/jonas
K8200 & Linux - den saknade manualen
piano_jonas
Re: K8200 & Linux - den saknade manualen
Nix, pix, mono använder sig av mono för att installera sig själv och därför måste redan en mono-version vara installerad (hmm.. hönan och ägget
) . När uppenbarar sig felet? Är det när du startar Repetier?
/jonas
/jonas
piano_jonas
Något felmeddelande som kan ge ledtråd? Jag misstänker att det kan vara någon länk till ett dynamiskt library som blivit galet?
/jonas
/jonas
här kommer en traceback:
[stda@localhost .cddb]$ /opt/3d-printer/RepetierHost/repetierHost
Unhandled Exception:
System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.XplatUI ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: libgdiplus.so
at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
at System.Drawing.GDIPlus..cctor () [0x00000] in <filename unknown>:0
--- End of inner exception stack trace ---
at System.Drawing.Graphics.FromHdcInternal (IntPtr hdc) [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11.SetDisplay (IntPtr display_handle) [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11..ctor () [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUIX11.GetInstance () [0x00000] in <filename unknown>:0
at System.Windows.Forms.XplatUI..cctor () [0x00000] in <filename unknown>:0
at System.Windows.Forms.Application.EnableVisualStyles () [0x00000] in <filename unknown>:0
at RepetierHost.Program.Main (System.String[] args) [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for System.Windows.Forms.XplatUI ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: libgdiplus.so
Jag har antagligen totalmissat något. Men jag körde repetiers installer direkt. http://www.repetier.com/download/
Dock använder jag inte repetier-host utan pronterface mot min printer. Gör repetier-host för windows något annorlunda än repetier-host för linux som vellemanprintern behöver?
piano_jonas
Sorry för oerhört sent svar... Men, men. Det är något länkat library som inte hamnar rätt i installationen. Vad får du för resultat om du kör:
ldconfig -p | grep libgdiplus
du måste köra kommandot som root (su)
/jonas
/jonas
[Nuc:flog:0] sudo ldconfig -p | grep libgdiplus ≈
libgdiplus.so.0 (libc6,x86-64) => /usr/lib/libgdiplus.so.0
libgdiplus.so (libc6,x86-64) => /usr/lib/libgdiplus.so
[Nuc:flog:0] ls | grep libgdiplus [/usr/lib]
libgdiplus.so
libgdiplus.so.0
libgdiplus.so.0.0.0
piano_jonas
Men Flog, har du fått K8200 att fungera bara sådär med din Linux-distrubution? Vilken är det i så fall?
/jonas
Borde varit tydligare. Jag använder inte vellemantprintern. Men jag blev nyfiken varför ni inte använder installern.
Själv kör jag en smoothiebaserad kossel. Installerade repetier host på test på min ubuntumaskin.
piano_jonas
Aha! Som nämnt i början på tråden - av någon knepig anledning stöder inte mono-ramverket den baud rate (250000) som K8200:ans styrkortet arbetar med
. Urdumt.
/jonas
/jonas
Jag skulle kunna testa repetier host mot min rumba med repetier om det är intressant.
