Etsning alla kan göra hemma! Ny metod!
ashsama
Inlägg av ashsama »
Det här var lite kul att göra faktiskt,
satt och tänkte lite och kom på en rolig idé, finns ju bla fosforsyra i coca cola så varför inte prova att etsa kretskort med det... (hade rätt tråkigt den dagen)...
Two copperclad PCB's are placed in beakers with one Coca Cola and the other Coca Cola Light.
(Pepsi was also evaluated but didn't meet standards)
About 1/5'th Hydrogen Peroxide is added as oxidizer.
(much less than I use when etching with hydrochloric acid - which might also explain the longer etching time)
After a couple of hours (depends alot on temperature),
the liquids turn all transparent for some reason.
The blue comes from the copper disolving.
And for some other reason - the Light turns all goo-ey and doesn't etch at all basically, so Coke Light is out of the competition.
Time goes by!
After a mishap I had to redo the test, therefor the liquid ain't as blue as it would be.
Here you see it's etched alot already.
This is the final phase - where the _real_ etching starts,
liquid turns deep blue and almost boils.
It'll take a couple of hours for the reaction to get to this stage -
instead of having the pcb's inside I recommend this is when you add the cards to prevent ink from unnessecary disolving.
The solution is self heating, and at the point of boiling - yes it WILL -
it will boil like crazy until the beaker is empty -
also releasing a nice cloud of smoke - maybe it's just vapor , didn't feel like sticking my head into it.
Here it's all boiled over into the bucket but hey - the card's finished so it's okay!
Result: Coca Cola etched PCB's!
I simply used a magic marker to write the stuff onto it,
of course you could use photoresist developed cards for much better result.
And more hydrogen peroxide for faster etching.
NEAT HUH?
xles
Inlägg av xles »
Awsome, totalt genialt! :D
ashsama
Inlägg av ashsama »
Fast det är säkert dyrare med coca cola än med saltsyra iofs :)
Får en också att fundera hur jäkla bra coca cola är att dricka....
PaNiC
Inlägg av PaNiC »
Underbart :D.
*Inmundigar ett glas cola*
anton
Inlägg av anton »
men flera timmar? går inte vanlig etsning på några minuter bara? Och vad är fördelarna med cocacola, får man läckrare färger på vätskan? :lol:
ashsama
Inlägg av ashsama »
Säkert inga fördelar alls :)
Har bara provat två gånger så går kanske att tweaka till mängderna så det går snabbare , ev värma vätskan också...
När reaktionen väl börjat - då går det rätt fort dock...
Henry
Inlägg av Henry »
Det blir uppenbarligen en ordentlig reaktion, undrar vad som bildas av koppar, fosfor och väteperoxid? :)
peter555
Inlägg av peter555 »
Skicka in det där till Expressen/AB så lär det bli ett j-a liv.
Henry
Inlägg av Henry »
:lol:
peter555
Det vore riktigt kul att trycka till Coca Cola med tanke på de i andra avseenden onyttiga produkter de säljer. Man kan ju inleda med att skriva att normalt används saltsyra eller andra otrevliga saker för etsning.
Nisse
Inlägg av Nisse »
Trycka till CocaCola? Den femtedel Väteperoxid som också är med i blandningen kanske har något med det hela att göra.......
peter555
Väteperoxid presenteras naturligtvis som det snälla sårtvättmedlet. Sedan fixar kvällsblaskorna resten.
rehnmaak
Inlägg av rehnmaak »
Undrar om det går att ersätta väteperoxiden med något annat tex klorin som oxideringsmedel :?:
dar303
Inlägg av dar303 »
haha, häftigt!
Hur kom du på detta?
Fritzell
Inlägg av Fritzell »
Coolt
Lite för tidsödande för att jag ska prova det dock.
