MPLAB skriver detta!
Tar jag bort config raden så godkänner den det men avslutar med.Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F452 "Blink.asm" /l"Blink.lst" /e"Blink.err" /o"Blink.o" /c-
Warning[215] C:\BLINK.ASM 6 : Processor superseded by command line. Verify processor symbol.
Message[301] C:\P16F877A.INC 35 : MESSAGE: (Processor-header file mismatch. Verify selected processor.)
Warning[230] C:\BLINK.ASM 9 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Error[126] C:\\BLINK.ASM 9 : Argument out of range (not a valid config register address)
Halting build on first failure as requested.
BUILD FAILED: Tue Feb 26 02:17:42 2008
"Couldn't locate build tool. Check tool locations"
Har googlat i timmar o fått lite olika tips men inget funkar! Har provat både version 8.00 och 7.52Warning[205] C:\UNTITLED.ASM 57 : Found directive in column 1. (END)
Couldn't locate build tool. Check tool locations.
Link step failed.
BUILD FAILED: Wed Feb 27 19:13:53 2008
