Ersätta hårddisk med CF-kort/SSDdisk
Re: Ersätta hårddisk med CF-kort
Ingen installationsdiskett, bara en hemgjord systemdiskett.
Hur går det till partionera i DOS?
Det har jag aldrig gjort tidigare.
ajje
Inlägg av ajje »
Partitionering i DOS görs med "fdisk"
Ok, då ska jag se till att kopiera in FDISK på systemdisketten.
rvl
Inlägg av rvl »
Hade inte datorer på den tiden en skivstorleksgräns mindre än 8 Giga. Eller är just 8G gränsen med 1024 cylindrar? Max volymstorlek blir väl i alla fall bara 2 G med fat12 (dos).
lgrfbs
Inlägg av lgrfbs »
Lite sido information:
http://answers.microsoft.com/en-us/wind ... a6976ac0c0
"First, note that there are three varieties of FAT: FAT12, FAT16, and
FAT32. Many people call FAT16 just FAT, because before FAT32 came out,
FAT16 was the only variety used for hard drives, so just calling it
FAT was sufficient.
FAT12 (hardly used at all anymore) had a maximum volume size of 12mb.
It was used almost exclusively for floppy disks.
FAT16 was used on hard drives (or partitions) up to 4GB, and had a
cluster size that varied from 2kb to 64kb, depending on the size of
the partition. It is almost never used anymore, because almost nobody
has partitions as small as 4GB.
FAT32 took over from FAT16 and has a maximum drive size of 2TB. Its
maximum file size is 4GB, which is why you can't copy a 5GB file to
it. Its cluster size is 4KB up to a partition of 8GB. Above 8GB the
cluster size grows up to 32kb.
NTFS is what almost everyone should be using on their hard drives
today. Its maximum volume size is 2^^64-1, and its maximum file size
is 16 × 1024^^6 bytes (way more than the biggest hard drive available
today). Its cluster size stays at 4kb, regardless of the volume size."
limpan4all
Inlägg av limpan4all »
Dos 6.22 kan väl inte adressera mer är 2GB per partition dvs med 8GB från början så kommer du inte att se mera än 2GB på C: men sedan kan du med FDISK lägga till D: E: och F: vardera med 2GB.
I MS-DOS 6.22 så kan/bör du inte ställa cluster size till annat än 32kB...
Sedan så skall alla partitionerna formateras, C: med /S för system (operativet)...
Innebär det att jag inte behöver partionera kortet?
Jag behöver inte de resterande 6GB.
Jo det måste du.
Partitionstabellen måste skapas, bootstrapkoden måste skrivas osv, det sker vid partitioneringen.
Därefter formaterar du disken så att MSDOS kan använda den.
Henry
Inlägg av Henry »
Vid formateringen efter partitioneringen så överför du systemfilerna som beskrivits innan så skall datorn efter en omstart boota in på disken om allt funkar som det skall.
Jag har fått hjälp att städa på kontoret.
Det är ett usel, för nu hittar jag ingenting längre.
Min systemdiskett är som förintad.
Jag har någon maskin i källaren med DOS 6.22, där borde man väl kunna tillverka en ny?
FORMAT/S var det väl va?
swesysmgr
Inlägg av swesysmgr »
Jo eller SYS C:
Jag (och säkert fler här :)) har originaldisketter och images för DOS 6.22 liggandes, problemet är väl att hitta blanka floppies att kopiera dem till.
lillahuset
Gått bort
Inlägg av lillahuset »
Om du vill ha 3,5" har jag några osprättade kartonger. 8)
Är det 1.44 MB?
lillahuset
Gått bort
TDK MF-2HD formatterade för MS-DOS. Det står inget om 1,44MB men jag är ganska säker på att det är det.
xxargs
Inlägg av xxargs »
Man kan alltid göra en dd-image av floppyn - zippa denna och skicka den (1.44 MB är inte stort idag...)
tittade genom mitt lager - men DOS 6.0 och uppgradering till DOS 6.2 är vad jag hittade och vet inte om dessa är läsbara (har förvisso extern USB/floppydisk-drive liggandes någonstans)
såg att boot-disk image kunde man tanka hem här
http://www.allbootdisks.com/download/dos.html
