Varför blir det konflikt I MPLAB
newbadboy
Inlägg av newbadboy »
Försöker konfigurera pinnarna i MPlab MCC. Man jag får en konflikt på alla pinner jag satt som analoga ingångar.
Vad är det som jag missförstår.
Försöker även toggla en pinne för att se om det lever men det verkar stå helt still. Vad har jag missat?
MAIN
#include <xc.h>
#include "mcc_generated_files/mcc.h"
void main(void) {
  while(1){
  LATBbits.LATB1=1;
  __delay_ms(100);
  LATBbits.LATB1=0;
  __delay_ms(100);
PIN MANAGER FILE
#include "pin_manager.h"
void PIN_MANAGER_Initialize(void)
  LATx registers
  LATA = 0x00;
  LATB = 0x00;
  LATC = 0x00;
  TRISx registers
  TRISA = 0x7E;
  TRISB = 0x41;
  TRISC = 0x81;
  ANSELx registers
  ANSELC = 0x00;
  ANSELB = 0x80;
  ANSELA = 0x46;
  WPUx registers
  WPUE = 0x00;
  WPUB = 0x00;
  WPUA = 0x00;
  WPUC = 0x00;
  RxyI2C registers
  RB1I2C = 0x00;
  RB2I2C = 0x00;
  RC3I2C = 0x00;
  RC4I2C = 0x00;
  ODx registers
  ODCONA = 0x00;
  ODCONB = 0x00;
  ODCONC = 0x00;
  SLRCONx registers
  SLRCONA = 0xFF;
  SLRCONB = 0xFF;
  SLRCONC = 0xFF;
  INLVLx registers
  INLVLA = 0xFF;
  INLVLB = 0xFF;
  INLVLC = 0xFF;
  INLVLE = 0x08;
CONBITS
// Configuration bits: selected in the GUI
// CONFIG1L
#pragma config FEXTOSC = OFF  // External Oscillator Selection->Oscillator not enabled
#pragma config RSTOSC = HFINTOSC_1MHZ  // Reset Oscillator Selection->HFINTOSC with HFFRQ = 4 MHz and CDIV = 4:1
// CONFIG1H
#pragma config CLKOUTEN = OFF  // Clock out Enable bit->CLKOUT function is disabled
#pragma config PR1WAY = ON  // PRLOCKED One-Way Set Enable bit->PRLOCK bit can be cleared and set only once
#pragma config CSWEN = ON  // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed
#pragma config FCMEN = OFF  // Fail-Safe Clock Monitor Enable bit->Fail-Safe Clock Monitor disabled
// CONFIG2L
#pragma config MCLRE = EXTMCLR  // MCLR Enable bit->If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR
#pragma config PWRTS = PWRT_OFF  // Power-up timer selection bits->PWRT is disabled
#pragma config MVECEN = OFF  // Multi-vector enable bit->Interrupt contoller does not use vector table to prioritze interrupts
#pragma config IVT1WAY = ON  // IVTLOCK bit One-way set enable bit->IVTLOCK bit can be cleared and set only once
#pragma config LPBOREN = OFF  // Low Power BOR Enable bit->ULPBOR disabled
#pragma config BOREN = SBORDIS  // Brown-out Reset Enable bits->Brown-out Reset enabled , SBOREN bit is ignored
// CONFIG2H
#pragma config BORV = VBOR_2P45  // Brown-out Reset Voltage Selection bits->Brown-out Reset Voltage (VBOR) set to 2.45V
#pragma config ZCD = OFF  // ZCD Disable bit->ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON
#pragma config PPS1WAY = ON  // PPSLOCK bit One-Way Set Enable bit->PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle
#pragma config STVREN = ON  // Stack Full/Underflow Reset Enable bit->Stack full/underflow will cause Reset
#pragma config DEBUG = OFF  // Debugger Enable bit->Background debugger disabled
#pragma config XINST = OFF  // Extended Instruction Set Enable bit->Extended Instruction Set and Indexed Addressing Mode disabled
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31  // WDT Period selection bits->Divider ratio 1:65536; software control of WDTPS
#pragma config WDTE = OFF  // WDT operating mode->WDT Disabled; SWDTEN is ignored
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7  // WDT Window Select bits->window always open (100%); software control; keyed access not required
#pragma config WDTCCS = SC  // WDT input clock selector->Software Control
// CONFIG4L
#pragma config BBSIZE = BBSIZE_512  // Boot Block Size selection bits->Boot Block size is 512 words
#pragma config BBEN = OFF  // Boot Block enable bit->Boot block disabled
#pragma config SAFEN = OFF  // Storage Area Flash enable bit->SAF disabled
#pragma config WRTAPP = OFF  // Application Block write protection bit->Application Block not write protected
// CONFIG4H
#pragma config WRTB = OFF  // Boot Block Write Protection bit->Boot Block not write-protected
#pragma config WRTC = OFF  // Configuration Register Write Protection bit->Configuration registers not write-protected
#pragma config WRTD = OFF  // Data EEPROM Write Protection bit->Data EEPROM not write-protected
#pragma config WRTSAF = OFF  // SAF Write protection bit->SAF not Write Protected
#pragma config LVP = OFF  // Low Voltage Programming Enable bit->HV on MCLR/VPP must be used for programming
// CONFIG5L
#pragma config CP = OFF  // PFM and Data EEPROM Code Protection bit->PFM and Data EEPROM code protection disabled
Shimonu
Re: Varför blir det konflikt I MPLAB
Inlägg av Shimonu »
Function måste sättas till ANA antar jag? har aldrig använt MPLAB.
Varför är det två rader med samma namn?
newbadboy
Ja det verkar som att först tilldelar den IO som ut eller in. Sedan om man aktiverar ngn annan funktion som tex adc och uart skriver den dit en rad med det oxå.
Första gången jag kör MPlab och det är så satans mycket man kan välja o styra så det är galet
Kryssa bort funktionerna som är assignade till "PIN_MODULE"
newbadboy
Shit vad detta är skumt. Jag kan inte klicka bort bara en utan måpsta klicka bort båda samtidigt. Men jag får då varninge tvärtom istället :)
Jämdför bilderna så ser du vad jag menar. Jag har här klickat bort RA1
rvl
Inlägg av rvl »
Undrar som Shimonu också varför det är dubbla rader med samma namn?
(Har inte heller använt MPLAB ...ännu.)
newbadboy
Jag svarade på den frågan direkt efter :).
Innan jag aktiverade ADc modulen fanns det en rad bara. Sedan när jag aktiverade modulen fick jag 2 rader.
EDIT:
Har lagt till mer info i första inlägget!!
Shimonu
Inlägg av Shimonu »
Behöver du inte anropa PIN_MANAGER_Initialize i main? Eller ska MPLAB sköta det i startup innan main?
newbadboy
Jag anropar hela mappen mcc_generated_files/mcc.h och där finns pin manager.
Anropar jag inte denna mapp så får jag massa fel vid kompilering
Shimonu
Inlägg av Shimonu »
Att inkludera mcc_generates_files/mcc.h betyder inte att någon kod där exekveras. Du behöver fortfarande anropa funktionerna. Vad är det för kompileringsfel du får då?
Testa att lägga till
PIN_MANAGER_Initialize();
innan din while-loop.
newbadboy
Ja ska def prova. Ni kan ha rätt. Det är första gången jag använder mplab.
Eg får jag inget kompileringsfel. Utan det var varningen jag får redan i pin manager. Det syns i bilden. I mitten längst ner.
Markerad med gula varningstrianglar.
Varför ställer du inte frågan i rätt forum?, dvs MPLABX forum?
newbadboy
Har provat där oxå men här på EF brukar folk vara mer på hugget :)
Nu har jag fått kretsen att toggla :) det var SYSTEM_Initialize(); som behövdes.
Nu ska jag bara utröna vad varningarna betyder och om det är ngt jag alls behöver bry mig om :=
