Dimbara lågenergi-lampor?
Re: Dimbara lågenergi-lampor?
Jo det var inga problem att ladda hem från första länken
Dimming of the lamp is accomplished through the closed loop control of the average lamp power as long as the
lamp voltage corresponds to IVL<IVLstopx.0.85, otherwise lamp current control. The voltage at the CRECT pin,
representing the average lamp power, is compared to the reference voltage applied at the DIM pin. An internal
high gain error amplifier drives the oscillator FWD time until the difference between these two inputs is reduced to
near zero, resulting in a linear and proportional control of the lamp power with DIM voltage. The waveform at the
DIM pin is internally sampled during the falling sloped portion of the VCO waveform, and held just prior to the
falling edge of the T2 gate drive signal. The usefull input range at the DIM pin for dimming control is between a
maximum level of 2.79V and a minimum level of 0.44. Outside these levels the DIM control voltage (which is
internally limited) has the same effect as the maximum or minimum values. The lamp control loop is only closed
following a successful lamp ignition as discussed in section 6.10. External changes in the DIM control voltage
should be slower than the rate of change in voltage at the CRECT pin (set by Rrect and Crect) and must never be
instantaneous.
Vill minnas att innan HF-Donens tid, hade man speciella lysrör och armaturer som gick att dimma
Hittade en artikel som förklarade det istället:
EEtimes: How compact fluorescent lamps work--and how to dim them
Frekvensen till två MOSFETs som aktiveras omväxlande med en varierande frekvens (67-43 kHz) kopplat till en "tank circuit" som består av en serieinduktans och en parallellkapacitans. I sin tur kopplat till lysröret.
Ansats:
Push-pull utgången varieras i frekvens som gör att LC delen ger en frekvensberoende AC ökad spänning som används till reglerloppen med strömmen som utgångspunkt.
Således borde dimmer funktion ske genom att amplituden hos strömmen genom lysröret varieras.
Kretsen IRS2530D som används i exemplet kan styras via DIM pinnen om man vill slippa styrning med elmatningen. En mikrokontroller med ett RC filter skulle då lätt kunna styra den från ett eget hemmanätverk. Vilket var trådskaparens önskan ;)
(hittade UBA2010)
netrunner skrev:
JimmyAndersson skrev:Sedan vill man förstås ha en *riktig* varmvit ljusbild med stor spridning.
Skulle du klara av att i en blindtest ( :D 8) ) hitta en vanlig glödlampa mot 5-6 olika CFL, sida vid sida i identisk armaturer? Jag har försökt och även testat lite andra personer som tvärsäkert har valt helt fel.
Sen det här med med stor spridning är ju ett problem. Nästan alla armaturer måste ha en reflektor eller lampskärm för att man ska få en riktad ljusbild och inte bli bländad.
Jag är inte ute efter något superspecialdeluxe-varmvitt ljus, utan helt enkelt något som bara *är* varmvitt.
Vi köpte några lampor som ger ett tydligt "kallt" (aningen blått) ljus och det fungerar ingenstans, trots att det stod "varmvit".
Jo iofs, på ett stort (A2) svartvitt foto i svart tjock ram på en "varm" mörkröd vägg blev det effektfullt.
Spridningen är inget problem om de som designar lamporna tänker lite utanför de gamla vanliga ramarna.
Reflektor måste ju inte innebära den klassiska "tratten". Det har fotografer vetat i princip lika länge som kameran har funnits.
Förresten, finns det verkligen inget sätt att dimma en vanlig lågenergilampa?
Att dimma en lågenergilampa är ungefär som att dimma en switchad power supply.
Gimbal
Inlägg av Gimbal »
JimmyAndersson skrev: Förresten, finns det verkligen inget sätt att dimma en vanlig lågenergilampa?
Jodå, mekaniskt.
Du får bygga specialarmaturer med någon form av bländare på. Dubbla polaroid filter kanske?
Det var en kul och originell idé! :tumupp: Det måste jag komma ihåg. :D
Nerre:
Vilken typ av switchteknik?
Funderar på vad som händer med spänningen och frekvensen i och efter nätdelen
om man ändrar spänning och frekvens i matningspänningen.
Jag saknar tyvärr apparaterna som krävs för att testa.
Vanliga glödlampor gick ju att driva med likspänning från labb-aggregatet, även om det inte lös speciellt starkt. :)
mrfrenzy
Inlägg av mrfrenzy »
Lamporna lyser med konstant effekt från ca 100-240V, under 100V slocknar dom då det inte längre finns tillräckligt med energi i glättningskondensatorn för att bibehålla spänningen till drivdonet.
Här finns ett schema och lite beskrivning: http://www.en-genius.net/includes/files/col_081307.pdf
Ajdå.
Mycket matnyttig PDF-fil! Tack! :tumupp: :tumupp:
YD1150
Inlägg av YD1150 »
Lite fler scheman på lågenergilampor:
http://www.pavouk.org/hw/lamp/en_index.html
Efter att djupdykt i lysrörsdrivardjungeln så kan jag konstatera att dom flesta drivs med någon form av resonant switchkonverterare oftast utförd med push-pull steg och induktans i serie.
Om dimfunktion önskas så ändrar man frekvensen så att olika mycket spänning når lampan.
Det innebär att två dimtekniker saknas:
* Hoppa över enstaka pulser
* Pulsbreddsmodulering
Hur tål ett lysrör ren likström? (måste det vara AC)
YD1150
Inlägg av YD1150 »
Tror inte att livslängden blir så stor, DC kommer nog att "äta" upp
en av elektroderna i lysröret.
Det rekommenderas att strömmen genom lysröret är så nära sinusform som
möjligt annars blir det något som kallas Cathode Sputtering.
Aktivt material från glödtrådarna "slungas" ut och det äter på dem.
Hittade lite info till på "utrikiska":
Fluorescent lamps can run directly from a DC supply of sufficient voltage to strike an arc. The ballast must be resistive, and would consume about as much power as the lamp. When operated from DC, the starting switch is often arranged to reverse the polarity of the supply to the lamp each time it is started; otherwise, the mercury accumulates at one end of the tube. Fluorescent lamps are (almost) never operated directly from DC for those reasons.
Om starten av ett lysrör:
Each start cycle slightly erodes the electron-emitting surface of the cathodes; when all the emission material is gone, the lamp cannot start with the available ballast voltage.
Finns det någon övre maxfrekvens det går att driva rören med?
Borde kunna göra det möjligt annars att släppa iväg skurar av sinusvågor och på det sättet åstdakomma ljusreglering.
(detta att till/frånslag försämrar livstiden lämnar också en del att fundera över ang CFL..)
