Keppe Motor
blueint
Re: Keppe Motor
Inlägg av blueint »
hubben, Du har inte borrat djupt nog.. :badgrin:
Apropå fri energi.. kanske man skulle bygga en "solfångare" för högenergi gammastrålning. Enstaka småskurar dyker upp ibland. ;)
hubben
Re: Keppe Motor
Inlägg av hubben »
196 meter bara, får upp 4-5 gradigt vatten året om.. Klart är det -45 ute så skiljer det ju en del, men då klarar man sig nog inte utan elpatron i vilket fall. ;-)
ds77
Re: Keppe Motor
Inlägg av ds77 »
FAQ - Keppe Motor
1.11. Can the Keppe Motor be attached to a generator and power a home?
Answer: No. Every machine loses energy during its energy conversion process and this is not an exception for the Keppe Motor. In order to achieve such feat, a motor should be able to deliver more energy than it consumes.
Despite the new technology employed to the Keppe Motor, its efficiency gets close to 100% but does not exceed this value, so it needs an external power source to function.
Nevertheless, coupled to photovoltaic panels, the Keppe Motor can easily provide energy in excess for most domestic needs.
The STOP Association research team carried out some experiments to verify the efficiency of a system comprised of one Keppe Motor fan equivalent to 60W + one Battery (12V/4.3Ah) + one 20W-Photovoltaic panel. The results showed that the motor consumed between 0.1 and 0.3 Amps in a cloudy day (summer day, São Paulo (Brazil), 11 Am). This current corresponded to consumption between 1.2 and 3.6W in order to turn the fan blade at 700 rpm. With few minutes of direct sunlight the battery was rapidly recharged. This same Keppe Motor worked in a closed room (without the solar panel) connected to one 12V regular car battery, moving the 60W fan blade, which dropped from 1,100 rpm to 930 rpm after 55 hours of continuous operation. These speeds corresponded to the voltages of 12,4V and 11,1V, respectively. This means that the 60W equivalent Keppe Motor worked continuously for more than two consecutive days (48 hours) without losing much of its output power using only a regular car battery. If it were deep discharge, this autonomy would have been even greater.
In other words a small 20W photovoltaic panel can supply enough energy to one battery in order to supply a 60W equivalent Keppe Motor for several days work, even without direct sunlight. These results are very encouraging for we can think about small self-sustaining water pumping systems (24h non-stop working regime) with 7 liters/min flow at almost zero cost.
In regions where the sunlight is more intense and abundant around the year this available self-sustaining system can be easily scaled up and bring immediate and unimaginable benefits to the populations that don’t have access to the public grid.
Lite kul att dom motsäger sig själva...
Kul att läsa forumet om alla som försöker ladda batterier med motorn, en hade ett nästan helt urladdat alkaliskt 9v batteri som han fick upp till 8.7v(0.7v/h) eller nått samtidigt som batteriet han drev allt med laddades ur till 8.2 eller något(0.02v/h eller vad han mätte i för enhet). Sedan konstaterade han att det uppladdade batteriet verkade laddas ur 30 ggr den vanliga hastigheten... och tyckte att experimentet var lyckat.
Walle
Moderator
Re: Keppe Motor
Inlägg av Walle »
Vilka dårar det finns, säger jag bara. Så lurade, så naiva. Så korkade.
Jag skulle vilja fråga både bloggerskan och konstruktören en enkel fråga: Om nu den här enkla motorn kan hämta energi från någon annan dimension eller vad det nu är frågan om, så borde det finnas ett minst lika enkelt sätt att mäta denna energi. Alltså: Hur mäter man denna "gudomliga" energi som ni så ihärdigt påstår att keppe-motorn går på? Snurrbollar säger jag bara.
Jag såg ett "perpetuum mobile"-försök på TV för många år sedan. Det var i princip en lutande rund "bana" (såg ut som toppen på ett oljefat som lutade lite) där ett gäng kulor rullade runt runt. När en kula kom med fart och slog till den "sista kulan" som låg still så fortplantade sig rörelserna genom stålkulorna och kulan "i toppen" satte fart. Och när den kom ned så slog den i den "sista" kulan, och så fortsatte det. Det var många många år sedan, men jag vill minnas att konstruktören själv var fullt medveten om att man inte skulle kunna plocka ur någon energi, men han trodde att den skulle kunna fortsätta göra vad den gjorde under väldigt lång tid. Någon som vet vad jag pratar om och har en aning om hur det gick?
blueint
Re: Keppe Motor
Inlägg av blueint »
Effekt och Newton-Meter-Varv/sekund det vore något för den motorn att mätas med.. :badgrin:
ds77
Re: Keppe Motor
Inlägg av ds77 »
Den gemensamma nämnaren för alla liknande konstruktioner verkar vara att det funkar inte nu, men med fler spolar och fler magneter så kommer det funka. Fungerar det inte då så behöver vi fler magneter osv....
hubben
Re: Keppe Motor
Inlägg av hubben »
Nej, det var ju nån gubbe som fått det att fungera - men nu kommer jag tusan inte ihåg vad han heter.
Han hade byggt en motor av ett par "kärnringar" av lite olika material, och cylindriska magneter som roterade runt dessa kärnor. Han hade byggt den första motorn när han jobbade hos en radioreparatör och fick tillgång till extremt fina magneter.
Första gången han testade motorn gav han den lite fart, och motorn fortsatte bara att accelerera tills den lämnade bordet och flög upp i taket - där den borrade sig igenom och försvann. Även den andra motorn och den tredje gjorde samma sak. Motor 9 eller nåt lärde han sig tygla och han byggde en flygmaskin av den. Han var ute en hel del och flög runt i london på sin motor. Han drev även hela sitt hus med en likadan motor. Sen kom kraftbolaget och gjorde en inspektion eftersom att han inte förbrukade någon el från elnätet, och tog hans motorer i beslag. Han hade nu slutat på tvfirman och fick inte tag i lika fina magneter längre, därför har han inte lyckats bygga nån motor som fungerar efter det.
Enligt officiella dokument åkte han dit för att ha tjuvkopplat sin elmätare, dvs dragit en kabel runt - det var därför elbolaget gjorde en inspektion, och detta åkte han även dit för. Konspiration säger gubben och alla som tror på honom... Och det verkar vara MÅNGA som tror på honom om man kollar youtube. Han har tom en egen fansite...
Han demar motorn på Youtube, men då har han 2 kablar ikopplade som försvinner ur bild....
Andy
Re: Keppe Motor
Inlägg av Andy »
Vad jag inte förstår är hur någon orkar kommentera den här typen av BS! :wacko:
Mizzarrogh
Re: Keppe Motor
Inlägg av Mizzarrogh »
Keff(e) motor... Edit: Ej att förväXXXla med Keppe motorn men likvärdiga egenskaper...
Paxmax
Re: Keppe Motor
Inlägg av Paxmax »
KEFF! ojoj... det har jag inte hört på bra länge... användes flitigt i slutet av 80-talet! fint ord... gillar det! :tumupp:
@ Andy: har man lite extra energi så blir humor'n värt besväret! :D
Electricguy
Re: Keppe Motor
Inlägg av Electricguy »
Får väl säga som Dave Jones, IT'S BOUSHEET! :mrgreen:
what ae peice ouf sheiit!
ToPNoTCH
Re: Keppe Motor
Inlägg av ToPNoTCH »
Låter som en Svalander motor :vissla:
Mizzarrogh
Re: Keppe Motor
Hos Svalan borde den ha en lysande framtid: "Avlägsnar störande fält från din anläggning så att ren andlig energi kan..."
Paxmax
Re: Keppe Motor
Inlägg av Paxmax »
:badgrin: :badgrin: :badgrin: :lol:
Andy
Re: Keppe Motor
Inlägg av Andy »
Paxmax skrev:KEFF! ojoj... det har jag inte hört på bra länge... användes flitigt i slutet av 80-talet! fint ord... gillar det! :tumupp:
Ja, du har faktiskt rätt! :lol:
