Nybörjarfråga
MarkBolton
Nybörjarfråga
Inlägg av MarkBolton »
Top 4 shelves you can use for mounting your baby monitor
Before mounting the best video baby monitor into your baby room, you must prepare enough essential items. They could be different depending on where you will install: the wall, on a shelf, or the baby crib. In the event of shelves, there are many different types of best baby monitors on the market Bild. Let you read the information about each one below to determine which one is the most suitable model.
What are the benefits of the baby monitor camera shelves?
Installing a baby monitor on a shelf can have an unobstructed view of the entire baby room without getting any blind spot. Moreover, this position can keep the video baby monitor out of the reach of your baby.
The types of baby monitor shelves
Small shelf with a flat surface
This option takes less space in your room; even it becomes invisible. It is small enough to hold a baby monitor. What's more, its stylish design with primary colors (black and white) suits any room decor. Here is the specific information:
The shelf that is 9.8 inches in width, 4.8 inches in depth, and 1.5 inches thick can put up with a 2.5-pound baby monitor.
If you don't want your monitor to fall, you had better secure the unit to the surface by using tape or 3M strip.
●▬▬▬▬๑ ๑▬▬▬▬● ●▬▬▬▬๑ ๑▬▬▬▬● ●▬▬▬▬๑ ๑▬▬▬▬● ●▬▬▬▬๑ ๑▬▬▬▬●
❃❃❃ Important Site: Bild Top rated baby monitors - The best baby monitor in the world
Adhesive small shelf stand
Drilling holes will ruin your walls, so what is the solution in this case?
Using an adhesive small shelf stand won't leave any unacceptable mark on the wall surface.
How can?
Instead of drilling, you will stick the baby monitor to the wall by using adhesive strips. You can still adhere to different surfaces without tools such as tiles, vinyl, decals, wallpaper, wood, and paint. Don't put more than 2 pounds on this shelf, or your installation will be broken.
Flat shelf with cable management
The flat shelf is designed to hold electronic devices. In this case, you just need to run the wire through the hole in the middle of the shelf. There is no need to run the cables to the side of the flat shelf.
What's more, the installation of this shelf is quick and straightforward. What you have to do is to use 3M adhesive command strips to stick to on the wall. When taking the baby monitor down, your wall won't be damaged.
Corner shelf with cable management
Thanks to the small design and size, this corner shelf suits limited space and room. Furthermore, this choice is pretty safe because you can secure the cable to the wall's corner.
Like other shelves, this corner shelf doesn't require a permanent installation. But, if you want to add extra security, you can use anchors and screws. It can withstand a thing over 2 pounds, so it's more than enough to hold a small model.
❖❖❖ Useful Link: Best rated baby monitors Bild
Although the best video monitor for baby can provide the parent unit with the high-quality video and audio, only picking up an appropriate shelf can result in a good view. What type of shelf have you bought? Don’t forget to let me know by leaving a comment in the section below.
StureS
Bannad
Re: Nybörjarfråga
Inlägg av StureS »
Du kan använda vilken mikroprocessor som helst (Arduino, Rapspberry mfl. även om det är lite overkill). Fördelen är att det är lätt att göra ändringar i frekvens osv.
Du kan även bygga allt med gamla hederliga TTL-kretsar men då är det svårare att ändra parametrarna.
HUGGBÄVERN
Tidigare soundbrigade
Re: Nybörjarfråga
Inlägg av HUGGBÄVERN »
En CD40106 (hex schmitt-inverterare), en CD4017 (10-räknare) och en CD4011 (NAND-grind) och lite motstånd, dioder och kondingar skulle kunna fixa det här.
(I det här läget hade det varit fint med en ritplatta som direkt skapade en jpeg- eller png-fil.)
Klas-Kenny
Re: Nybörjarfråga
Inlägg av Klas-Kenny »
Borde gå att lösa ganska enkelt med två 555'or också (eller en 556 som är just det).
En för att skapa 1 Hz blink, och en för att tända konstant efter 10s (10 blink).
Som sagt, en mikrokontroller är ju smidig då man enkelt kan justera blinket. Men är man inte van vid programmeringen kan det ju finnas enklare vägar.
HUGGBÄVERN
Re: Nybörjarfråga
Och för att fortsätta meningen Klas-Kenny inte riktigt avslutade:
Vill du ramla ner i det här kaninhålet kan du (till en början) välja om du vill starta med "diskret elektronik", dvs bygga med kretsar och transistorer eller programmera dina funktioner (PIC, Arduino ...).
Nånstans, skulle jag nog vilja säga är det bra att ha koll på både det ena och det andra.
StureS
Bannad
Re: Nybörjarfråga
Inlägg av StureS »
Huggbävern skrev: "Vill du ramla ner i det här kaninhålet kan du (till en början) välja om du vill starta med "diskret elektronik", dvs bygga med kretsar och transistorer eller programmera dina funktioner (PIC, Arduino ...). Nånstans, skulle jag nog vilja säga är det bra att ha koll på både det ena och det andra."
Håller absolut med. Det finns ingen universell lösning på allt utan man måste titta på detaljerna och hur lösningen enklast/smartast/billigast/kortsiktigt/långsiktigt kan utföras. Att ha en bred kunskap kommer aldrig vara till nackdel.
En fråga till TS (MarkBolton): Kommer frekvensen, spänningen eller annat att behöva ändras i framtiden? Då skulle jag välja en programmerbar lösning. Annars skulle jag bygga projektet i TTL.
Det är min personliga idé, inte alls säkert att det passar TS.
LeCanard
Re: Nybörjarfråga
Inlägg av LeCanard »
Med en gammal ICL8038 ( om du kan hitta någon) kan du lätt ändra frekvensen medelst några kondingar och en pot. Men den kanske mer är en leksak för Huggis, då den har olika vågformer att lattja med.
/LC
HUGGBÄVERN
Re: Nybörjarfråga
Jag har några sådana (8038) och har en idé med dem, men till det här projektet funkar de inte så bra.
Jag tänkte mig ungefär så här (man får kolla polariteten här och där):
Re: Nybörjarfråga
Välkommen till forumet.
Innan du väljer sätt att utföra lösningen är det viktigt att veta:
* Är parametrarna fasta? Alltså hastigheten för blink, tid innan blinket slutar osv. En icke-mikroprocessor lösning kan vara besvärlig att ändra.
* Ska det vara 12V pulser/nivåer som kommer ut? Är det bara lampor kan det vara lättare att koppla dom till 12V och sedan styra några transistorer til GND men det kan finnas orsaker till att styra 12V och det kan fungera fint också.
