Bild-/byggtråd Velleman K8200 3D-printer
Virror
Re: Bild-/byggtråd Velleman K8200 3D-printer
Inlägg av Virror »
Den är visst baserad på Marlin, så antar att den har samma stöd. Man kan kolla spana in all kod och scheman här:
https://github.com/fastbot3d/hardware
https://github.com/fastbot3d/u-boot
https://github.com/fastbot3d/linux-3.2.0
https://github.com/fastbot3d/firmware
Kulla
Inlägg av Kulla »
Hmm, det här är ny repo på github
Här är implementerad G kod
* Gcode command processor
* Implemented Codes
* look here for descriptions of gcodes:
* http://linuxcnc.org/handbook/gcode/g-code.html
* http://objects.reprap.org/wiki/Mendel_U ... pRapGCodes
* G0 -> G1
* G1 - Coordinated Movement X Y Z E
* G2 - CW ARC
* G3 - CCW ARC
* G4 - Dwell S<seconds> or P<milliseconds>
* G10 - retract filament according to setting of M207
* G11 - retract recover according to setting of M208
* G28 - Home all Axis
* G90 - Use Absolute Coordinates
* G91 - Use Relative Coordinates
* G92 - Set current position to coordinates given
* RepRap M Codes
* M104 - Set extruder target temp
* M105 - Read current temp
* M106 - Fan 1 on
* M107 - Fan 1 off
* M109 - Wait for extruder current temp to reach target temp.
* M114 - Display current position
* Custom M Codes
* M20 - List SD card
* M21 - Init SD card
* M22 - Release SD card
* M23 - Select SD file (M23 filename.g)
* M24 - Start/resume SD print
* M25 - Pause SD print
* M26 - Set SD position in bytes (M26 S12345)
* M27 - Report SD print status
* M28 - Start SD write (M28 filename.g)
* M29 - Stop SD write
* <filename> - Delete file on sd card
* M42 - Set output on free pins (not implemented)
* M44 - Boot From ROM (load bootloader for uploading firmware)
* M80 - Turn on Power Supply (not implemented)
* M81 - Turn off Power Supply (not implemented)
* M82 - Set E codes absolute (default)
* M83 - Set E codes relative while in Absolute Coordinates (G90) mode
* M84 - Disable steppers until next move,
* or use S<seconds> to specify an inactivity timeout,
* after which the steppers will be disabled. S0 to disable the timeout.
* M85 - Set inactivity shutdown timer with parameter S<seconds>. To disable set zero (default)
* M92 - Set axis_steps_per_unit - same syntax as G92
* M93 - Send axis_steps_per_unit
* M115 - Capabilities string
* M119 - Show Endstop State
* M140 - Set bed target temp
* M176 - Fan 2 on
* M177 - Fan 2 off
* M190 - Wait for bed current temp to reach target temp.
* M201 - Set maximum acceleration in units/s^2 for print moves (M201 X1000 Y1000)
* M202 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
* M203 - Set temperture monitor to Sx
* M204 - Set default acceleration: S normal moves T filament only moves
* (M204 S3000 T7000) in mm/sec^2
* M205 - advanced settings: minimum travel speed S=while printing T=travel only,
* X=maximum xy jerk, Z=maximum Z jerk
* M206 - set additional homing offset
* M207 - set homing feedrate mm/min (M207 X1500 Y1500 Z120)
* M220 - set speed factor override percentage S=factor in percent
* M221 - set extruder multiply factor S100 --> original Extrude Speed
* Note: M301, M303, M304 applies to currently selected extruder. Use T0 or T1 to select.
* M301 - Set Heater parameters P, I, D, S (slope), B (y-intercept), W (maximum pwm)
* M303 - PID relay autotune S<temperature> sets the target temperature.
* (default target temperature = 150C)
* M304 - Calculate slope and y-intercept for HEATER_DUTY_FOR_SETPOINT formula.
* Caution - this can take 30 minutes to complete and will heat the hotend
* to 200 degrees.
* M400 - Finish all moves
* M510 - Invert axis, 0=false, 1=true (M510 X0 Y0 Z0 E1)
* M520 - Set maximum print area (M520 X200 Y200 Z150)
* M521 - Disable axis when unused (M520 X0 Y0 Z1 E0)
* M522 - Use software endstops I=min, A=max, 0=false, 1=true (M522 I0 A1)
* M523 - Enable min endstop input 1=true, -1=false (M523 X1 Y1 Z1)
* M524 - Enable max endstop input 1=true, -1=false (M524 X-1 Y-1 Z-1)
* M525 - Set homing direction 1=+, -1=- (M525 X-1 Y-1 Z-1)
* M526 - Invert endstop inputs 0=false, 1=true (M526 X0 Y0 Z0)
* Note: M530, M531 applies to currently selected extruder. Use T0 or T1 to select.
* M530 - Set heater sensor (thermocouple) type B (bed) E (extruder) (M530 E11 B11)
* M531 - Set heater PWM mode 0=false, 1=true (M531 E1)
* M350 - Set microstepping steps (M350 X16 Y16 Z16 E16 B16)
* M906 - Set motor current (mA) (M906 X1000 Y1000 Z1000 E1000 B1000) or set all (M906 S1000)
* M907 - Set motor current (raw) (M907 X128 Y128 Z128 E128 B128) or set all (M907 S128)
* M500 - stores paramters in EEPROM
* M501 - reads parameters from EEPROM
* (if you need to reset them after you changed them temporarily).
* M502 - reverts to the default "factory settings".
* You still need to store them in EEPROM afterwards if you want to.
* M503 - Print settings
* M505 - Save Parameters to SD-Card
Virror
Inlägg av Virror »
Verkar ju som det mesta finns med iaf : )
Nu vill jag ha min nya hotend och buildplate så jag kan sätta igång att printa igen, man blir ju sugen med allt snack : p
Kulla
Inlägg av Kulla »
Haha, kan tänka mig, jag precis avslutade 5+ timmars utskrift :D
matteeee
Inlägg av matteeee »
Kulla: Får man säga så utan att bifoga en bild??
Kulla
Inlägg av Kulla »
Hahaha, sant i för sig
Här kommer ursäkt i form av bilder
Första utskriften är min första egna design på thingiverse: http://www.thingiverse.com/thing:718825
Här är den andra designen som jag skrev ut igår kväll, blev färdigt runt 01:30, ekolodsgivarfäste
0.20mm lager höjd, 60% infil
matteeee
Du är ursäktad :) Snyggt!
Virror
Inlägg av Virror »
Nice : )
dbostream
Inlägg av dbostream »
Det här med att byta kort för att kunna skriva ut snabbare, maxar ni verkligen det nuvarande kortet? Står på Vellemans sida att det ska gå att köra en bra bit över 100mm/s men jag brukar bara köra upp till 70 ungefär. Tycker det blir problem att smälta tillräckligt med plast om man kör snabbare så det är väl snarare hotenden man borde göra något åt? Men andra kort kanske klarar att elda på hotenden mer?
Kulla
Inlägg av Kulla »
Så länge du kan extruda tillräckligt mycket av smält plast då borde det gå att också kyla den så att du får hastigheten, problemet är att du kan inte ha båda två, kvalitet och hastighet
Virror
Inlägg av Virror »
Jag tror absolut att hotenden sätter begränsningen långt innan kortet, därför jag beställde e3d vulcan.
Jag tänker nog inte byta kort för det orkar jag inte men tyckte ändå det såg intressant ut och ville dela med mig : )
Har ju många andra trevliga features förutom hastigheten.
Virror
Inlägg av Virror »
Äntligen har dom skickat min PEI platta, ska bli spännande att se om den fixar nylon som utlovat!
dbostream
Ser fram emot lite bilder och omdöme när du fått den.
Köpte du den ifrån MTplus?
Virror
Inlägg av Virror »
Köpte min från amazon, tror jag länkade den här i en tidigare post, ska se om jag hittar länken.
Edit:
Leveranstiden är lite lång dock, ganska exakt en månad sedan jag beställde nu.
XorXaX
Inlägg av XorXaX »
Forumet verkar inte gilla långa länkar :(
