Fibaro RGBW
Retroperra
Re: Fibaro RGBW
Inlägg av Retroperra »
Jag hänger inte med. Försöker du styra en motor med en LED-dimmer?
wb4net
Skype: wbl.se
Re: Fibaro RGBW
Inlägg av wb4net »
Hello All
I have done the electronics R&D development for the Draftoptimizer system ( WedeCon Design - Denmark)
A new advanced wireless remote control solution has just been released for the Draftoptimzer system .
Please have a look into the PDF userguide of the new advanced software control functions at the Draftoptimizer homepage
Please have a nice day
Velkommen til at besøge - Welcome to visit :
http://www.wb-net.dk
http://www.c22.dk
http://www.gsm-control.c22.dk
http://www.c22.dk/press1
FACEBOOK : https://www.facebook.com/wedecon
mrfrenzy
Re: Fibaro RGBW
Inlägg av mrfrenzy »
Welcome to the forum wb4net. It is always nice to get comments directly from the designer.
The wireless controller looks like a nice product for someone who just wants to control their draft optimizer.
However, what we are trying to do here is connect the fan to an existing home automation system for example zigbee, knx, openhab etc.
We are trying to figure out what are the control signals accepted on the CTRL input of the control box but cannot find it in the manuals.
sumo89
Re: Fibaro RGBW
Inlägg av sumo89 »
Thanks all for your help! :)
@wb4net: I really appreciate what you done with the wireless controller - but like mrfrenzy said - I'd like to integrate this with my existing system, which for the moment is Domoticz.
And I know many of you think I'm crazy, trying to controll this with a "LED dimmer". But this device have 4 PWM outputs which I can controll individually. Output is PWM 244Hz.
I got (some) specs for the motor itself and it have three cables, GND, 24VDC and CNTR.
CNTR is "24 V version; 400 - 1300 rpm; 0-10 V interface".
But in the PDF there is no electric connection diagram for the 3620, but looking at most other fans in the same PDF which have a connection diagram - the 0-10V interface is also a PWM interface.
So... Could I just directly connect:
Fibaro 24V -> Motor 24V
Fibaro GND -> Motor GND
Fibaro W -> Motor CNTR
...and it will just work? Or will everything burn and die? ;)
sumo89
Re: Fibaro RGBW
Inlägg av sumo89 »
Och nu precis fick jag specarna från tyskarna!
Jag fick dem i förtroende, så vill någon se kan jag skicka PM. Men det är 24v, gnd och 0-10v control.
Så nu tänker jag mig denna bara direkt på motorn:
http://smart-telematik.se/product.html/ ... mmer-0-10v
Done? :)
sumo89
Re: Fibaro RGBW
Inlägg av sumo89 »
Jag fortsätter att svara på min egen tråd... ;)
Men lösningen var ju inte svårare än det jag skrev ovan. Qubino Flush Dimmer 0-10V. Specen säger att CTRL porten egentligen bara använder området mellan 5-7.5V. Men det är ju inga problem då man sätter "min dim value" till 50% (5V) och "max dim value" till 75% (7.5V).
Fungerar klockrent!
