Servotestare för 2 servon tänkt för tilt och pan.[Klart]
lgrfbs
Inlägg av lgrfbs »
För ett tag sedan beställde jag dessa mönsterkorten:
jag ville ha möjlighet att använda dem till andra projekt än just bara till servotestning, så det är med avsikt inte draget mönsterledningar mellan komponenterna.
Igår fann jag lite inspiration, så nu ser det ut så här:
// arduino-nano
// Modified by lgrfbs 2021-11-01
// https://www.makerguides.com/servo-arduino-tutorial/
// https://www.tutorialspoint.com/print-new-line-and-tab-in-arduino
//__________________________________________________________________________
#include <Servo.h> // include the required Arduino library
int Xangle = 0; // variable to store the servo position in degrees
int Yangle = 0; // variable to store the servo position in degrees
Servo pan;
Servo tilt;
// Define the servo pin:
#define servoPinT 10
#define servoPinP 9
// Global setting for program
  int Time=400; //Set time for blink.
  int Step=5; //Set time for blink.
  int Xpos=0; //Set defulte for X.
  int Ypos=0; //Set defulte for Y.
void setup() {
  // put your setup code here, to run once:
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  // Attach the Servo variable to a pin:
  pan.attach(servoPinP);
  tilt.attach(servoPinT);
Xangle=0;
Yangle=0;
  pan.write(Xangle); // tell the servo to go to the set position
  tilt.write(Yangle); // tell the servo to go to the set position
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  Serial.begin(19200);
  Serial.println(" ");
  Serial.println("Pan and tilt test device by lgrfbs 2021-11-01");
  Serial.println("---------------------------------------------");
  Serial.println("X:____\tY:____    positions");
delay(5000);
void loop() {
  // put your main code here, to run repeatedly:
  int Xpos=analogRead(A0);
  Serial.print("X:");
  Serial.print(Xpos);
  Xangle = map(Xpos, 0, 1016, 0, 100); // map the input to a value between 0 and 100 degrees
  Serial.print(" ");
  Serial.print(Xangle);
  int YPos=analogRead(A1);
  Serial.print("\t Y:");
  Serial.print(YPos);
  Yangle = map(YPos, 0, 1023, 0, 100); // map the input to a value between 0 and 100 degrees
  Serial.print(" ");
  Serial.println(Yangle);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(Time);                       // wait for a second
  Step=Step+1;
  Time=400;
  if (Step>5){Step=0;Time=200;}
Bonus:
Inläggnings etiketter till batterilådan för BG1 typ batterierna, för att snabbt se laddnings status på batteriet:
BG1 Batteriettikett.pdf
lgrfbs
Re: Servotestare för 2 servon tänkt för tilt och pan.[Klart]
Inlägg av lgrfbs »
Glömde att lägga med hårdvarulistan.
Mönsterkort:
https://www.pcbway.com/project/sharepro ... ester.html
W184210ASF10_Pan and Tilt tester.zip
3D hölje:
http://shpws.me/SSvo
http://shpws.me/SSvp
Hölje till pan and tilt.zip
MCU:
Nano ATmega328 V3.2 Board CH340 USB Chip Arduino Kompatibel
https://www.ebay.com/itm/252742123829
Joystik:
https://www.electrokit.com/produkt/joys ... novrering/
