machine fire safety. a word of warning.
Hej alla 'fräsare'
Nedan ett klipp från en tråd på Yahoo Mach forumet, en liten uppmaning i all välmening att inte lämna maskiner obevakade!
There are a lot of us that trust mach and our machines enough to leave them onovernight or leave them running while we go get a cup of tea.yesterday i was machining a job in oak. luckily for the first time so i didntleave it!i use diamond (pcd) spiral cutters for all my cutout workthese have the tips added to the steel shank of the cutter.(in the same way a carbide tool can have the tips brazed on)anyway, on the last job the tool had pinged a corner lump off some oak and ididnt realise had lost a tip. effectively this turned the tool into a highfriction grinding bar instead of a cutter!the tool entered the job and tried its best to burn its way through. in secondsthe workshop was full of smoke! the oak was smouldering bright red as were thechippings around it, being fanned by the spindle cooling air. im pretty surethere would have been some well kindled flames if i wasnt there.so the moral...... Dont leave it un attended.i caught the act on video. you can see how quick this can happen. shame i didnt carry on filming i was too busy snuffing out the smoulderings if i had my extractor on all the hot stuff would have been in my dust bag
mrfrenzy
Re: machine fire safety. a word of warning.
Inlägg av mrfrenzy »
En brandvarnare kan ju vara bra att ha i alla fall, den hade snart löst på den där röken.
Tar man en centralkopplad detektor kan man ju låta den lösa ut nödstoppet på maskinen (men det hjälper ju inte om det redan börjat brinna).
Det tar jag för givet att alla har i sina mek utrymmen oavsett vad man pysslar med.
Visst kan det vara OK med att att lösa ut nödstopp men det lär ju inte hjälpa om Mr Murphy redan har tuttat på.
