0-10v till 1-10v
MadModder
Re: 0-10v till 1-10v
Inlägg av MadModder »
Det är väl bara det att i första inlägget skrev du tvärtom. Annars är det klart. :D
Eller det STÅR alltså på dem som du skrev först. Men i verkligheten är det i det närmaste tvärtom?
Så vilket är det?
Larsson90
Inlägg av Larsson90 »
TomasL, saxat från http://www.lutron.com/en-us/education-t ... ts/10v.pdf
0-10V Basics
The two 0-10V control types are current source (a theatrical dimming standard) and
current sink (a dimming ballast standard).
There is an IEC standard for current sink controls - Standard 60929 Annex E. The
standard requires that the ballast (or driver) provides full light output when the control
voltage is 10 Volts (or above). As the control voltage is reduced by the control, the light
level is reduced. At a control voltage of 1 volt, the ballast (driver) provides it’s minimum
light level. Any voltage less than 1 volt is defined as minimum. Some drivers' minimum
is off, while other drivers' minimum is the lowest light level of the driver. It is important to
understand what minimum is for a particular driver. For drivers that do not go to off at
minimum, a separate relay or switching device is required.
An additional specification that needs to be considered is the current carrying capacity of
the control. Standard 60929 Annex E requires the ballast (driver) to limit the current
draw to 2.0 mA maximum. This means that a control with a 50mA capacity can operate
25 ballasts (drivers) if they have a specified current of 2.0mA.
For more information and to purchase the IEC standard, visit the IEC website
at http://www.webstore.iec.ch.
Current sourcing controls for 0-10V are supported by the standard ESTA E1.3,
Entertainment Technology – Lighting Control System – 0-10V Analog Control Protocol,
Draft 9 June 1997. It defines 10V as 100% light level and 0V as off. Drivers using this
protocol require the control to provide (source) the voltage.
Snälla nån, det är fullständigt ointressant vad diverse olika tillverkare skriver, VILKEN UTRUSTNING HAR DU, hur många gånger skall jag behöva upprepa detta, innan du begriper.
MadModder
Du behöver inte brusa upp Tomas.
Larsson90: börja först en test med att helt enkelt sätta en diod i serie. Slocknar lyset helt vet du vad du behöver göra.
börja med att sätta en diod i serie med utgången, och kanske ett litet pulldown efter så tappar du 0.5-0.7v och kolla om det funkar som du vill
ska man göra det på allvar får man ha en op som som drar bort 1v och förstärker signalen 1.1x
metric
Inlägg av metric »
Larsson90 skrev:TomasL, jag har en utgång som ger 0.88v-10v, ALDRIG 0v. Ingången behöver <= 0.8v för att släcka. Vet inte hur jag ska förklara det bättre?
Han har ju förklarat här!
nä, det finns inga förklaringar överhuvudtaget, bara en massa svammel hit och dit.
Vi bet fortfarande inte om han har 0-10V ut eller 1-10V ut osv.
Larsson90
Refererar till bilagan.
Den blåa enheten ger 0.88v-10v ut. Led drivaren som är mitt emot tänder lampan vid inspänning 1v och dimrar upp till 10v. Under 1v men över 0.8v lyser lampan lika mycket som vid 1v. Under 0.8v slocknar lampan.
Uppenbarligen har du då inte som du skrev, en 0-10V utgång.
Kan du då tala om för femtielfte gången vad du använder.
Larsson90
Qubino flush dimmer (ZMNHVD1) som styr
Hide a light Jolly Maxi Us.
MadModder och grym, tack ska kika :)
MadModder
:humm: Det står klart och tydligt 1-10V på Hide-a-liten. Eftersom den kräver mindre än det för att släcka ligger den utanför specifikationerna.
metric
Inlägg av metric »
Larsson90 skrev:Refererar till bilagan.
Sätt en diod i serie så får du ett spänningsfall på ett antal tiondels volt beroende på vilken diod du använder.
Och lamporna kommer att slockna när din enhet skickar ut 0.88V.
Sen kommer du inte ända upp till 10V så du får kanske inte full ljusstyrka, men det är kanske inget problem?
MadModder skrev:Du behöver inte brusa upp Tomas.
Men iom man ett flertal gånger efterfrågar relevant information, och ts ser sig för god att inte tillhandahålla detta, klart man blir irriterad.
Dessutom, TS förväntar sig att vi skall googla efter datablad etc, istället för i god ordning tillhandahålla dessa, nåväl, det gör mig irriterad.
Larsson90
Metric, ja det låter som den enklaste lösningen. Man tappar dock lite i max styrka på lampan.
