Leadwell Fmc 1 Fanuc O-M Dnc (drip feed)
Dasopel
Inlägg av Dasopel »
Hej.
Är det någon som har parameterinställningarna för att köra drip feed till en Leadwell Fmc1 med fanuc O-M styrning?
cinc
Re: Leadwell Fmc 1 Fanuc O-M Dnc (drip feed)
Inlägg av cinc »
Du kan testa med:
Fanuc 0 Series Controls
Suggested Cable Pin Out
CNC Control Computer 25 Pin Computer 9 Pin
I/O Port RS232 Port RS232
DB-25 Male DB-25 Male DB-9 Male
1 (Chassis ground) (Not connected) (Not connected)
2 3 2
3 2 3
7 7 5
4 and 5 jumpered
6 8 20 jumpered
Notes on Suggested Machine Control Settings
1. Set the PWE parameter to off. The machine will go into Alarm mode as you are setting the
parameters. After done setting the parameters set PWE back on and hit Reset.
2. Above procedure unnecessary to change Handy Page settings
3. On 0 Series Controls using ISO format, only Baud rate and # of stop bits can be set. Always use
Even parity, Word length 7, and 2 Stop bits.
4. All Parameters set by 8 bit numbers are read right to left, e.g. Bit 0 is the rightmost bit and Bit 7
is the leftmost bit.
5.
Control must have tape reader to do direct DNC. To direct DNC, go to tape mode, set up
NCSentry to Send and Wait for XON, hit Cycle Start at the CNC. To pause direct DNC turn
Feedrate Override to 0%.
Suggested Machine Control Control Parameters
#0002 - Set Bit 0 to 1 for 2 Stop Bits-I/O = 0
Set Bit 2 to 0 for RS-232 Input
#552 = 10 (4800 Baud)
Suggested Machine Control Set Page Settings
I/O = 0
ISO Format
Suggested DNC Communication Send Settings
Baud Rate 4800 (Suggested starting point)
Parity Even
Data Bits 7
Stop Bits 2
Handshake Software - XON - XOFF
Start at Machine Tagged active
First Lines %
Last Lines %
Remove Spaces Tagged active
Suggested DNC Communication Settings for Receive
Parity Even
Data Bits 7
Stop Bits 2
Receive Timeout 10000
Strip at end of Line
The settings are automatically saved when exiting the settings and they are saved to the currently
loaded machine configuration. The Receive and Send settings are separately saved.
säter
Inlägg av säter »
Det vill jag minnas också.
Har ditt system remsläsare?
cinc
Inlägg av cinc »
Jaha det var inte viktigare än så... :tumner:
säter
Inlägg av säter »
Det var dåligt med återkoppling från TS.
Dålig stil tycker jag. :tumner:
verkstaden
Inlägg av verkstaden »
Men för oss andra kan det vara väldigt värdefullt att hitta den här tråden när man sitter vid nån maskin klockan tre på natten slitandes håret och levt ett dygn på kaffe och kexchoklad så tackar cinc även om ts inte återkopplar!
