Har en hoover dyn33 5124D som ger "Error 07" precis efter att tvätten är klar. Luckan går endast att öppna om jag tar ur stickproppen och väntar en stund.
Samt att låssymbolen nu visas hela tiden. Innan visades den endast när man tryckte på start.
Någon som har koll på detta?
Tack
Tvättmaskin ger felkod E07
Re: Tvättmaskin ger felkod 007
Något med eller kring låset verkar vara tokigt.
http://www.espares.co.uk/advice/0/2531/ ... rror-codesAn E01 error code or on some models and E07 error code indicates an issue with the door lock. This could be an issue with the door lock itself, the wiring or the connection to the PCB board.
An E02 error code will indicate an issue with the fill. Now this either means that there is a trapped, blocked or pinched fill hose, or an issue with the water supply or with the valves.
An E03 error code indicated there was a problem with the drain circuit, this usually means there is something stuck in the pump
An E04 error code may mean there’s a problem with the anti flood, this means you have water in the base and may indicate that you have a leak.
An E05 error code means that you have an issue with the NTC the water temperature sensor at the back. It may be as simple as a loose connection which needs reconnecting.
An E06 error code is either a problem in the machine being out a balance if the error code is displayed straight after a spin or it's a problem with the board or the eprom being faulty.
An E07 error code is either a problem with the door lock or with the motor being jammed and unable to spin.
An E08 error code indicates a problem with the motor speed sensor. This can result in the motor spinning up at very high speed for a few seconds slowing down and then stopping. It may also mean that the motor is not spinning.
An E09 area code means that you have a problem with the motor triac on the circuit board, this may mean that you don't have any motor drive.
An E10 error code on older machines may mean there's a problem with the motorised selector. On new machines it could indicate a drum sensor issue if fitted.
Now error codes 11 through to 14 all relate to issues with washer dryers.
An E11 error code indicates there's an open circuit on the dryer heater or a module issue, it's a good idea to check the wiring from the sensor on the top the drum to the circuit board as this can become damaged during the spin cycle.
An E12 error code suggests a PCB communication error or an open circuit on the dryer heater sensor.
An E13 error code means that there is an issue with the PCB as does the E14 error code. This could also indicate an issue with the dryer heater or the NTC
An E15 error code indicates that there may be an issue with the circuit board that it’s not programmed or the memory chip here has become corrupted.
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it’s hard to prove without the replacement of your heater.
An E17 error code means that there is an issue with the motor tachometer and could result in your motor not spinning.
An E18 error code means that there's an issue with the PCB.
Tack så mycket!
Antar (hoppas) det är dörrlåset som strular då eftersom den kör hela programmet så borde det ju inte vara motorn. Något vanligt fel som händer med låsen som indikerar denna typ av problem?
Den låser ju dörren så det kanske är något annat än själva låsmekanismen?
- HUGGBÄVERN
- Tidigare soundbrigade
Du får alltid den koden när försöker tvätta James Bonds tuxedo ....
soundbrigade skrev:Du får alltid den koden när försöker tvätta James Bonds tuxedo ....
Re: Tvättmaskin ger felkod E07
Bytte låset men låssymbolen uppför sig underligt fortfarande. Lyser när dörren är öppen samt slocknar inte efter avslutat program... tröttsamt (dock inget felmeddelande efter senaste tvätten)
