Problem ansluta ESP8266, dmesg
Oltronix
Inlägg av Oltronix »
Försöker ansluta en Wemos ESP8266 till en Linuxburk, Ubuntu 22.04.5 LTS
Linux HP 5.15.0-160-generic #170-Ubuntu SMP Wed Oct 1 10:06:56 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
Då händer följande och jag får förståss ingen kontakt med ESPn
[okt.19 15:16] usb 3-8: new full-speed USB device number 8 using xhci_hcd
[  +0,149263] usb 3-8: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[  +0,000004] usb 3-8: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  +0,000002] usb 3-8: Product: USB Serial
[  +0,001467] ch341 3-8:1.0: ch341-uart converter detected
[  +0,000415] usb 3-8: ch341-uart converter now attached to ttyUSB0
[  +0,537438] input: BRLTTY 6.4 Linux Screen Driver Keyboard as /devices/virtual/input/input21
[  +0,184195] usb 3-8: usbfs: interface 0 claimed by ch341 while 'brltty' sets config #1
[  +0,000523] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[  +0,000015] ch341 3-8:1.0: device disconnected
När jag drar ut USB-sladden:
[okt.19 15:17] usb 3-8: USB disconnect, device number 8
När gör samma sak med en Raspberry Pi så ser det ut så här, och jag får kontakt med ESPn
Raspbian GNU/Linux 9.13 (stretch)
Linux mumin3 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
dmesg -e
[Oct19 15:09] usb 1-1.4.3: new full-speed USB device number 16 using dwc_otg
[  +0.133315] usb 1-1.4.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[  +0.000025] usb 1-1.4.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[  +0.000011] usb 1-1.4.3: Product: USB Serial
[  +0.002092] ch341 1-1.4.3:1.0: ch341-uart converter detected
[  +0.011581] usb 1-1.4.3: ch341-uart converter now attached to ttyUSB0
När jag drar ut USB-sladden.
[Oct19 15:10] usb 1-1.4.3: USB disconnect, device number 16
[  +0.000987] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[  +0.000149] ch341 1-1.4.3:1.0: device disconnected
Vad kan det var för problem? Jag har testat flera ESP8266-kort.
nifelheim
Den första
Re: Problem ansluta ESP8266, dmesg
Inlägg av nifelheim »
Om du inte är synskadad så avinstallera BRLTTY :-)
sudo apt remove brltty
Oltronix
Funkar!! Tack!!
