Vinn boken "15 Dangerously Mad Projects for the Evil Genius"
4kTRB
Inlägg av 4kTRB »
Möjlighet att vinna boken "15 Dangerously Mad Projects for the Evil Genius"
Det är väl så många börjar sin elektronikbana.
Hur det slutar vet jag inte.
http://www.mhprofessional.ca/win/i/9780071755672/
PeterH
Re: Vinn boken "15 Dangerously Mad Projects for the Evil Gen
Inlägg av PeterH »
Men det verkar som du får flytta till USA,Canada eller England om du vill vara med... Och så måste du vara över 18 år.
4kTRB
Inlägg av 4kTRB »
Läste reglerna för dåligt.
Jaha tur man inte bor i Kanada t.ex.
jesse
Inlägg av jesse »
Eller kanske den här boken kan vara bra? :D
Arduino + Android Projects for the Evil Genius: Control Arduino with Your Smartphone or Tablet
Dom har visst ett helt gäng böcker för "the Evil Genius". :mrgreen:
EDIT: menade denna:
30 Arduino Projects for the Evil Genius
Description :
30 Ways to Have Some Computer-Controlled Evil Fun!
This wickedly inventive guide shows you how to program and build a variety of projects with the Arduino microcontroller development system. Covering Windows, Mac, and Linux platforms, 30 Arduino Projects for the Evil Genius gets you up to speed with the simplified C programming you need to know--no prior programming experience necessary.
Using easy-to-find components and equipment, this do-it-yourself book explains how to attach an Arduino board to your computer, program it, and connect electronics to it to create fiendishly fun projects. The only limit is your imagination!
30 Arduino Projects for the Evil Genius:
Features step-by-step instructions and helpful illustrations
Provides full schematic and construction details for every project
Covers the scientific principles behind the projects
Removes the frustration factor--all required parts are listed along with sources
Build these and other devious devices:
Morse code translator
High-powered strobe light
Seasonal affective disorder light
LED dice
Keypad security code
Pulse rate monitor
USB temperature logger
Oscilloscope
Light harp
LCD thermostat
Computer-controlled fan
Hypnotizer
Servo-controlled laser
Lie detector
Magnetic door lock
Infrared remote
Table of Contents :
Introduction;
Chapter 1. Quickstart;
Chapter 2. A Tour of Arduino;
Chapter 3. LED Projects;
Chapter 4. More LED Projects;
Chapter 5. Sensor Projects;
Chapter 6. Light Projects;
Chapter 7. Sound Projects;
Chapter 8. Power Projects;
Chapter 9. Miscellaneous Projects;
Chapter 10. Your Projects;
Appendix: Components and Supplies
PHermansson
Inlägg av PHermansson »
Den om Arduino och Android lät oneligen spännande, men hur tolkas "© 2012 | 1st Edition | 256 pages , Softcover"?
jesse
Inlägg av jesse »
softcover betyder att omslaget består av mjukvara. 2012 betyder att det var då författaren skrev boken. (Han skrev även boken om hur man bygger en maskin som böjer universum så du kan hamna i en timewarp)
nole
Inlägg av nole »
Status: In Process, Editorial kanske kan bringa lite ljus över frågeställningen :)
