Jag är inte så sugen på vätskekylning, det blir ju så kladdigt..
Jag har hittat ett tryckluftssystem som använder kall (-25gr) tryckluft för att kyla verktyget vid bearbetning.
Finns det ngn här som har erfarenhet av ngt liknande?
Jag kommer nog jobba mest i fiber och plast men lättare aluminiumjobb kommer det nog bli en hel del av oxå.
Länk med info
Från produktbeskrivningen:
Dry machining is nowadays for many milling tasks the selection of choice.
Up to now, material, tool wear and tear and finish quality offer forced cooling with respective coolants/ lubricants.
This always means more humidity. Even spray cooling with minimum amounts leads to unintended side effects such as fouling, adhering of the shavings to the tool or surface and depending on material also effect on the material structure.
With the patented cooling method introduced here, the very good cooling of tools and surfaces make side effects a problem of the past.
The shavings are dry and depending on the material, easy to extract or blow off.
The surface is preserved and through the direct tool cooling (also appropriate for tools with inside cooling) long periods of tool use is obtained.
Basis of the cooling method is a cold air nozzle that operates on the whirlpool principle and separates the air flow in warm and cold air.
To operate the system only pressurized air (6 to 10 bar) is required.
Technical specifications:
Pressurized inlet: 6-10 bar
Cool air outlet: of up to -25 °C
Warm air oulet: up to max. 70 °C
Air use approx. 150 l/min
Special maintenance unit with 1µm filter
Maintenance free cold air nozzle
//Love
