Rätt impad av moderna hårddiskar
Bytte diskar i min hemmaburk i helgen.
Är rätt imponerad av SMART-Data så här 7 år senare och ca 40K driftstimmar.
WDC WD50 00AAKS-00YGA0 SATA Disk Device
Manufacturer	Western Digital
Business Unit/Brand	Desktop/WD Caviar
RPM/Buffer Size or Attribute	7200 RPM with 16 MB cache
Interface/Connector	SATA 3 Gb/s with 22-pin SATA connector/SATA 1.5 Gb/s with 22-pin SATA connector (Mobile)
Heads	16
Cylinders	60 801
Tracks	15 504 255
Sectors	976 768 065
SATA type	SATA-II 3.0Gb/s
Device type	Fixed
ATA Standard	ATA8-ACS
Serial Number	WD-WCAS80912846
Firmware Version Number	12.01C02
LBA Size	48-bit LBA
Power On Count	10782 times
Power On Time	1658,4 days
Speed	7200 RPM
Features	S.M.A.R.T., AAM, NCQ
Max. Transfer Mode	SATA II 3.0Gb/s
Used Transfer Mode	SATA II 3.0Gb/s
Interface	SATA
Capacity	465 GB
Real size	500 107 862 016 bytes
RAID Type	None
S.M.A.R.T
Status	Good
Temperature	37 °C
Temperature Range	OK (less than 50 °C)
S.M.A.R.T attributes
	Attribute name				Real value	  Current	Worst	Threshold	Raw Value	        Status
01 Read Error Rate				0		  200	        200	        51		0000000000	Good
03 Spin-Up Time				6233 ms	  175	        172	        21		0000001859	Good
04 Start/Stop Count				10 873	  90	        90	        0		0000002A79	Good
05 Reallocated Sectors Count			0		200	200	140		0000000000	Good
07 Seek Error Rate				0		100	253	51		0000000000	Good
09 Power-On Hours (POH)				1658d 10h	46	46	0		0000009B7A	Good
0A Spin Retry Count				0		100	100	51		0000000000	Good
0B Recalibration Retries			0		100	100	51		0000000000	Good
0C Device Power Cycle Count			10 782		90	90	0		0000002A1E	Good
C0 Power-off Retract Count			9 659		188	188	0		00000025BB	Good
C1 Load/Unload Cycle Count			10 873		197	197	0		0000002A79	Good
C2 Temperature					37 °C		113	111	0		0000000025	Good
C4 Reallocation Event Count			0		200	200	0		0000000000	Good
C5 Current Pending Sector Count			0		200	200	0		0000000000	Good
C6 Uncorrectable Sector Count			0		200	200	0		0000000000	Good
C7 UltraDMA CRC Error Count			2		200	200	0		0000000002	Good
C8 Write Error Rate / Multi-Zone Error Rate	0		200	200	51		0000000000	Good
Varför i h funkar inte formateringen i kode-taggen
MadModder
Re: Rätt impad av moderna hårddiskar
Inlägg av MadModder »
För att TAB översätts till ett bestämt antal mellanslag.
Och hur många mellanslag?
MadModder
Jag vet inte. 4-5st kanske? Du får väl prova. ;)
Men det är ju lite knepigt att få till, för man kan ju skriva ända in till 1 tecken före nästa tabläge utan att texten efter hoppar fram, och då motsvarar ju en tab olika många mellanslag...
[edit]
	A
A	A
AA	A
AAA	A
I själva redigeringsrutan finns tabbarna med hela tiden, och mina högra "A" står i en perfekt rak kolumn, men när de skrivs ut är varje TAB tre (3) mellanslag.
janaf
Inlägg av janaf »
Ja, imponerande driftsdata!
bearing
Inlägg av bearing »
Angående tabbar
Jag brukar använda ett gammalt program som heter "Crimson Editor" för att konvertera tabb-intenderad text till mellanslags-intenderad. Den konverterar på ett "intelligent" sätt, så att texten ser exakt lika ut efter operationen. Notepad++, och diverse online-program gör bara en "dum" översättning till ett fast antal space.
Före:
A	B	C
10	20	30
Efter Crimson editor:
A   B   C
10  20  30
Efter Notepad++:
A    B    C
10    20    30
sebastiannielsen
Inlägg av sebastiannielsen »
C7 var ändå inte bra tycker jag.
Man kan inte, IMHO, lita på bedömningen som SMART-systemet gör själv (t.ex. OK eller liknande), utan man måste manuellt titta på raw-värderna och avgöra om de är vettiga.
Om raw-värderna är osannolikt höga (typ som värden 4294967296) kan det bero på att hårddisktillverkaren har sitt egna sätt att koda värdet.
Hade jag haft den disken så hade jag i alla fall inte lagrat något viktigt på den. Den har börjat gå sönder, det är bara frågan om när disken packar ihop och går hem.
Men annars har den disken hängt med länge utan några nämnvärda fel.
hyperion
Inlägg av hyperion »
Tack Bearing för tipset! Crimson Editor är numera installerat och kommer användas för allt mer avancerat än inköpslistor :)
Ang. hårddiskstatistik så håller jag med, det är imponerande. Tyvärr kan inte jag kolla liknande statistik då jag sedan 2010 kört 4st 60GB SSD i raid 0 som systemdisk. Jo jag vet, raid 0, men jag har ingenting på C: som är viktigt utan både lokal och molnbaserad backup. Försöker hitta en printscreen av ett benchmark-test jag körde då 2010 som visar läshastigheter precis över 1000MB/s och skrivhastigheter som var lite drygt 500MB/s om jag kommer ihåg rätt. Men hittar inte den bilden så. Dock väldigt förvånad över att datorn fortfarande funkar så bra som den gör även om det ska köpas ny så fort som möjligt :)
xxargs
Inlägg av xxargs »
C7 har inte med HD-ytans avläsning eller tveksamhet i avläsning där utan i kontakten/överföringen och DMA-hantering mellan HD och och tex. moderkort/diskkontrollern - det räcker att ruska om kablarna under drift och kontakterna rör sig i hållaren eller extern störning utifrån (tex. åskblixt), alternativ att DMA-hanteringen inte fungerade riktigt som tänkt, så kan det bli fel - det viktiga är att felet upptäcks och det görs en omläsning och inte går in vidare i någon fil oupptäckt.
Två fel ackumulerad på typ 5 år är inget att orda om och ingen vet när dessa inträffade heller - det kan vara i samband med installationen av nya disken likväl som igår.
börjar däremot antalet reallokerade sektorer att röra på sig med stigande antal, speciellt om de hoppar iväg efter en datascrubbing (alla sektorer på disken läses av från början till slut med typ 'dd if=/dev/sda of=/dev/null bs=1024k' i linuxsystem, vilket bör göras minst 1 ggr per år för mekaniska diskar) plötsligt och på kort tid så är det nog dags...
När det gäller SSD vet jag inte om datascrubbing behövs eller om det räcker att den är strömsatt då och då (minst var tredje månad) för att felrättning av sämre sektorer skall kontrolleras och uppdateras automagiskt. Men det är samma där att om sektor reallokering count börja röra sig uppåt och wear-levling count är hög (uppåt 1000 för 3-nivåers-minnesceller) så är man i end of life-sidan av SSD-disken
