guldkorn från CNCZone, lågbudget torque-mätning av stegmo
dar303
Inlägg av dar303 »
Nåt för wiki/klistrad?
Geckodrive-Mariss:
This is the low-tech method I came up with some time ago to measure motor power directly using just a paper towel, channel lock pliers and a multimeter:
1) Run your motor up to a speed of interest. It must be more than 2 to 3 revs per second.
2) Set your multimeter to 'DC Amps' and put it in series with the power supply. You will be measuring power supply current to the drive.
3) Measure the supply current with no load on the motor.
4) Fold a full paper towel over and over until it is 1" by 3" in size. You want it nice and thick. Moisten it and fold it over the motor shaft in a "U" shape. Grab the motor shaft with your channel lock pliers with the towel as a 'brake pad'.
5) Start slowly clamping down with the pliers while watching the Ammeter. More pressure is more amps. At some pressure the motor will stall. Note the meter reading at the instant of stall. Repeat a few times until you sneak up on the stall point and get the highest ammeter reading. This takes a little skill and a steady hand.
6) Subtract (3) from (5) to get the difference between the two current readings: Delta I = (I stall) - (I no-load).
Multiply 'Delta I' times your measured power supply voltage to get Watts: Watts = (Delta I) * (V supply)
That is your motor's power output power in Watts at the speed you are running it at. To calculate motor torque at that speed use:
In-oz torque = Watts * 1351 / RPM
That's all there's to it. A big NEMA-23 or any NEMA-34 motor will put enough power into the towel to catch it on fire. Moistening it and keeping moist will turn that power into steam and keep the motor shaft from getting heat damaged. I have a video I made somewhere where the shaft glows a dull cherry red when a dry towel is used. It ruins the motor shaft and you have a paper towel on fire, so keep it wet with bigger motors.
The reason for folding the towel over a million times is to make it thick. Otherwise the channel lock pliers will ruin the motor shaft if it can bite thru the paper.
Done carefully (accurately measuring current at instant of stall) will give an answer within +/-5% of a genuine dynomometer result. This method falls apart at slow speeds because the motor generates very little power at low speeds (Power = torque times RPM). The difference between no-load current and stall current becomes too small to measure accurately.
The results from this method have been compared to dynomometer results (yes, we a good calibrated one and I use it all the time) hundreds of times with all sorts of motors. The results agree within the stated +/-5% tolerance.
funkis
Utsparkad, på semester
Inlägg av funkis »
Tycker inte att det är en bra ide, jag har gjort som så att jag låter stegmotorn
hissa och sänka en tyngd (magnetit i en pose men det går lika bra med selleri)
via ett simpelt spel.Inga glödande axlar och sånt. och man vet hur många kilo
den drar i för stunden.
Vad man kunde göra är att köpa en såndäringa skivbroms till en cyckel
och låta motorn driva den.
dar303
Inlägg av dar303 »
Tång, multimeter och en servett är ganska basic grejer, helt klart MacGyver-poäng i mina ögon!
Sen kan man ju koppla på en annan axel om man är orolig över att glödga den på motorn.
funkis
Inlägg av funkis »
Jo, men varför förstöra stegmotorn på köpet?
Ser ingen poäng i detta!?
dar303
Inlägg av dar303 »
"Moistening it (the towel) and keeping moist will turn that power into steam and keep the motor shaft from getting heat damaged"
Greensilver
Inlägg av Greensilver »
Torde icke fungera om stegmotordrivern har en strömreglering till lindningarna ("chopper"). Men annars var det ju en fin tanke. Stegmotorer skadas ju inte av att "stallas" vad jag förstått.
dar303
Inlägg av dar303 »
Han som skriver detta är samma man som har byggt de mycket framgångsrika "geckodrives", chopperbaserade stegmotordrivers.
http://www.geckodrive.com/
Nåja, jag ska testa när jag har mitt system igång, dock inte direkt på motoraxeln utan jag kopplar på en annan axel så jag inte sabbar nåt.
Helifoto
Inlägg av Helifoto »
dar303 skrev:Nåja, jag ska testa när jag har mitt system igång,.
Varför det? Funkar det när systemet är igång så är ju allt gott och väl och då kan det ju kvitta hur mycket kraft motorerna levererar, eller? :)
dar303
Inlägg av dar303 »
För vetenskapen min vän, för vetenskapen... :)
