Fundamentals of Electronic Devices and Circuits - Bra bok?
4kTRB
Inlägg av 4kTRB »
Jag har inte hittat några kommentarer om den här boken och
undrar om någon här kanske har läst i den?
David A Bell
1000 sidor tjock
Innehåll:
  • PREFACE; 1. Basic Semiconductor and pn-Junction Theory; 2. Semiconductor Diodes; 3. Diode Applications; 4. Bipolar Junction Transistors; 5. BJT Biasing; 6. AC Analysis of BJT Cicruits; 7. Semiconductor Device and IC Fabrication; 8. Transistor Specifications and Performance; 9. Field Effect Transistors; 10. FET Biasing; 11. AC Analysis of FET Circuits; 12. Small Signal Amplifiers; 13. Amplifiers with Negative Feedback; 14. IC Operational Amplifiers and Basic Op-amp Circuits; 15. Operational Amplifier Frequency Response and Compensation; 16. Signal Generators; 17. Active Filters; 18. Linear Switching Voltage Regulators; 19. Audio Power Amplifiers; 20. Thyristors; 21. Optoelectronic Devices; 22. Miscellaneous Devices; APPENDICES; INDEX
    (Oxford)
http://www.bokus.com/bok/9780195425239/ ... -circuits/
