C:\Program\Microchip\Projekt\eeprom>xwisp2w verbose go eeprom.hex pass auxi
xwisp2 version 1.9.5 for Windows (Jan 24 2008, Open Watcom C/C++ 1.70)
Reading file 'eeprom.HEX'
File eeprom.hex loaded and is Intel Hex format conforming
Total of program and data memory: 428 bytes
Initializing serial port: COM1
Portspeed min: 50, max: 115200, cur: 38400
Portspeed new: 19200
DTR Off, RTS On
DTR On, RTS On
DTR Off, RTS On
Programmer type string: 'Wisp628'
Programmer firmware version string: '1.11'
Detected programmer: Wisp628, firmware version 1.11
Switching communications speed from 19200 to 115200 bps
Portspeed min: 50, max: 115200, cur: 19200
Portspeed new: 115200
Trying 14 bits core family (provisional target 16F627)
Received target deviceID: 3FFF
Not a valid Device-ID received
Trying 16 bits core family (provisional target 18F1220)
Received target deviceID: 0C44
Target: 18F4525 revision 04 (ID=0C44)
Datasheet: DS39626, Programming Specifications: DS39622
Using programming algorithm 9 (PIC18A)
Target erased
Transferring program to 18F4525 via Wisp628
[ Onödig info bortklippt, programmeringen fungerar utmärkt ]
Write-Verify operation terminated successfully in 0.00 seconds
Putting target in run mode
Portspeed min: 50, max: 115200, cur: 115200
Portspeed new: 38400
DTR Off, RTS Off
Entering PassThrough mode: AUXI
SendReceiveFast write error, bytes written: 0 of 4
xwisp2 failed after 1.78 seconds, rc 21
Press 'Enter' to continue:
Gör jag något fel när jag skriver flera argument (både GO och PASS) efter varandra till Xwisp2w, eller beror problemet på en bugg?
Om jag kör kommandot "xwisp2w pass auxi" separat efter programmeringen fungerar det bra. Jag vill dock helst kunna utföra allt på en enda rad enligt ovan.
Jag har inte hittat något officiellt support-forum för Xwisp2, finns det något?
