Halvledare av lödtenn?
Jag har varit med om del konstiga fenomen runt att kall-lödningar och liknande. Nu undrar jag om kontakten mellan tenn-ytor (e.v med förorening från lödning), kan skapa någon sorts halvledare, typ diod?
Re: Halvledare av lödtenn?
Skulle detta kunna vara något?
Kopparoxid-diod
http://www.hpfriedrichs.com/radioroom/c ... -diode.htm
Kopparoxid-diod
Oxidskikt är olinjära...
https://en.wikipedia.org/wiki/Rusty_bolt_effect
Passive intermodulation (PIM), however, occurs in passive devices (which may include cables, antennas etc.) that are subjected to two or more high power tones. The PIM product is the result of the two (or more) high power tones mixing at device nonlinearities such as junctions of dissimilar metals or metal-oxide junctions, such as loose corroded connectors. The higher the signal amplitudes, the more pronounced the effect of the nonlinearities, and the more prominent the intermodulation that occurs — even though upon initial inspection, the system would appear to be linear and unable to generate intermodulation.
Sources of PIM
Ferromagnetic materials are the most common materials to avoid and include ferrites, nickel, (including nickel plating) and steels (including some stainless steels). These materials exhibit hysteresis when exposed to reversing magnetic fields, resulting in PIM generation.
PIM can also be generated in components with manufacturing or workmanship defects, such as cold or cracked solder joints or poorly made mechanical contacts. If these defects are exposed to high RF currents, PIM can be generated. As a result, RF equipment manufacturers perform factory PIM tests on components, to eliminate PIM caused by these design and manufacturing defects.
In the field, PIM can be caused by components that were damaged in transit to the cell site, installation workmanship issues and by external PIM sources. Some of these include:
Contaminated surfaces or contacts due to dirt, dust, moisture or oxidation.
Loose mechanical junctions due to inadequate torque, poor alignment or poorly prepared contact surfaces.
Loose mechanical junctions caused during transportation, shock or vibration.
Metal flakes or shavings inside RF connections.
Inconsistent metal-to-metal contact between RF connector surfaces caused by any of the following:
Trapped dielectric materials (adhesives, foam, etc.), cracks or distortions at the end of the outer conductor of coaxial cables, often caused by overtightening the back nut during installation, solid inner conductors distorted in the preparation process, hollow inner conductors excessively enlarged or made oval during the preparation process.
PIM can also occur in connectors, or when conductors made of two galvanically unmatched metals come in contact with each other. Nearby metallic objects in the direct beam and side lobes of the transmit antenna including rusty bolts, roof flashing, vent pipes, guy wires, etc.
Sources of PIM
Mycket intressant, stort tack. Har skummat och ska läsa mer ingående.Micke_s skrev:Skulle detta kunna vara något?
Kopparoxid-diod
Bakgrunden till min fråga är ett problem med ett kretskort som jag felsökte. Två komponentben hade fått en dålig placering, vilket gjorde att de hamnade i kläm vid montering av plastlocket på den plastlåda de var monterade i. Ena komponentbenet var jord, och andra kopplat med 2k pull-up till 3,3V. Utan lock vilade spänningen på 3,3V som förväntat. Med locket monterat (vilket tryckte med stor kraft på dessa lödningar) sjönk spänningen till ca 0,6-0,8V. Jag kunde återskapa fenomenet gång på gång genom att montera loss och dit locket. Det gick inte att mäta någon resistans med multimetern mellan lödningarna. Diod-mätning tänkte jag inte på vid tillfället. Men jag kan bara förklara det här fenomenet med att det bildats en diod i kontaktytan mellan lödningarna, när de hamnade i kläm. Låter det fysiskt möjligt? Ingen tror mig, snarare skrattar dom åt mig.
Sedan filade jag ned benen/lödningarna, och allt fungerade som det skulle efter detta.
Hittade den här listan över halvledande material, och där finns både kopparoxid (Cu2O, CuO) och tenndioxid (SnO2)
https://en.wikipedia.org/wiki/List_of_s ... _materials
YD1150, intressant, nu känns det som att det ändå ligger något i min teori.
