här hittade jag ett hack som gör att man kan programmera AVR32 enheter från FLIP's GUI.
Some how by default AVR32 devices not appear in device list in Flip 3.4.2 so only BatchIsp supposed to be used. I found way to hack it.
Go to:
C:\Program Files (x86)\Atmel\Flip 3.4.2\bin\PartDescriptionFiles
Make copy of AT32UC3B0256.xml (this is in my case, EVK1101).
Rename it to something >not< starting with "AT32UC". In my case I made it to mAT32UC3B0256.xml
Voila, now it appears in device list and working fine through USB on Windows 7 x64 :)
KostyaOch så ska man i filen lägga till
<Gui FILE="at90usb1287_gui.xml" />Att filen är för AT90usb1287 spelar ingen roll då denna inte har något med programmeringen att göra.
NAMN: mAT32UC3A0512 (Kopiera inte denna rad!)
<?xml version="1.0"?>
<!DOCTYPE Part SYSTEM "part.dtd">
<Part NAME="AT32UC3A0512">
<USB_PID VALUE="2FF8" />
<Memory NAME="FLASH" SIZE="524288" ADDR="80000000" />
<Memory NAME="BOOTLOADER" SIZE="3" INDEX="3"/>
<Memory NAME="SIGNATURE" SIZE="4" INDEX="6"/>
<Memory NAME="SECURITY" SIZE="1" />
<Memory NAME="CONFIGURATION" SIZE="32" />
<Memory NAME="USER" SIZE="512" ADDR="80800000" INDEX="11" />
<Memory NAME="INT_RAM" SIZE="65536" ADDR="0" INDEX="20" />
<!-- EXT_RAM memories are too large (>= 16Mbyte) to create a buffer; we declare a 0-byte size for them.
We program them during the ELF parsing process. -->
<Memory NAME="EXT_MEM_CS0" SIZE="0" ADDR="C0000000" />
<Memory NAME="EXT_MEM_CS1" SIZE="0" ADDR="D0000000" />
<Memory NAME="EXT_MEM_CS2" SIZE="0" ADDR="C8000000" />
<Memory NAME="EXT_MEM_CS3" SIZE="0" ADDR="CC000000" />
<Memory NAME="EXT_MEM_DF" SIZE="8388608" ADDR="0" INDEX="30" />
<Protocol FILE="USB_DFU_02.xml" />
<Protocol FILE="RS232_I02.xml" />
</Part>
Enyoy!
FLIP
AVR32
