Gps + hyperterminal = konstiga tecken
Christian
Inlägg av Christian »
Har köpt en EM-411 gps-mottagare och kopplat in den på serieporten. Men jag får en massa konstiga tecken bara (se nedan). Jag har ställt in Hyperterminalen på 4800 bps. Måste man ändra nån annan inställning?
datablad till mottagaren: https://www1.elfa.se/data1/wwwroot/webr ... 840002.pdf
&N2F6N2F6V22JVnb>6JrN:"..:F>>>NzN**2*F2>>NFN>:2>>F            i9S&fffffsfffS&&
&f&Lff39s&&fffs2>NjN:N>.N2F6N::F>NJN.>FNJNN>>>>V&nJVnb>b2zNzN2N:&N>"N62N6>NNN
NNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6>F>>>NzN**2*F2>>NFN>:2>>F2>NjN>F>N"*F*>N62
>::>NNV2.JV             i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F>NJN.>
FNJNN>>>>V&.JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6:F>>>N
zN**2*F2>>NFN>:2>>F            i9S&fffffsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N:
:F>NJN.>FNJNN>>>>V&"JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>b2&N2N:
N::N:2N"*N>".N6.N>"N.N:"6N2:N62N.:N>""N.>N>6N.>N6"NV"JVnb>b2&N2N6N::N>.N2"N66
6NN:>N26N6*NN:&N6>N>."N26N>N:"N:2N6.V">JVnb>b2&N2N2N::N>*N:.N2>>NN6>N:>N:6N6
N6N>N22NV.6JVnb>6JrN:"..            i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N
>.N2F6N::F:NJN.>FNJNN>>>>V&"JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb
>6JrN:"..62F>>>NzN**2*F2>>NFN>:2>>F            i9S&fffffsfffS&&&f&Lff39s&&fffs
2:>NjN:N>.N2F6N::F:NJN.>FNJNN>>>>V&>JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F
6V2>JVnb>6JrN:"..6.F>>>NzN**2*F2>>NFN>:2>>F            i9S&fff&fsfffS&&&f&Lff3
9s&&fffs2:>NjN:N>.N2F6N::F6NJN.>FNJNN>>>>V&6JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F
*N2F6N2F6V2>JVnb>6JrN:"..6*F>>>NzN**2*F2>>NFN>:2>>F            i9S&fffffsfffS&&
&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F6NJN.>FNJNN>>>>V&:JVnb>b2zNzN2N:&N>"N62N6>NNN
NNNNNN.F*N2F6N2F6V2>JVnb>6JrN:"..6&F>>>NzN**2*F2>>NFN>:2>>F2:>NjN>F>N"F:*N62
>::>NNV2"JV             i9S&fff&fsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N::F6NJN.>
FNJNN>>>>V&>JVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>b2&N2N:N::N:2N"
*N>".N62N>"N.N:"6N2>N62N.:N>""N.>N>6N.>N6"NV"fJVnb>b2&N2N6N::N>.N2"N666NN:>N26
N6*NN:&N6>N>."N26N>N:"N:2N6.V">JVnb>b2&N2N2N::N>*N:.N2>>NN6>N:>N:6N6N6N>N
22NV.2JVnb>6JrN:"..            i9S&ffffLsfffS&&&f&Lff39s&&fffs2:>NjN:N>.N2F6N:
:F2NJN.>FNJNN>>>>V&jJVnb>b2zNzN2N:&N>"N62N6>NNNNNNNNN.F*N2F6N2F6V2>JVnb>6JrN:".
.6F>>>NzN**2*F2>>NFN>:2>>F2:>NjN>F::N&6F*2N62>::>
/Christian
Re: Gps + hyperterminal = konstiga tecken
Vad har du som nivå-konvertering?
För om jag tolkar den där rätt så har den TTL-nivåer på porten (0 och 5 V), och din datorn har troligen RS-232-nivåer (3 - 12 V och -3 - -12 V).
Christian
Det är en minilaptop och en usb-serieports konverterare, men kanske fortfarande är som du säger med olika nivåer?
Anders_Peter
Inlägg av Anders_Peter »
Precis som Nerre skriver så står det på sidan 3, 0-2.85volt TTL, sedan brukar man ställa in, baudrate, antal databitar, stopbitar, paritet, detta står om på sid 10.
/Anders
Christian
Vilket är det lättaste sättet att konvertera från ttl - rs232? Max232?
Jag har även kopplat gps-modulen till en basic stamp, men den ska väl kunna läsa av ttl nivåerna direkt?
Anders_Peter
MAX232 låter väl som ett vettigt förslag, har aldrig använt basic stamp men om den arbetar med 5v så borde det väl fungera.
Hillman
Inlägg av Hillman »
Jag har börjat använda dessa sladdar mer och mer, då slipper man hålla på med att koppla MAX232-kretsar hela tiden.
TTL-232R USB-TTL-kablage 3.3V I/O - Elfa-nr: 73-206-74
TTL-232R USB-TTL-kablage 5V I/O - Elfa-nr: 73-206-73
MAX3222
snigelen
Inlägg av snigelen »
Hillman skrev:Jag har börjat använda dessa sladdar mer och mer, då slipper man hålla på med att koppla MAX232-kretsar hela tiden.
Jo de är smidiga. Man får stabil spänningsmatning på köpet. Har man dessutom lagt in en bootloader innan så har man kommunikation, spänningsmatning och programmeringsinterface i en enhet, med fyra tåtar att koppla :)
sysop
Inlägg av sysop »
TTL -> CMOS är konstruktionsmässigt rätt. no doubt. Jag är dock inte säker på att detta är ditt problem.
Hur har du kopplat modulen?
Kollat på att ändra sirfbin -> NMEA?
gvs
Inlägg av gvs »
Hade liknande problem med en mottagare från samma tillverkare, men min var USB-ansluten. Hittade följande, programmet längst ner på sidan kan du testa med: http://www.usglobalsat.com/gpsfacts/bu3 ... facts.html
