BlackBoard Breadboard Designer (Open Source)
Ronny
Inlägg av Ronny »
Ännu ett program för de som är intresserade av att bygga elektronik på experimentkort (Stripboard, Veroboard)
Bilder på ingående byggblock (Gerd Bartelt)
lgrfbs
Re: BlackBoard Breadboard Designer (Open Source)
Inlägg av lgrfbs »
Det där ser ju trevligt ut.
Ronny
Inlägg av Ronny »
Ny version (0.18) finns att hämta.
Gorgus
Inlägg av Gorgus »
0.18 kräver tydligen Java 7...
Ronny
Inlägg av Ronny »
BlackBoard Breadboard Designer - News
"1.0beta3" heter den version jag installerade för ett par månader sedan.
En hel del förbättringar i den jämfört med den tidigare versionen.
Changelog info
Version 0.01
First experimental version
Version 0.1
First usable version
Undo/Redo system works now
Version 0.11
Changed resource loading to ClassLoader.getSystemClassLoader()
Version 0.12
Adding lines is now undoable
Changed raster size to be more precise
Rotating parts can now be done from the menu too.
Rotating parts is now undoable
Improved precision when drawing lines
Version 0.13
Parts can no be switched to transparent
Added splash image to about dialog
Board may now have two different types : STRIPES, HOLES
Board size and type can now be specified
New part type : "break" for stripe layouts
Version 0.14
Color for lines is now chooseable
Line color can now be changed
Missing xml extension for files is now automatically added
Missing parts are shown as quotation marks both in browser and on the board
Parts have now an author and a license
Parts can now be reordered from front to back and vice versa
Fixed wrong display of dirty flag when restoring open views
Selection borders and handles are now always drawn on top
Changed background of part preview to lightgray for better viewing
Raster is now adjustable
Version 0.15
Fixed missing z-index for parts when opening a board
Added new board type "blank"
Added new text part type
Changed order of some items
Toggle snap to grid is now reachable from all menus
Added separators to ApplicationMenubarProvider and ApplicationToolbarProvider
Version 0.16
Text color is now changeable
Parts may now be moved by cursor keys
Added part preloading for part browser
Properties of all objects are now changeable
Added value display of parts
Added basic CSV partlist export
Commands are now enabled/disabled depending on the editor state
Tab windows are now minimizable/maximizable
Version 0.17
Added designator function when adding parts
Fixed nasty bug when creating new boards while an untitled dirty editor is open
Fixed problem with opening boards which contain empty parts
Added basic preferences system
Visibility of part names can now be toggled.
Files are now stored in a packed way
Added user definable board type
Version 0.18
Improved selection behaviour
Improved snap behaviour
Added user definable layers.
Board properties may now be changed at any time
Change all single key commands to ALT-modifier
Made editor zoomable
Made size for board switchable between pixels and mm
Added changeable line types and thickness
Opacity of layers is now adjustable
Fixed bug : strange snap behaviour, when moving different types of items.
Changed UI for layers view
Added datasheet browser
Sorting preferences alphabetically
Fixed some minor copy and paste bugs
Added confirmation dialog if saving to an existing file
Board is now mirrorable
Added primitive drawing: box and ellipse
Drawings can now be converted to parts and be reused
Version 1.0
Extracted layer behaviour to command pattern
Extracted string resources to make them translatable
Added german translation
Changed resistor appeareance
Fixed maximized window state problem under Windows Vista/7
Added new line styles
Replaced Ellipse with Arc and made angles configurable
Fixed build problem for Java 6
Added Pixel-O-Mat tool for primitive pixel drawings
Lines, Ellipses and Boxes may now be combined/uncombined as symbols
Shape properties like color, outline and line style may now be changed at any time
Fixed wrong calculation of bounding box, when text is being rotated
BlackBoard reminds now the folder last saved to and loaded from
Added backside solder pin render, when board is mirrored
Added symbol library with draggable symbols
Fixed bug : bad snap behaviour (fw)
Fixed bug : wrong behavior of Save As command when cancelled
AddTextCommand reminds now last selected font and takes care of the mouse position
Enabled default language
Changed several hotkeys due to menu translation mechanism
Made item, line and symbol movements undoable/redoable
Each editor has now its own undo history
Added mouse coordinate display at the status bar
Fixed bug : Impossible to move resistors from a recently opened board
Editor switches now automatically to select mode if items are inserted or copied
Symbols can now be automatically labelled when inserting, for that a symbol must contain textparts starting with #
Paste command is undoable
Mouse wheel zooming can now be inverted
Parts are added now to the default parts layer if it still exists.
Editor mode defaults to select
Layers now have a color, the user can choose if the layers colors should be used for drawing on that layer or not.
Fixed bug : Wrong setting of designators when copying items.
PHermansson
Inlägg av PHermansson »
Tack för tipset, var precis på jakt efter ett sånt program! :)
