Skapa Compile database fån MPLAB 8 och X, Hur?
Någon som vet hur man kan generera en Compile Database (json) från MPLAB8 eller X med MIPS-GCC (uChips version).
Dvs för en PIC32
mankan
Re: Skapa Compile database fån MPLAB 8 och X, Hur?
Inlägg av mankan »
Med X och mips-gcc, är det make-baserat?
Isf, kan du bara köra make clean;make 2>/dev/null > compile_data.txt, sedan är det mindre än 10 rader skalskript med grep, cut, echo så är det klart. Jag gjorde så på jobbet nyligen.
Makefilen är i princip tom
Den ser ut så här
#     CND_BASEDIR                base directory for relative paths
#     CND_DISTDIR                default top distribution directory (build artifacts)
#     CND_BUILDDIR               default top build directory (object files, ...)
#     CONF                       name of current configuration
#     CND_ARTIFACT_DIR_${CONF}   directory of build artifact (current configuration)
#     CND_ARTIFACT_NAME_${CONF}  name of build artifact (current configuration)
#     CND_ARTIFACT_PATH_${CONF}  path to build artifact (current configuration)
#     CND_PACKAGE_DIR_${CONF}    directory of package (current configuration)
#     CND_PACKAGE_NAME_${CONF}   name of package (current configuration)
#     CND_PACKAGE_PATH_${CONF}   path to package (current configuration)
# NOCDDL
# Environment
MKDIR=mkdir
CP=cp
CCADMIN=CCadmin
RANLIB=ranlib
# build
build: .build-post
.build-pre:
# Add your pre 'build' code here...
.build-post: .build-impl
# Add your post 'build' code here...
# clean
clean: .clean-post
.clean-pre:
# Add your pre 'clean' code here...
# WARNING: the IDE does not call this target since it takes a long time to
# simply run make. Instead, the IDE removes the configuration directories
# under build and dist directly without calling make.
# This target is left here so people can do a clean when running a clean
# outside the IDE.
.clean-post: .clean-impl
# Add your post 'clean' code here...
# clobber
clobber: .clobber-post
.clobber-pre:
# Add your pre 'clobber' code here...
.clobber-post: .clobber-impl
# Add your post 'clobber' code here...
# all
all: .all-post
.all-pre:
# Add your pre 'all' code here...
.all-post: .all-impl
# Add your post 'all' code here...
# help
help: .help-post
.help-pre:
# Add your pre 'help' code here...
.help-post: .help-impl
# Add your post 'help' code here...
# include project implementation makefile
include nbproject/Makefile-impl.mk
# include project make variables
include nbproject/Makefile-variables.mk
mankan
Inlägg av mankan »
Spelar ingen roll hur den ser ut. Det viktiga är att spela in kompilatorkommando som den kör med ungefär den raden jag gav dig. Du kan förresten skippa stderr-omdirigeringen.Möjligen kan du behöva slå på något verbose-läge för att få se vilka gcc-kommandon som körs.
Så, vad hittar man Make 2 på ett W10-system, och ser kommandoraden likadan ut?
mankan
Inlägg av mankan »
För Windows vet jag inte men du borde kunna köra samma mips-gcc i WSL men jag vet inte hur det hjälper dig göra en databas som funkar med MPLAB. De gånger jag kört MPLAB de senaste 20 åren är lätträknade.
Vad ska du ha databasen till?
Skall köra ett verktyg som heter cppcheck, för att kunna identifiera oanvänd kod.
Det vill ha en sådan fil tydligen.
Eller finns det någon som har bättre ideer för att identifiera oanvänd kod.
mankan
Inlägg av mankan »
Tillräckligt ny gcc kan varna för det själv, möjligen kan du behöva slå på lite -Wall -pedantic -Wextra osv. Tror det räcker med -Wall.
cppcheck kan jobba direkt på filer och kataloger fast då vet den inte vilka som används i ditt projekt.
Men MPLAB och MIPS, då har du väl inget OS med programladdning? Då borde din länkare redan ta bort kod som inte används.
GCC varnar inte för oanvänd kod, det togs bort för många år sedan.
Ej heller för oanvända globala variabler.
Och tyvärr, så i uChips version, så plockar inte länkaren bort oanvända funktioner heller.
Jo jag vet, därför så behöver jag databasen
mankan
Inlägg av mankan »
GCC varnar visst för oanvänd kod (funktioner). Osäker på globala variabler dock.
Länkare, kanske bara saknas lämplig flaggor. Använder Microchip inte GNU ld (gcc) eller gold (också gcc)?
Har aldrig någonsin fått en sådan varning, gissar att det handlar om vilken optimering man kan använda.
Med Doxygen har jag kunnat leta upp en del oanvänt (funktioner), men det är rätt krångligt.
mankan
Inlägg av mankan »
Vilken version har din MIPS-GCC?
Bla följande flaggor slås på med -Wall sedan GCC4.6.0, kanske äldre också men de har ingen html-dokumentation jag kan kolla.
-Wunused-function
-Wunused-label
-Wunused-value
-Wunused-variable
Optimering borde inte spela roll här. Ja, doxygen låter som fel verktyg men antar den utnyttjar collaboration graphs.
-Wall skall ju slå på detta, men icke.
Vilken den egentliga versionen av GCC det är har jag inte en aning om.
hmm
D:\Microchip\xc32\V3.01\bin>xc32-gcc --version
pic32m-gcc.exe (Microchip xc32 v3.01) 8.3.1 20190819 [ARM/embedded-6-branch revision 243739] Build date: May 21 2021
Part support version: could not read xc32_device.info
Jag begriper mig inte på GCC release history
från gcc.gnu.org
GCC 9.4 released [2021-06-01]
GCC 8.5 released [2021-05-14]
GCC 11.1 released [2021-04-27]
GCC 10.3 released [2021-04-08]
GCC 10.2 released [2020-07-23]
GNU Tools @ Linux Plumbers Conference 2020 [2020-07-17]
Will be held through online videoconference, August 24-28 2020
GCC 10.1 released [2020-05-07]
GCC 9.3 released [2020-03-12]
GCC 8.4 released [2020-03-04]
hur kommer det sig att version 11 släpps innan version 8.5 och 9.4
eller handlar det om buggfixar i äldre versioner?
hummel
Inlägg av hummel »
PC-lint från Gimpel gör det du vill men kostar en slant, finns full demo under några veckor.
Vet, men försöker hålla mina personliga kostnader nere.
