http://www.laserpointerforums.com/forum ... 38341973/0
808nm! GREEN LASER PUMP DIODES!!!
808nm 1/2W C-mount $25.00 each ***ALL GONE!***
808nm 1W C-mount $35.00 each
808nm 2W C-mount $50.00 each
808nm 2W C-mount w/FAC $75.00 each
808nm 3W c-mount $75.00 each
808nm 5W c-mount $150.00 each
808nm 5W C-mount w/FAC 200.00 each
808nm 2W 9mm cans $50.00 each
808nm 2W TO-3 TEC cooled laser diode $75.00 each!
808nm 1W BUTTERFLY LASER DIODE w/FAC $95.00 each
PRICE REDUCED! 808nm 7WATT+ laser diode bars 150.00 each, or 5 for $600!
Also have 40W FAP laser diodes for $400 OBO ***ALL GONE***
60 WATT 810nm LASER DIODE $450 OBO
120W- YES ONE HUNDRED AND TWENTY WATTS!!!! OMFG! 808nm LASER DIODE $995 OBO
Cool Red 635 through 655nm Cool
Red 645-655nm 1/2Watt C-mount $50.00 each
Red 645-655nm 1 Watt C-mount $75.00 each
PRICE REDUCED!Red 645-655nm 2 Watt C-mount $155.00 each
PRICE REDUCED! TO-3 RED 645-655nm 1-2W TEC COOLED LASER DIODE $95.00 each
SALE!Red 1 Watt 9mm 635nm $125.00 each w/colimator assembly $250.00, with nice TEC cooled collimator assy (custom build), $250 each
Red 1 Watt TO-3 635nm with nice TEC cooled w/collimator assy, $250 each
Red 655nm PULSED 3 to 5 WATT laser diodes $50.00 lot of 2, note these can also run constantly if cooled with a TEC in the 1W range. RUNNING LOW!
Prototype and other oddball laser diodes
BRIGHT ORANGE 622nm laser diode, have 3 units available, one produces about 125mw, one 300mw and one 500mw+ MAKE OFFER!!!
Green 300mW TO-3 532nm with nice TEC cooler w/ heat sink & collimator assy, $300 each ***ALL GONE!***
3-5W c-mount 835-980nm CW laser diodes $50.00 lot of 2! NOTE: PLEASE SPECIFY desired wavelength!
7W TO-3 980nm laser diodes w/collimator assembly $75.00 each *** NOTE RUNNING LOW!!!***
4W 904nm laser marking assembly for military target designator $125.00 each. Internal diode is rated to 8W peak power in QCW mode! It has a few more peaceful uses- it can be focused with a simple lens to make an excellent thermal PCB etching heads! *** ALL GONE***
15-40W phased laser arrays, Have 915, 980, 1500, and 808nm units in stock, these have the BEST BEAM you can get from multimode emitting diodes. If interested post or PM me.
40 and 60W pulsed laser diodes, operates near 1064nm only $25.00 each
Polychrome emitter assemblies units use an 8 element axicon and collimator to merge 8 laser diodes into 1 beam. Very unusual unit! Have a 40W 915nm and a 30W 808nm unit If interested post or PM me.
Cheesy AS IS Laser diode Grab bags!!! Cheesy
Grab bags sold AS THEY ARE without warranties!- Each Grab bag is unique, it will have working, dead, and off spec lasers included. The price is right though, if you get even 2 working 808's your ahead! You may however, if truly disappointed exchange your grab bag for another one of the same type at one time only. It is not likely that this will be the case though! Cheesy
$10.00 BAG OF "junk diodes" which i'll sell by the ounce... sold for gold reclaim or parts only, no guarantees of *ANY* working diodes in this lot- Only $10 a bag of one ounce! These may also be useful for the mounts if you have chips to mount on them too.
$50.00 for a lot of 25 assorted laser diodes, mostly 730nm through 980nm possibly some red 650 and 635nm diodes too. Power levels are generally over a watt if they work! About 75 to 90% are working. May have 9mm TO-3's and other types included
$50.00 Dead /weak TO-3 and similar type lasers with miniture TEC's in them etc, Lot of 5 units. These are more expensive than most grab bags because even if DOA you can pop the case open and remove the dead diode and reuse the TEC assemblies w/ thermistors for projects. Some may be open can style.
$75.00 Off spec and alternate wavelengths laser diode bars, Lot of 3. these will have a minimum power of 5 and a maximum power of 25W typical wavelengths of 100% bars are 835, 915, 980, and 1060nm, 808nm will have some sort of defect.
$100.00 Open can type 9mm lot of 50 diodes in a nice gel pac tray, you will get an assortment of wavelengths, mostly near IR, possibly red too. Possible wavelengths are all over the map, from 635nm through 1500nm Power levels are generally over a watt if they work, about 80% of these work.
PRICE WENT UP! $100.00 C-mount Lot of 20 C-mount diodes in a nice gel pac tray, you will get an assortment of wavelengths, mostly near IR, possibly red too. Possible wavelengths are all over the map, from 635nm through 1500nm. About 80% are working- Power levels are generally over a watt!
Electronic surprise box, $45.00US, $75.00 Int'l, A FLAT RATE USPS priority mailing box chocked full of electronic stuff both LASER and NON LASER gadgets. Would be worth hundreds of dollars for each item sold separately on ebay. Surprise box will have everything from milspec semiconductors and hardware to laser diodes, these WILL NOT DISAPPOINT YOU!
Laser diode CHIP grab bag, a lot of 3 boxes of bare laser diode dies for mounting on c-mounts or? only $10.00 a box or 3 for $20.00
Build your own diode kits! Box of laser diode chips, 2 inches of indium solder, and a bag of gold scrap lasers to recycle as mounts all for $25.00 variety of wavelengths and power levels to choose from, will try to accommodate you!
Cheesy OTHER LASERS & PARTS! Cheesy
Multiline ARGON LASER SYSTEM, $500 OBO Puts out about 75W on all lines, very nice Tem00 beam!
Red 2-5mW hene laser $45.00 delivered w/ power supply Int'l bidders add $25.00 to cover shipping!
YELLOW beam hene laser, abouut 4mW with 12V or turn-key power supplier $375.00 OBO
RARE ORANGE beam hene laser, abouut 4mW with 12V or turn-key power supplier $350.00 OBO
100mw lab laser- violet beam with plug-in PSU $150.00
Single AA battery violet laser diode UV glue curing tool $125 OBO
Synrad 40W CO2 Laser W/ magic box. $1800 OBO
RF excited CO2 laser with RF driver, 20W $350 OBO
Cool Other stuff!!! Cool
Indium Tin foil type solder 137 deg C MP $5.00 an inch long strip, also have pure indium and indium 3% Silver for the same price. Pure indium is an excellent thermal gasket material as well as solder that can solder metal to glass! Quantity discount available on this one!
80% gold 20% tin high end eutectic solder, Mp 280 degC $25.00 a gram- quantity discount available on this one too! Selling it at essentially the cost of the GOLD in it, normally this stuff sells for 3-5x the gold cost! This one can solder stuff without using a flux, solder ceramics to metal and other such "fun" applications. It also could be used in most hallmarkable jewelery repair since it is about 19Kt gold.
Tec's for cooling laser c-mount diodes, $10.00 each
Big TEC's for cooling Laser FAP or bars $25.00 each
Sodium metal 1 oz in mineral oil $75.00
Cesium metal 250 grams in Glass vial- $ ASK ME or make an offer!
Multimode primary collimator lens set $25.00 each
Missile laser collimator lens- VERY NICE for DIY hand held w/ a FAC red!! $25.00 each! As seen on ebay for about $100 EACH!
Cylinder lenses, Have fast, medium and slow lenses, if focusing close to burn/cut get FAST if collimating for long distances get SLOW only $10.00 each.
TO3 collimator assembly w/heat sink $ 75.00 each
Sapphire windows, $25.00 each
Cheesy Anything else just ask! Cheesy
