Vi håller på och tävlar ilte om vem som skriver ut en benchy på kortast tid
The rules are as follows;
you must use PLA, PLA+, PETG, ASA, ABS, or ABS+
you cannot use filled, metallic, or silk filaments (these filaments typically hide defects)
the print must finish
the maximum nozzle or line width size is 0.5mm
the maximum layer height is 0.25mm
You may combine infill every other layer
You must record the whole print
you must use 3 top and bottom layers
you must use 2 walls and 10% infill
The finished print must be dimensionally accurate (within reason) bonus points if it looks good!
The machine must be powered by stepper motors
There must be a timer/clock shown in the video to verify its real time.(a phone is fine or you can show the time before and after the print)
You must share the profile !
en lite snabbare Benchy
hywelmartin
