Nu har jag fått igång ghdl och gtkwave.
Jag fick göra om lite register eftersom jag inte har filerna från logiblox. (Jag har ett gammalt projekt).
Men hur ska jag få den att förstå vad + är?
Den kan inte använda std_logic_signed.
primary unit "std_logic_signed" not found in library "ieee"
Så här står det i bruksanvisningen:
Sometimes, a design does not fully follow the VHDL standards.
For example it uses the badly engineered std_logic_unsigned package.
GHDL supports this VHDL dialect through some options:
--ieee=synopsys -fexplicit
Men det blir ju bara så här:
ghdl --ieee=synopsys -fexplicit
/usr/lib/ghdl/bin/ghdl: unknown command '--ieee=synopsys', try --help
Vad ska jag göra då?
Lite mer förklaring:
synopsys
Supply the former packages and the following additionnal packages:
std_logic_arith, std_logic_signed, std_logic_unsigned, std_logic_textio.
These packages were created by some companies, and are popular.
They are not standard packages, and have been placed in the IEEE library without the ieee permission.
Gratis-program för vhdl-simulering och syntes?
Det verkar inte ens finnas "ieee" som val när man kör programmet.
"-fexplicit" är ju med, men jag hittar inte "ieee"...
ghdl --help
usage: /usr/lib/ghdl/bin/ghdl COMMAND [OPTIONS] ...
COMMAND is one of:
-a [OPTS] FILEs Analyze FILEs
-e [OPTS] UNIT [ARCH] Elaborate UNIT
-r UNIT [ARCH] [OPTS] Run UNIT
--elab-run [OPTS] UNIT [ARCH] [OPTS] Elaborate and run UNIT
--bind [OPTS] UNIT [ARCH] Bind UNIT
--link [OPTS] UNIT [ARCH] Link UNIT
--list-link [OPTS] UNIT [ARCH] List objects file to link UNIT
-c [OPTS] FILEs -e UNIT [ARCH] Generate whole code to elab UNIT from FILEs
-m [OPTS] UNIT [ARCH] Make UNIT
--gen-makefile [OPTS] UNIT [ARCH] Generate a Makefile for UNIT
--dispconfig Disp tools path
-i [OPTS] FILEs Import units of FILEs
-s [OPTS] FILEs Check syntax of FILEs
-d or --dir Disp contents of the work library
-f FILEs Disp units in FILES
--clean Remove generated files
--remove Remove generated files and library file
--disp-standard Disp std.standard in pseudo-vhdl
--chop [OPTS] FILEs Chop FILEs
--lines FILEs Precede line with its number
--pp-html FILEs Pretty-print FILEs in HTML
--xref-html FILEs Display FILEs in HTML with xrefs
--xref FILEs Generate xrefs
-h or --help [CMD] Disp this help or [help on CMD]
-v or --version Disp ghdl version
--options-help Disp help for analyzer options
ghdl --options-help
Main options:
--work=LIB use LIB as work library
--workdir=DIR use DIR for the file library
-PPATH add PATH in the library path list
--std=87 select vhdl 87 standard
--std=93 select vhdl 93 standard
--std=93c select vhdl 93 standard and allow 87 syntax
--[no-]vital-checks do [not] check VITAL restrictions
Warnings:
--warn-binding warns for component not bound
--warn-reserved warns use of 93 reserved words in vhdl87
--warn-library warns for redefinition of a design unit
--warn-vital-generic warns of non-vital generic names
--warn-delayed-checks warns for checks performed at elaboration
--warn-body warns for not necessary package body
--warn-specs warns if a all/others spec does not apply
--warn-unused warns if a subprogram is never used
--warn-error turns warnings into errors
Illegal extensions:
-fexplicit give priority to explicitly declared operator
-C --mb-comments allow multi-bytes chars in a comment
--bootstrap allow --work=std
--syn-binding use synthesis default binding rule
Compilation dump:
-dp dump tree after parsing
-ds dump tree after semantics
-da dump tree after annotate
--dall -dX options apply to all files
Compilation list:
-ls after semantics
-lc after canon
-la after annotation
--lall -lX options apply to all files
-lv verbose list
-v disp compilation stages
Jag hade tydligen fel... Webpack verkar vara för privatpersoner också.
Först får man registrera sig. "User id" är deras namn för användarnamn.
Sen får man fylla i mer saker när man hämtar programmet.
Då vill dom veta vad det är för företag eller organisation.
Jag skrev private, nånting. Det verkar fungera. Jag fick filerna i alla fall.
Så nu har jag webpack och Modelsim XE III starter (gratis-versionen) till windows.
Webpack finns till Redhat linux också. Jag provade i ubuntu, och lade in dom här tre sakerna:
http://www.c3a.de/wiki/index.php/ISE_Webpack_Ubuntu
Det mesta verkar fungera. Men det händer inte så mycket när jag tar
"view/edit routed design (fpga editor)".
I windows verkar programmen prata med varandra genom en lokal nätverksanslutning.
Jag vet inte hur det är i linux. Det kan ju vara nåt annat som är fel också...
Re: Gratis-program för vhdl-simulering och syntes?
Tog igår och laddade ner och installerade Xlinx ISE 10.1 som var gratis att ladda ner. Men STORT är det att ladda ner och installera, totalt 2,25GB, men webinstallfilen är "bara" på 48MB, så suger den ner resten från nätet under installation. Tog nästan en hel dag att slutföra detta innan allt var på plats.Andax skrev:Xilinx ISE WebPACK är ju gratis. Och med den kommer ju Modelsim XE III starter. WebPACK innehåller ju även "ISE simulator lite" som jag visserligen inte testat.BJ skrev:Jag har använt Modelsim och Xilinx ISE förut. Finns det några gratis-program som kan ungefär samma saker?
Körde igenom verktyget idag med ett enkelt exempel i den Tutorial som finns med. Jämfört när jag gick kursen för 3år sedan med Modelsim m.fl. så har man nu integrerat allt, så man befinner sig i samma verktyg genom kodning, simulering, syntes och laddning till målsystemet. I verktyget finns en hel del templates också, så även om man som jag är lite rostig i VHDL så får man en hel del hjälp där. Trots att verktyget innehåller mycket så var det inte så knepigt som man skulle kunna tro, bara man lär sig hitta allt.
Har dock ingen hårdvara ännu, så den biten har jag inte tittat på ännu.
Upptäckte att jag var registrerad sedan tidigare, och då var jag registrerad som studerande, nu var det bara att logga in igen och suga ner det nya.
Atera
Laddade igår ner Alteras Modelsim "Web Edition", som också är gratis och stödjer CPLD och små FPGA enligt info på deras sida.
http://www.altera.com/products/software/sfw-index.jsp Man måste även här registrera sig, men det var inga som helst problem. Denna gick betydligt snabbare att ladda ner och installera än vad Xilinx hela designpaket gjorde. Nu är ju Modelsim "bara" simuleringsbiten och inte samma designstöd sim ISE (med templates etc.), däremot så känns den lite lättare att använda.
Återkommer när jag laddat ner och testat Quartus för syntesbiten.
