Parallellkoppla schottky-dioder
Re: Parallellkoppla schottky-dioder
Minförbrukning utan aktivitet, och maxförbrukning för ett komplett fiktivt system.
Minimum load refers to the power demand placed on the power supply when using a
bare system configuration with minimal power requirement conditions.
Minimum load configuration test results are shown in Table 32.
The test configuration was defined as follows:
• 2 GB DDR3/1066 MHz SO-DIMM
• USB keyboard and mouse
• LAN linked at 1000 Mb/s
• DOS booted via network (PXE); system at idle
• All on board peripherals enabled (serial, parallel, audio, …)
Table 32.  Minimum Load Configuration Current and Power Results
Output Voltage 	3.3 V  	5 V 	 	12 V  	-12 V  	5 VSB
Minimum Load 		0.89 A 	1.06 A 	0.14 A 	0.08 A 	0.10 A
2.7.2 Maximum Load Configuration Maximum load refers to the incremental power demands placed on the power supply,
augmenting the minimum load configuration into a fully-featured system that stresses power consumption from all subsystems.
Maximum load configuration test results are shown in Table 33.
• 4 GB DDR3/1066MHz SO-DIMM
• 14.1-inch LCD via LVDS
• SATA DVD-R/W
	Load: DVD playback
• 3.5-inch SATA hard disk drive, running Microsoft Windows Vista Home Basic
	Load: continuous read/write benchmark
• Intel Z-U130 USB Solid-State Drive or compatible device on the USB flash drive header
• Wireless card on PCI Express Full-/Half-Mini Card slot, connected via 802.11n protocol
	Load: continuous read/write benchmark on remote share
• Riser card on conventional PCI slot, populated with PCI LAN card, running file
  transfer through local network to SATA hard drive
• Back and front panel host-powered USB devices (other than keyboard and mouse)
	Load: continuous read/write activity on external drive/peripheral
Table 33.  Maximum Load Configuration Current and Power Results
Maximum Load 		4.78 A 	6.32 A 	2.01 A 	0.05 A 	0.72 A
rikkitikkitavi
Inlägg av rikkitikkitavi »
Löste det sig? Är det brådis?
Jag har några 20-30A i TO-XXX kapsling du kan få, tror det är 45V på dem. Kan slänga iväg ett brev på posten.
Nej, egentligen inte.
rikkitikkitavi
Vad jag menar är att det finns inga data på vad kortet i sig, utan kringutrustning drar vid full belastning, enbart ett komplett system.
Riki, svarade nog på fel inlägg, har hittat en bunt 3A Schottky-dioder liggande, ytmonterade förvisso, så det bör funka.
rikkitikkitavi
Ok. Hojta annars.
