RepLab - The Open Source Fab Lab: Call for participation
olleolleolle
Inlägg av olleolleolle »
Detta är ett anrop från Open Source Ecology som kommer att göra ett FabLab, fast Open Source. Man siktar på en stark kostnadsreduktion, och enkel replikerbarhet. Du kan vara med!
Jag postar det här på forumet för att det finns ett starkt CNC-gäng här, och för att den aktiva läsarskaran kan föra det här vidare till intresserade. Marcin Jakobowski utanför Kansas City leder projektet, och här följer hans email. Han vill gärna ha kontakt med andra som jobbar på liknande projekt, så svara honom gärna.
Friends,
I would like to call out further for participation in RepLab - The Open Source Fab Lab: See blog post
We are gathering interest from people interested in working on the open source fab lab components. Because many different hackerspaces have an interest in tools of production - we're hoping to leverage this interest to develop the open source fab lab.
The list of tools needed is below. Please get back to us specifically on what you can contribute. In particular:
  1. Tell us the tool of interest to you;
  2. What specific technical developments you are willling to contribute to the project - such as design, calculations, research, fabrication, testing, documentation, web development, marketing, resource development, parts sourcing assistance, etc.
  3. Resources and infrastructure that you have available, and what groups you are involved with or that you can leverage for assistance
  4. Suggestions on strategies and enterprise models that can be utilized in development
  5. Suggestions on tools missing, and how you're willing to contribute to developing them
  6. How much energy you can commit - do you 'have a job' or can you commit significant time?
TOOL LIST - from FabLab - see http://openfarmtech.org/index.php?title ... _item_list
  1. Laser cutter - large DIY community exists for C02 lasers
  2. ShopBot - RepTab is the Factor e Farm version
  3. Precise router for milling circuits
  4. Plasma cutter - power circuit is main point to opensource
  5. Welder - power circuit is main point to opensource
  6. Oscilloscope - can a computer oscilloscope cover most needs?
Beyond FabLab:
  1. RepRap - fabrication streamlining and open business model needed
  2. Mill
  3. Drill
  4. Lathe
  5. Induction furnace - power electronics are main point to opensource
  6. Ciruit fab - automated process including pick-and-place
  7. Aluminum extrusion
  8. Metal casting - of ingot from induction furnace, and other molds
  9. Hot rolling
  10. Cold rolling
  11. Forging
  12. Metal shear and hole punch for up to 1" steel
  13. Wire drawing
These tools cover electronics, precision fabrication, heavy metal work, and ability to make other tools for producing any technology known in advanced civilization. Tools created from the above can even yield clean room technology. The above is quite a limited set, but is sufficient to generate other tools. The latter parts focus on serious industrial process, with a bias towards building replicable, post-scarcity resilient communities with capacity to bootstrap largerly from scrap steel.
Comments and refinements of problem statement are welcome.
Thanks,
Marcin
marcin@replab.org
mri
Re: RepLab - The Open Source Fab Lab: Call for participation
Inlägg av mri »
RepLab, FabLab, ShopBot, RepTab, RepRap, FABuloUS, FeF... :)
Har läst här och där på de där sidorna... men än så länge får de mig inte mer än att småle lite. :roll:
Är det här något verkligt, eller är det bara några bloggande visionärer som har för mycket fritid framför datorn?
olleolleolle
Bra fråga. Ja, det är på riktigt. Jag klargör med lite länkar till de olika sakerna.
Saker som byggts av eller tillsammans med Factor e Farm: Relaterade teknologier som inte byggts av Factor e Farm:
  • FabLab, en samling av existerande digital-fabrikations-maskiner, som dokumenteras och behandlas som ett paket av produkter som kan kickstarta en studio varsomhelst.
  • ShopBot är ett företag som saluför diverse CNC-maskiner.
  • RepRap är en populär 3D-printer.
mri skrev: Är det här något verkligt, eller är det bara några bloggande visionärer som har för mycket fritid framför datorn?
Ungefär som Linus bara var en student som lekte lite? :-)
Det handlar ju bara om det som många gör här på forumet mer eller mindre varje dag: Att dela med sig av sina konstruktioner utan att ta betalt för det och utan att hindra andra att förbättra eller förändra dem.
mri
Inlägg av mri »
Nja. Skillnaden är väl att Linus inte hade några fantastiska och storslagna visioner, utan råkade skapa nåt som just då passade som hand i handske i en större helhet, dvs operativsystemet GNU. Mash kärnan blev ju aldrig nåt.
Men men... "RepLab, FabLab, ShopBot, RepTab, RepRap..." projekten kan vara helt OK och intressanta, det vara bara det att de fick mina "WARNING FÖR HÖGTFLYGANDE VISIONÄRER" varningsklockor att ringa. Jag har i olika samanhang jobbat med hopplösa visionärer som inte riktigt står med båda benen på jorden... och det är något som inte passar mig (som är mer intresserad av verklig substans än luft och hype).
dar303
Inlägg av dar303 »
Det känns på något vis som vi missuppfattar de amerikanska alternativen lite. Det känns som dessa saker är mer en del av en demokratiseringsprocess för dom, att alla ska ha tillgång till produktionsmedlen efter många år av nedläggningar, allmän lathet och outsourcing av teknik då kunskaperna har koncentrerats till den akademiska världen. För att få sådana projekt att få luft under vingarna så behövs lite visionära ord och vi tolkar dem som drömmare men i själva verket så är ju flera av dessa projekt igång och riktigt famgångsrika som t.ex hackerspaces i californien. Det här har ju även kommit igång i mindre skala så att säga bland annat genom Make magazine/Make blog/Craft, BoingBoing mfl. Det handlar om att moderna "informationsmänniskor" börjar göra eller göra om saker i sin närmiljö och fundera på hur saker fungerar och vad man kan göra med dom istället för att kasta bort sakerna när de är omoderna eller trasiga.
bara en tanke. (eller 2) :)
Många av oss håller väl på lite till mans/kvinns att bygga våra egna FabLab:s i mindre skala hemma...
Här är mitt försök:
Lödutrustning, oscilloskop, frekvensräknare, några ok datorer, cnc-maskin, laserskärare, skruvdragare, pelarborr, cnc-svarv, cirkelsåg, sticksåg, svets (mig, tig, pinne), kretskortstillverkningsgrejer, luftkompressor, bänkslip, gasolbrännare, fotospektrometer, pic & arduino-grejer samt handverktyg.
Och så klart komponenter, metaller, trä, skruv/mutter + div annat skrot.
Precis, man får inte glömma att USA är patentens förlovade land.
Men annars handlar det ju i princip om att göra "Open Source" hårdvara. D.v.s. hårdvara där alla ritningar och sånt är fria så vem som helst kan använda dem utan att riskera att nån kommer och vill ha massa pengar för det.
