3fas PWM med arduino
Tekko
Inlägg av Tekko »
Då jag e helt grön och inte vet vad jag ska söka på så ställer jag frågan här:
Hur får man till 3st 120 grader från varann faser ut, altså det är 3st sinusar efter filtrering jag menar, vad ändrar/lägger man till i denna kod ?
#include "avr/pgmspace.h"
// table of 256 sine values / one sine period / stored in flash memory
PROGMEM  prog_uchar sine256[]  = {
  127,130,133,136,139,143,146,149,152,155,158,161,164,167,170,173,176,178,181,184,187,190,192,195,198,200,203,205,208,210,212,215,217,219,221,223,225,227,229,231,233,234,236,238,239,240,
  242,243,244,245,247,248,249,249,250,251,252,252,253,253,253,254,254,254,254,254,254,254,253,253,253,252,252,251,250,249,249,248,247,245,244,243,242,240,239,238,236,234,233,231,229,227,225,223,
  221,219,217,215,212,210,208,205,203,200,198,195,192,190,187,184,181,178,176,173,170,167,164,161,158,155,152,149,146,143,139,136,133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,87,84,81,78,
  76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,11,12,14,15,16,18,20,21,23,25,27,29,31,
  33,35,37,39,42,44,46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,99,102,105,108,111,115,118,121,124
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
int ledPin = 13;                 // LED pin 7
int testPin = 7;
int t2Pin = 6;
byte bb;
double dfreq;
// const double refclk=64000;  // =16MHz / 250
const double refclk=64000;      // measured
// variables used inside interrupt service declared as voilatile
volatile byte icnt;              // var inside interrupt
volatile byte icnt1;             // var inside interrupt
volatile byte c4ms;              // counter incremented all 4ms
volatile unsigned long phaccu;   // pahse accumulator
volatile unsigned long tword_m;  // dds tuning word m
void setup()
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  Serial.begin(115200);        // connect to the serial port
  Serial.println("DDS Test");
  pinMode(6, OUTPUT);      // sets the digital pin as output
  pinMode(7, OUTPUT);      // sets the digital pin as output
  pinMode(11, OUTPUT);     // pin11= PWM  output / frequency output
  pinMode(12, OUTPUT);     // pin12= PWM  output / frequency output +120
  pinMode(13, OUTPUT);     // pin13= PWM  output / frequency output +240
  Setup_timer2();
  // disable interrupts to avoid timing distortion
  cbi (TIMSK0,TOIE0);              // disable Timer0 !!! delay() is now not available
  sbi (TIMSK2,TOIE2);              // enable Timer2 Interrupt
  dfreq=1000.0;                    // initial output frequency = 1000.o Hz
  tword_m=pow(2,32)*dfreq/refclk;  // calulate DDS new tuning word
void loop()
  while(1) {
     if (c4ms > 250) {                 // timer / wait fou a full second
      c4ms=0;
      dfreq=analogRead(0);             // read Poti on analog pin 0 to adjust output frequency from 0..1023 Hz
      cbi (TIMSK2,TOIE2);              // disble Timer2 Interrupt
      Serial.print(dfreq);
      Serial.print("  ");
      Serial.println(tword_m);
   sbi(PORTD,6); // Test / set PORTD,7 high to observe timing with a scope
   cbi(PORTD,6); // Test /reset PORTD,7 high to observe timing with a scope
// timer2 setup
// set prscaler to 1, PWM mode to phase correct PWM,  16000000/250 = 64000 Hz clock
void Setup_timer2() {
// Timer2 Clock Prescaler to : 1
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
  // Timer2 PWM Mode set to Phase Correct PWM
  cbi (TCCR2A, COM2A0);  // clear Compare Match
  sbi (TCCR2A, COM2A1);
  sbi (TCCR2A, WGM20);  // Mode 1  / Phase Correct PWM
  cbi (TCCR2A, WGM21);
  cbi (TCCR2B, WGM22);
// Timer2 Interrupt Service at 64000 Hz = 15.625uSec
// this is the timebase REFCLOCK for the DDS generator
// FOUT = (M (REFCLK)) / (2 exp 32)
// runtime : 8 microseconds ( inclusive push and pop)
ISR(TIMER2_OVF_vect) {
  sbi(PORTD,7);          // Test / set PORTD,7 high to observe timing with a oscope
  phaccu=phaccu+tword_m; // soft DDS, phase accu with 32 bits
  icnt=phaccu >> 24;     // use upper 8 bits for phase accu as frequency information
                         // read value fron ROM sine table and send to PWM DAC
  OCR2A=pgm_read_byte_near(sine256 + icnt);
  if(icnt1++ == 125) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icnt1=0;
 cbi(PORTD,7);            // reset PORTD,7
Re: 3fas PWM med arduino
Kanske detta kan vägleda, sökte med google
http://www.arduino.cc/cgi-bin/yabb2/YaB ... 1244372691
Tekko
Inlägg av Tekko »
Det där är en vanlig 6-stegs trapetzoid drift vilket EJ är det jag söker.
"I princip" är det en tabell med sinus-värden och tre pekare
som ligger med 120 graders förskjutning i tabellen. Sedan läser
du ut värden till utgångarna på lämpligt sätt (d.v.s "som vanligt").
Så skillnaden mot en lösning med en sinus är tre pekare istället för en.
Tekko
Inlägg av Tekko »
Jag antar då att detta är pekaren i detta fallet
    c4ms++;
    icnt1=0;
Tekko
Inlägg av Tekko »
Verkár detta vettigt ? Tog höfsta värdet i sine lookup tabellen och delade med 3.
OCR1A=pgm_read_byte_near(sine256 + icnt);
    c4ms++;
    icnt1=0;
  if(icnt2++ == 125) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icnt2=84;
OCR3A=pgm_read_byte_near(sine256 + icnt);
  if(icnt3++ == 125) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icnt3=170;
Nejm, dete tror jag inte.
icnt1 är väl till för att få rätt *frekvens*.
Du behöver 3 st icnt.
(Skit variabelnamn dessutom).
Sen så framgår det ju inte vad de andra prylarna är.
T.ex:
sin256 (sannolikt startadressen för sinus-tabellen).
icnt (sannolikt pekaren in i sinus-tabellen, den du behöver tre av).
icnt1 (sannolikt en räknare för att få 4 ms intervall, borde fortfarande endast behövas en).
c4ms (inte en susning vad den är till för...).
Tekko
Inlägg av Tekko »
Nåt sånnt här kanske:
  if(icntl++ == 0) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icntl=0;
OCR1B=pgm_read_byte_near(sine256 + icnt);
  if(icntl++ == 84) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icntl=0;
  if(icntl++ == 170) {  // increment variable c4ms all 4 milliseconds
    c4ms++;
    icntl=0;
Nej, det ger tre signaler med 3 olika frekvens, det var
väl inte det du skulle ha ? Om jag fattar koden rätt...
Snarare något i denna stil (ungefär, om jag har förstått koden rätt, som sagt) :
OCR1A=pgm_read_byte_near(sine256 + icnt_1);
OCR1B=pgm_read_byte_near(sine256 + icnt_2);
OCR2A=pgm_read_byte_near(sine256 + icnt_3);
    c4ms++;
    icntl=0;
icnt_1 - icnt_3 ska initialiseras någonstans innan denna kod för att
få rätt fasförhållande. Kanske med 0, 84 resp 170. Se det som tre pekare
som pekar på var sitt ställe i tabellen med samma intervall hela tiden.
Sedan så måste icnt_1 - icnt_3 också jämföras med "slut-av-tabellen"
(sannolikt sine256+256) så att de kan ställas tillbaka till början igen.
Det verkar också göras någon annanstans.
Tekko
Inlägg av Tekko »
OK. så icnt är en "byte" och kan så klart bara adressera 256 bytes i tabellen.
Den "wrap around" med automatik, så att säga.
*Kanske* något i denna stil, du får testa själv :
volatile byte icnt_1;            // var inside interrupt
volatile byte icnt_2;            // var inside interrupt
volatile byte icnt_3;            // var inside interrupt
  icnt_1=phaccu     >> 24;     // use upper 8 bits for phase accu as frequency information
  icnt_2=phaccu+84  >> 24;     // use upper 8 bits for phase accu as frequency information
  icnt_3=phaccu+170 >> 24;     // use upper 8 bits for phase accu as frequency information
Tekko
Inlägg av Tekko »
Med det avklarat, nu e bara frågan hur man adresserar dessa till varsin utgångsport, eller sker det per automatik ?
int testPin = 7;
int t2Pin = 6;
byte bb;
double dfreq;
volatile unsigned long phaccu;   // phase accumulator
void setup()
  Setup_timer2();
  dfreq=1000.0;                    // initial output frequency = 1000.0 Hz
void loop()
  while(1) {
      c4ms=0;
      Serial.print("  ");
// timer2 setup
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
    c4ms++;
    icnt1=0;
> Med det avklarat,
Hur kan du vara så säkert på att det är avklarat ?
Det är rena gissningar från min sida som du måste verifiera.
Det finns dokumentation som tar upp dom detaljerna.
Tekko
Inlägg av Tekko »
Nu fattas bara att skaffa hem en Arduino Duemilanove, brassa in koden å se om skiten funkar.
Koden kompilerar iaf utan fel:
int testPin = 7;
int t2Pin = 6;
byte bb;
double dfreq;
volatile byte U;             // var inside interrupt
volatile byte V;             // var inside interrupt
volatile byte W;             // var inside interrupt
const int phaseout = 11;
const int phaseout2 = 12;
const int phaseout3 = 13;
void setup()
  pinMode(phaseout, OUTPUT);     // pin11= PWM  output / frequency output U
  pinMode(phaseout2, OUTPUT);    // pin12= PWM  output / frequency output V
  pinMode(phaseout3, OUTPUT);    // pin13= PWM  output / frequency output W
  Setup_timer2();
void loop()
  while(1) {
      c4ms=0;
      Serial.print("  ");
// three phase PWM outputs
for (int OCR1A; OCR1B; OCR2A) {
analogWrite(phaseout, OCR1A); (phaseout2, OCR1B); (phaseout3, OCR2A);
// timer2 setup
  sbi (TCCR2B, CS20);
  cbi (TCCR2B, CS21);
  cbi (TCCR2B, CS22);
  U=phaccu >> 24;     // use upper 8 bits for phase accu as frequency information
  V=phaccu+84 >> 24;    // use upper 8 bits for phase accu as frequency information
  W=phaccu+170 >> 24;   // use upper 8 bits for phase accu as frequency information
OCR1A=pgm_read_byte_near(sine256 + U);
OCR1B=pgm_read_byte_near(sine256 + V);
OCR2A=pgm_read_byte_near(sine256 + W);
    c4ms++;
    icnt1=0;
Jag antar att det är de OCRxA/B som representerar PWM utgångarna.
