http://www.photonlexicon.com/forums/sho ... ware-to-go...
Hi, im selling the following stuff:
Dt-25 set (brand new, never installed in a projector, never used)
Optical Scan Angle 60 Degrees Max
Scan Speed 25Kpps at 8 Degrees
20Kpps at 8 Degrees with larger mirrors
Mirror Type Dielectric Mirrors >95 Reflectivity at 400nm-700nm
Input Signal Differential or Single Ended
Power Requirements 110V-220VAC
2 x 3-axis adjustable Plain front mounts for HR mirror or PBS cube
1 x 3-axis adjustable 15 mm dichro mount with RGB dichro inside
(reflect red transmit green & blue R>99% TG>93% TB>95%)
1 x Red PBS cube 15x15mm (forgot to include it in the photo)
2 x Dichro mount fitting kits from laser wave
2 x First surface mirrors 10x10mm
2 x Round diode housings from laser wave, 1 of them has a a red dvd diode fitted.
1 x aluminium mount for those round modules, machined by me, could be used to build a dual red setup.
1 x switch with a key
Now i dont know if anyone would be interested but i have a scanpro 20 set which is missing galvos, so there are drivers and PSU.
Also have a 150mw 532 nm DPSS, i dont know what make that is, it works perfectly my friend got a measure of 168mw.
Ok i hope i mentioned everything. I would like to get 250 of english money for the lot which i think is flaming bargain
Picture quality is not great but my camera died for some reason so have to use my phone..
