Intressanta komponenter!
Syntex
Talljudskrets
Inlägg av Syntex »
http://www.speechchips.com/shop/item.asp?itemid=5
http://www.speechchips.com/downloads/sp ... manual.pdf
Item Name:
Magnevation SpeakJet IC
Item #:
SPEAKJET1
Price/ea:
$24.99
$21.99
This little 18 Pin IC is exactly what you need to add speech and audio to your latest project. These things are just so cool and packed with features too! All you need to add is +5V and a speaker! Now it's easy for anyone to add speech to your hardware projects.
· Programmable 5 channel synthesizer
· Natural phonetic speech synthesis
· DTMF and other sound effects
· control of pitch, rate, bend and volume
· Programmable announcements
· Multiple modes of operation
· Simple interface to microcontrollers
· Simple Stand Alone operation
· Three programmable digital outputs
· Internal 64 Byte buffer
· Internal programmable EEPROM
· Extremely low power consumption
· Low pin count
· Multiple case styles available
· Only need power and speaker to hear speech
The SpeakJet is a completely self contained, single chip voice and complex sound synthesizer. It uses a mathematical sound algorithm to control an internal five channel sound synthesizer to generate on-the-fly, unlimited vocabulary speech synthesis and complex sound generation.
The SpeakJet is programmed with 72 speech elements (allophones), 43 sound effects, and 12 DTMF Touch Tones. Through the selection of these sounds and in combination with the control of the pitch, rate, bend, and volume parameters, the user has the ability to produce unlimited phrases and sound effects, with thousands of variations, at any time. The SpeakJet can be controlled simultaneously by logic changes on any one of its eight Event Input lines, and by a single I/O line from a CPU (such as the OOPic or the Basic Stamp) allowing for both CPU-Controlled and Stand-Alone operations.
Other features include an internal 64 byte input buffer, Internal Programmable EEPROM, three programmable outputs, and direct user access to the internal five channel sound synthesizer.
DennisD7
Inlägg av DennisD7 »
Jag fick grejerna,
Hehe min tjej (på skoj): "jaha. och vem är den där Bengt egentligen"? när hon fick se förpackningen. Den ser ut som en smyckesförpackning, och själva komponenterna minst sagt som smycken. :D
Go kväll i stugan,
Visst är de små displayerna fina, har du hittat nåt datablad ännu? Själv har jag inte haft tid att leta men den borde finnas häromkring :roll:
Du får väl berätta / visa vad du skapat sen längre fram
Tackar för förtroendet
Bengt
DennisD7
Eh nej jag har inte letat än, bara beundrat det röda skimret i månskenet... drömt mig bort... :D
Yepp det lär bli ett projekt nån gång.
netrunner
Inlägg av netrunner »
Är det bara jag som har läst william gibson / virtual light ! :(
Klart att man ska ha en klocka i solglasögonen!
