static int/void/vad som kompileringsfel MPLab X idf 6,05
Repaterion
Ort: Gustavsfors (Lite till vänster om världens utkant)
Inlägg av Repaterion »
Tjosan.
Leker med en PIC18F4550 i C.
Försöker få till en statisk funktion men jag får kompileringsfel, är det någon skillnad på hur man skriver dessa i MPlab XC8 (2,36) mot "vanlig" C/Atmel?
Fellmedelandet är: error: function declared in block scope cannot have 'static' storage class :humm: :roll:
Har prövat lägga static före/efter void eller int, lagt int, void eller tomt i parenteserna men samma fel.
header.h
alla andra konfigurationer finns ovan.
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
void LEDBlink();
#endif	/* XC_HEADER_TEMPLATE_H */
main.c
#include "header.h"
void main(void) {
    TRISBbits.TRISB0 = 0;   // 0 = OUT // 1 = INPUT
    TRISBbits.TRISB1 = 0;
    TRISBbits.TRISB2 = 0;
    TRISBbits.TRISB3 = 0;
    TRISBbits.TRISB7 = 1;
    while(1){
        LEDBlink();
    return;
"funktionsfilen"
#include "header.h"
static int LEDButtonBlinker();
void LEDBlink(){
static int LEDButtonBlinker(){
        if (PORTBbits.RB7 == 1){
            PORTBbits.RB0 = 1; //Turn on LED 0
            PORTBbits.RB1 = 1;  //Turn on LED 1
            PORTBbits.RB2 = 1;  //Turn on LED 2
            PORTBbits.RB3 = 1;  //Turn on LED 3
            __delay_ms(500);
            PORTBbits.RB0 = 0; //Turn off LED 0
            PORTBbits.RB1 = 0;  //Turn off LED 1
            PORTBbits.RB2 = 0;  //Turn off LED 2
            PORTBbits.RB3 = 0;  //Turn off LED 3
            __delay_ms(500);
Klas-Kenny
Re: static int/void/vad som kompileringsfel MPLab X idf 6,05
Inlägg av Klas-Kenny »
Ta bort "static int" från där du anropar funktionen i LedBlink().
Deklarationen ser OK ut.
Repaterion
:oops:
Jag har ju inte det i main... static int alltså... borde tänkt på detta.
Vi låtsas som att detta aldrig hänt, så glider jag ut diskret genom köksingången. :lol:
