Koden är en CRC32 Calculator
Public Function GetCRC32(ByVal sFileName As String) As String
Try
Dim FS As FileStream = New FileStream(sFileName, FileMode.Open, FileAccess.Read, FileShare.Read, 8192)
Dim CRC32Result As Integer = &HFFFFFFFF
Dim Buffer(4096) As Byte
Dim ReadSize As Integer = 4096
Dim Count As Integer = FS.Read(Buffer, 0, ReadSize)
Dim CRC32Table(256) As Integer
Dim DWPolynomial As Integer = &HEDB88320
Dim DWCRC As Integer
Dim i As Integer, j As Integer, n As Integer
'Create CRC32 Table
For i = 0 To 255
ProgressBar1.Value = i
DWCRC = i
For j = 8 To 1 Step -1
If (DWCRC And 1) Then
DWCRC = ((DWCRC And &HFFFFFFFE) \ 2&) And &H7FFFFFFF
DWCRC = DWCRC Xor DWPolynomial
Else
End If
Next j
CRC32Table(i) = DWCRC
Next i
'Calcualting CRC32 Hash
Do While (Count > 0)
For i = 0 To Count - 1
n = (CRC32Result And &HFF) Xor Buffer(i)
CRC32Result = ((CRC32Result And &HFFFFFF00) \ &H100) And &HFFFFFF
CRC32Result = CRC32Result Xor CRC32Table(n)
Next i
Count = FS.Read(Buffer, 0, ReadSize)
Loop
Return Hex(Not (CRC32Result))
Catch ex As Exception
Return ""
End Try
End Function
