I2C Address for controller
#define BACKLIGHT_PIN 7
#define En_pin 4
#define Rw_pin 5
#define Rs_pin 6
#define D4_pin 0
#define D5_pin 1
#define D6_pin 2
#define D7_pin 3
#define LED_OFF 0
#define LED_ON 1
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
//Ola
Chaf
Re: Arduino 1.8.4 kod för display
Inlägg av Chaf »
Hej :D
Håller på och pillrar med kod behöver lite hjälp.
Skulle vilja att den börjar om i stället för att stanna
efter sista raden.
M.v.h
Chaf
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
void setup()
  lcd.init();                      // initialize the lcd
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(3, 0);
  lcd.print("Christer Farman");
  lcd.setCursor(3, 1);
  lcd.print("Bohusgatan 19");
  lcd.setCursor(2, 2);
  lcd.print("116 67 Stockholm");
  lcd.setCursor(1, 3);
  lcd.print("email chaf@live.se");
  delay(3000);
  int blinkantal = 8;
  lcd.clear();
  lcd.setCursor(2, 0); //Start at character 0 on line 0
  lcd.print("Telnr 0707768816");
  delay(1000);
  lcd.setCursor(0, 1);
  lcd.print("Stockholm makerspace");
  delay(1000);
  lcd.setCursor(1, 2);
  lcd.print("Fungerar bra kul! ");
  delay(1000);
  lcd.print("Elektronikforumet");
  delay(3000);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(8,0);
  delay(200);
  lcd.print("Hej");
void loop()
kodar-holger
Inlägg av kodar-holger »
Lägg den kod som skall köras om och om igen i loop istället för i setup. Det är det dom är till för.
void setup()
//Koden här körs en gång
void loop()
//Koden här körs gång på gång på gång på gån gpå gå ngpå....
Chaf
Inlägg av Chaf »
Hej
Provade att byta första void setup mot void lloop
M.v.h
Chaf
felmeddelande
C:\arduino\Christer2\Christer2.ino: In function 'void loop()':
Christer2:50: error: redefinition of 'void loop()'
void loop()
C:\arduino\Christer2\Christer2.ino:6:6: note: 'void loop()' previously defined here
void loop()
Använd: C:\arduino\libraries\LiquidCrystal_I2C
Oanvänd: C:\arduino\libraries\jm_LiquidCrystal_I2C
Oanvänd: C:\arduino\libraries\fmalpartida-new-liquidcrystal-f0ec1a56eac5
exit status 1
rvl
Inlägg av rvl »
Lämna kvar de första radern fram till ...backlight() i setup() och klipp och klistra resten till loop(). Antar att både setup() och loop() är nåt Arduino mer eller mindre kräver, eftersom de finns färdigt i en "tom" sketch.
Chaf
Inlägg av Chaf »
Hej
provat om det var så du menade felmeddelande
Chaf
Christer2:8: error: expected unqualified-id before '{' token
exit status 1
#include <Wire.h>
//void setup()
  lcd.init();
  void loop()
  lcd.backlight();
  delay(3000);
  int blinkantal = 8;
  lcd.clear();
  delay(1000);
  delay(1000);
  delay(1000);
  delay(3000);
  lcd.init();
  lcd.backlight();
  delay(200);
  lcd.setCursor(8,0);
  lcd.print("Hej");
ffredrik
Inlägg av ffredrik »
Om du lär dig lite rudimentär C så kanske det går bättre.
nifelheim
Den första
Inlägg av nifelheim »
du har kommenterat bort setup
//void setup()
kolla vad kodar-holger skrev,
du ska inte ha loop() inne i setup()
Chaf
Inlägg av Chaf »
Hej :D
Provar lite enklare kod hjälper inte får felmeddelande.
ger snart upp.
M.v.h
Chaf
C:\arduino\sketch_sep10a\sketch_sep10a.ino: In function 'void loop()':
sketch_sep10a:9: error: 'lcd' was not declared in this scope
exit status 1
void setup()
 #include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);  // put your setup code here, to run once:
void loop()
  lcd.init();
  lcd.backlight();
  lcd.print("Christer Farman");// put your main code here, to run repeatedly:
hawkan
Inlägg av hawkan »
Prova
#include <Wire.h>
void setup()
void loop()
  lcd.backlight();
Chaf
Inlägg av Chaf »
Hej
Provade men den stannade vill att den börja om igen automatiskt.
Måste väl fungera på något sätt ?
M.v.h
Chaf
rvl
Inlägg av rvl »
Chaf skrev:Hej
Nja om vi utgår från att den ursprungliga koden fungerade, så var väl ungefär såhär jag menade:
#include <Wire.h>
void setup()
  lcd.backlight();
void loop()
  //börja loopen med tom display
  lcd.init();  // kanske fungerar med lcd.clear(); här istället, ifall det finns i det använda biblioteket
  delay(3000);
  int blinkantal = 8;
  lcd.clear();
  delay(1000);
  delay(1000);
  delay(1000);
  delay(3000);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(8,0);
  delay(200);
  lcd.print("Hej");
  delay(1000);  //en extra delay innan vi börjar om
