1. Ser det shemmat ut att funka bra?
2. Kan jag andvända mina röda lysdioder som drar 2.4 v?
3. Räcker det med 3 volt att driva alla 64 dioder?
Tacksam för svar!
Det var en bit av vad som han hade skrivit om de...I had the datasheet for the Motorola 74HC374 in front of me. The circuit is designed around the source/sink capabilities, timing characteristics and acceptable supply voltage range of the 74HC374, and if you use anything else the result is not guaranteeable. At best you will see reduced battery life.
