Delay bekymmer
* (C) Icecap 2006-02-10        *
* Ska köra på en PIC16F628A *
* MikroC                               *
#define false 0
#define true  1
typedef unsigned int  word;
typedef unsigned char byte;
typedef unsigned long dword;
byte Delay_Counter;
void Initialize(void);
void interrupt(void)
  if(PIR1.TMR2IF)
    PIR1.TMR2IF = false; // Acknowledge interrupt
    if(Delay_Counter) Delay_Counter--; // If >0 count it down
void main(void)
  Initialize(); // Set up timers, interrupts, variables and such
  while(true)
    { // Repeat forever
    Do_Thing_1();
    Delay(25); // Wait 1 sec
    Do_Thing_2();
    Delay_Counter = 25; // Set to 1 sec delay
    while(Delay_Counter)  // Wait 1 sec
      if(Alarm_Input) Delay_Counter = 0; // Terminate wait if something is wrong
    } // And then do it all over again
void Delay(byte Length)
  Delay_Counter = Length;
  while(Delay_Counter); // Wait for it to be finished
  Delay_Counter =    0;
  TRISB       = 0x01; // All out but PORTB.0
  TRISA       = 0x00; // All out, unused
  CMCON       = 0x07; // No comparator inputs
  PORTA       = 0x00; // Set to all '0'
  PORTB       = 0x04; // Set to all '0' but PORTB.2 (Ser out)
  // Set UART to 19K2,n,8,1
  SPBRG       =   12; // 19K2 @ 4MHz
  TXSTA       = 0x26; // Asynk,8,n,1
  RCSTA       = 0x80; // Kickstart UART, transmit only, no RX
  // Set Timer2 to give repeated interrupts, it's the time-tick of the whole system
  T2CON       = 0x4E;
  PR2         =  249; // 124 = 50Hz, 249 = 25Hz
  PIR1.TMR2IF =    0;
  PIE1.TMR2IE =    1;
  // Allow interrupts in general
  INTCON      = 0xC0;
Ett enkelt exempel på hur man använder interrupt till att time saker och hur man kan vänta och ändå utföra saker. Man kan även utföra saker under tiden det väntas som jag har visat med ett exempel.
