library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LCD is
    Port ( E : out  STD_LOGIC;
           RS : out  STD_LOGIC;
           DATA : inout  STD_LOGIC_VECTOR (7 downto 0);
           RW : inout  STD_LOGIC;
           CS1 : out  STD_LOGIC;
           CS2 : out  STD_LOGIC;
			  clka : in    STD_LOGIC;
			  status : out STD_LOGIC_VECTOR(4 downto 0));
end LCD;
architecture Behavioral of LCD is
	signal delay : integer := 0;
	signal done_sendning : STD_LOGIC;
	signal wait_for : STD_LOGIC;
	signal e_strobe_res : STD_LOGIC;
	signal CMD : STD_LOGIC_VECTOR(8 downto 0); -- 8: (0 = Kommando, 1 = Data)
   signal IP: integer := 0;
   signal tempsig: STD_LOGIC_VECTOR(5 downto 0);
	signal init_next_half: STD_LOGIC;
begin
	e_strobe: process (clka, wait_for)
	begin
	if (wait_for = '1') then
   if (clka'event and clka='1') then
		E <= '1';
      delay <= delay + 1;
      if (delay >= 22500) then --0,00045 / 0,00000002 = 22500 (450 ns min)
			 E <= '0';
			 if (delay = 45000) then
				delay <= 0;
				e_strobe_res <= '0';
			 end if;
      end if;
   end if;
	end if;
	end process e_strobe;
	sendCMD_D: process (CMD)
	begin
	    if CMD > "000000000" then
			done_sendning <= '0';
			RW <= '1';
			RS <= '0'; -- Läser status...
			while DATA(7) = '1' loop
					wait_for <= '1';
			end loop;
			if DATA(7) = '1' then
				RW <= '0';
				DATA(7 downto 0) <= CMD (7 downto 0);
				RS <= CMD(8) and '1';
				wait_for <= '1';
				if e_strobe_res = '0' then
					done_sendning <= '1';
				end if;
			end if;
		 end if;
	end process sendCMD_D;
	state_machine: process
		subtype rom_word is STD_LOGIC_VECTOR(3 downto 0);
		type rom_table is array(0 to 10) of rom_word;
		constant State_rom: rom_table := rom_table'("0001","0000","0010","0101",
																  "0100","0110","1001","0111",
																  "0011","1011","1101");
	begin
	   status(3 downto 0) <= State_rom(IP);
		case State_rom(IP)(0) is
			when '0' => --- Skicka kommando
			  CMD(8) <= '0';
			  case State_rom(IP)(3 downto 1) is
				  when "000" => CMD(7 downto 0) <= X"3F"; -- Sätter på display(X) utpekad av CSx
				  when "001" => CMD(7 downto 0) <= X"C0"; -- Sätter start linje
				  when "010" => CMD(7 downto 0) <= (X"B8" or ("00" & (tempsig and "111111")));
				  when "011" => CMD(7 downto 0) <= X"40";
				  when others => IP <= IP - 1;
			  end case;
			  if done_sendning = '1' then -- Behöver bara kolla denna bit
				  IP <= IP + 1;
			  end if;
			when '1' => -- Gör någonting annat...
					when "000" => CS1 <= '1'; -- Markera CS1
									  CS2 <= '0';
									  IP <= IP + 1;
			      when "001" => CS1 <= '0'; -- Makera CS2
								     CS2 <= '1';
									  IP <= IP + 1;
               when "010" => tempsig <= "001000";
									  IP <= IP + 1;
					when "011" => tempsig <= tempsig - 1;
						           if (tempsig = 0) then
										  IP <= IP + 1;
									  else
										  IP <= IP - 3;
								     end if;
					when "100" => tempsig <= "000000";
					              while (tempsig < "111111") loop
											CMD(8 downto 0) <= "111111111";
											   tempsig <= tempsig + 1;
											end if;
									  end loop;
					when "101" => if init_next_half = '0' then
										  IP <= IP - 8;
										  init_next_half <= '1';
									  else
										   IP <= IP + 1;
									  end if;
					when "110" => status(4) <= '1';-- Evighets loop...
					when others => null
				end case;
			when others => null;
		end case;
   end process state_machine;
end Behavioral;
NET "E" LOC = "C11";
NET "RS" LOC = "C10";
NET "RW" LOC = "E10";
NET "DATA<0>" LOC = "D11";
NET "DATA<1>" LOC = "C12";
NET "DATA<2>" LOC = "D12";
NET "DATA<3>" LOC = "E11";
NET "DATA<4>" LOC = "B16";
NET "DATA<5>" LOC = "R3";
NET "DATA<6>" LOC = "C16";
NET "DATA<7>" LOC = "D16";
NET "CS1" LOC = "E16";
NET "CS2" LOC = "G15";
NET "status<4>" LOC = "P11";
NET "status<3>" LOC = "P12";
NET "status<2>" LOC = "N12";
NET "status<1>" LOC = "P13";
NET "status<0>" LOC = "N14";
NET "clka" TNM_NET = "clk";
TIMESPEC "TS_clk" = PERIOD "clk" 50 MHz HIGH 50%;
NET "clka" LOC = "T9";
Någon som har nån aning om vad felet kan vara? (okej koden är nog inte den bästa så all feedback är varmt välkommen då detta är mitt typ 3:e VHDL "program")
